Fat Bob's or...?
Discussion in '4 Cylinder' started by Grim, Sep 27, 2010.
  1. Sep 27, 2010 at 5:57 AM
    Grim
    Grim [OP] Active Member
    Will
    Lancaster, PA
    With looking around, at all the leveling kits around, I have a few questions that I'm hoping someone can enlighten me on.
    is 2.5" the preferred level kit? I've seen 2" and others and what I'm wondering is if 2.5" is preferred, is a diff drop required? It seems like the Fat Bob 2.5" kit is wicked simple, just wanted to make sure 2.5" is what I would need and that by adding this the ass end won't "droop", cause no one likes a droopy ass.
  2. Sep 27, 2010 at 6:01 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    I'm going to assume Fat Bob's is a spacer lift without looking. Save a few more pennies and grab yourself a set of 5100s, you'll have a much better experience than with spacers. Do you have the TSB done for the rear leafs?
  3. Sep 27, 2010 at 6:20 AM
    Grim
    Will
    Lancaster, PA
  4. Sep 27, 2010 at 6:46 AM
    Grim
    Will
    Lancaster, PA
    Haven't been able to really locate any TSB's applicable to the 2010. There is 1 TSB for floormats, and 5 recalls. 2 ended 2/5/10, 1 is for the gas pedal sticking issue, and 2 are for labels.
  5. Sep 27, 2010 at 9:45 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I assume you have 5lugger Taco. That's how it seems from your profile.
    I would suggest Fat Bob's leveling kit with AAL's Than adding longer Billstein shocks in the rear.
  6. Sep 27, 2010 at 10:26 AM
    Grim
    Will
    Lancaster, PA
    6 lug, 2010 reg cab 4cyl 5spd 4x4. ok, well, with adding shocks and AALs, would it just be a more efficient route to go with Billy's all the way around? I've been reading the 5100's are adjustable in the front, so if I do them all around, would AALs still be needed? Sorry, a bit new to trucks and all the acronyms used on here. Used to be a Ford mechanic, car side, so i know my way around a wrench, but when it comes to lifts, yeah, I'm a noob. Thanks for your help :)
  7. Sep 27, 2010 at 10:33 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I have a brand new set of 2.5" spacers I'm selling in the BST thread linked below this post for half what you are about to spend.
    I weighed my options back and forth and wound up going with Billys in the front, and AAL in the back. Its all about what works best for you. I decided that since I was getting the lift 100% for function I wanted to have the Billys. If you are just doing it for looks or will only be seeing light off road driving then the spacers are way cheaper and easier to install. There is a lot of back and forth about safety with spacers, but at the end of the day some dealers install them as "factory equipment".
  8. Sep 27, 2010 at 10:48 AM
    Grim
    Will
    Lancaster, PA
    I would say as of now it'd be for looks, but I would also like functionality. We have a cabin up near State College, PA and some of the mountain roads are rough. Not saying that the spacer wouldn't work, I'd just want to make sure that I wouldn't have any issues. So if Billy's in the front and AAL in the rear would get me the best all around performance and street-ability, then that sounds like the best option... unless I'm on :rasta:
    I appreciate your help, wicked nice of ya!
  9. Sep 27, 2010 at 11:04 AM
    flightcancled
    That's how we roll around here. ;)
  10. Sep 27, 2010 at 8:35 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    i have the 2.25 lift from fat bobs and have had zero issues only thing i have noticed is when it is super windy i feel like the steering ''floats'' but im talking a Gusty day we dont get many of those here in houston but thats my only complaint.
  11. Oct 1, 2010 at 5:30 AM
    Grim
    Will
    Lancaster, PA
    hmm, ok. I was just curious if anyone really had any issues with them. I'm almost liking the idea of Billy's up front for now and maybe an AAL in the next few months. I have read alot about the TSB thing, but it seems that the '10s aren't eligible :confused: I haven't had any substantial weight in the back, just a few kayaks and a beagle. The ride doesn't seem rough at all, but I will have to add some weight to see. Are the '10s eligible for the TSB or have they corrected those issues?
  12. Oct 1, 2010 at 6:12 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Keep us updated on what you do with the lift. I have the same truck as you and am debating on which way to go also. Ironically I was also a mechanic on the car side of Ford but am not familiar with the lifts. Any pics would be greatly appreciated. I'm kicking around the Bilstein 5100's all-around but from what I read on here, the front gives you more lift than the rear. Right now my truck seems to sit pretty level. Also, did you ever get a response regarding the drop for the rear end?
    Thanks,
  13. Oct 1, 2010 at 6:30 AM
    Grim
    Will
    Lancaster, PA
    I sure will keep an update going, I have some feelers out there for pricing from some friends that get wicked deals and pass the savings along. Yeah, from my understanding, the fronts are the only ones that adjust, the rear do not but offer longer travel. At least that's what I gather. Mine seems to sit pretty level as well, just wanted to get the front a bit higher, seems like the clearance is a bit on the low side to me. No, never got any response for the diff drop. I am going to go out on a limb and say that if there is no height adjustment to the rear, then there is no call for a drop to the diff. Maybe someone can enlighten me on that. I'm hoping to get pricing back today, and will keep this updated with what I find and will post pics if/when I get these installed. Thanks!
