Fat guy with baby feet? Wheels and lift question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mrsoffgridtaco, Feb 5, 2019.
  1. Feb 5, 2019 at 11:34 PM
    #61
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    2wd with a 6" lift is much easier/cheaper/easier to reverse
  2. Feb 5, 2019 at 11:34 PM
    #62
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Changes options of lifts available to you, spindles, etc.
  3. Feb 5, 2019 at 11:35 PM
    #63
    Mrsoffgridtaco
    Mrsoffgridtaco [OP] My truck, my mods, my opinion.
    Brianna Hess
    PNW
    ‘18 Tacoma TRD Offroad- cement
    Yeah I’m lifting it to better. Serve clients. So it’s a write off :spending:
  4. Feb 5, 2019 at 11:39 PM
    #64
    Mrsoffgridtaco
    Brianna Hess
    PNW
    But I like the look better than your truck feel haha. It’s a write off so no worries I’m depriciation here
  5. Feb 5, 2019 at 11:40 PM
    #65
    Mrsoffgridtaco
    Brianna Hess
    PNW
    Actually it’s the dealer who told me warranty is good up to 6” lifts
    Dr. Emmett Brown likes this.
  6. Feb 5, 2019 at 11:41 PM
    #66
    Mrsoffgridtaco
    Brianna Hess
    PNW
    Not planning on selling that’s for sure
  7. Feb 5, 2019 at 11:41 PM
    #67
    Dr. Emmett Brown
    Haha I see.
    Well what do YOU want? A 3" lift on these 3rd gens look awesome. Not to mention, depending on the setup, they are most practical while off roading at this height.
    I'm waiting on my lift kit parts to arrive and will be lifting my truck 3" this month.
    A 6" lift, however, is also a very awesome option. Like most will say, due to you having 4wd, you will have to cut the rear most -front cross member to allow the front drive shaft to go through the space where the cross member usually is. This can pose a problem for many people so you should be warned that this is part of lifting the truck 4" or higher. If done by a professional, the cut piece can always be welded back into the cross member, or a new piece can be fabricated if you ever decide to take the drop bracket 6" lift off and return to stock.
  8. Feb 5, 2019 at 11:44 PM
    #68
    Mrsoffgridtaco
    Brianna Hess
    PNW
    Heyyyy! I know a great realtor that can get the house you want at the price you want. Just sayin :cool:
  9. Feb 5, 2019 at 11:51 PM
    #69
    TacoBuffet
    AL
    Ummm. I would question that. You are going to be cutting into your truck, I doubt Toyota would honor any warranty work related to potential issues stemming from you doing so, again do your research before you start chopping. Magnuson-Moss Warranty Act
    shane100700 likes this.
  10. Feb 5, 2019 at 11:52 PM
    #70
    TacoBuffet
    AL
    Lol, not quite there yet, 2 years from now I'll give ya a shout.
  11. Feb 6, 2019 at 1:19 AM
    #71
    Mrsoffgridtaco
    Brianna Hess
    PNW
    I’ll double check With them tomorrow. Maybe it’s just if Toyota does it for me. I dont know
  12. Feb 6, 2019 at 1:20 AM
    #72
    Mrsoffgridtaco
    Brianna Hess
    PNW
    Okay so if I do a 3” then I will be good with stock wheels and just need to get tires?
  13. Feb 6, 2019 at 1:31 AM
    #73
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    JCOOR likes this.
  14. Feb 6, 2019 at 6:04 AM
    #74
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    6" inch lifts require a good bit of work to do right.... Look for the Brocoma thread.
    2.5" lifts with big tires look good on these trucks. Be prepared to do a little cutting and welding though.
  15. Feb 6, 2019 at 6:14 AM
    #75
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    I wouldn't lift a truck without some negative offset, especially with a 6 inch lift. That's just me but its something to keep in mind when buying wheels if you want that look too.
  16. Feb 6, 2019 at 6:19 AM
    #76
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    3" with 285/70r17. If you want to use the stock wheels you will need wheel spacers because anything bigger than 265s will be to close or rub on the upper control arms.
    And for size reference.
  17. Feb 6, 2019 at 6:22 AM
    #77
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It depends on the look you want. You are asking a subjective question.
    You will need (IMO) at least a 285 tire with a 6 inch lift. Which means you will need to chop your body to fit depending on the type of lift you do and almost certainly will need to modify the spare tire space or relocate your spare because if you are too much outside 33” tire it ain’t gonna fit under the bed.
    Whether or not you need a larger wheel is up to you. You may not like wider taller tires on a 16” rim.
    I like more tire than wheel. I think large wheels look ugly AF on trucks. I hate anything bigger than 17” rims on pretty much all trucks to include full size.
    Smokehouse likes this.
  18. Feb 6, 2019 at 7:24 AM
    #78
    Dr. Emmett Brown
    Depending on what size tires you go with, you might need wheel spacers for the tires to clear the upper control arms.
  19. Feb 6, 2019 at 7:47 AM
    #79
    Professional Asian
    Professional Asian Ridgeline Enthusiast
    Andrew
    Eureka, California
    2017 DCSB TRD off road MT [OVtuned]
    @Dr. Emmett Brown I’m sorry but 6” lift with 33’s looks like a skateboard, which is exactly what she wanted to avoid lol.
    OP, if you’re gonna do a bro lift, do it right. 35” & up. Just make sure you regear to 5.29’s or your truck will suck.
    This should give you a good idea of what it’ll look like
    https://youtu.be/eWK9xPOMSDk
  20. Feb 6, 2019 at 7:58 AM
    #80
    TacoMateo
    TacoMateo Well-Known Member
    Nor Cal
    2019 DBLB TRDOR CEMENT
    If your not in a rush maybe you should see if there’s any meet ups in your area. Then you can see a bunch of options in person. Or check some of the local dealers that sell the trucks with lifts on them to see what you like and compare.
    Or you can just give me your cc info and I can order everything for you:spending:
