Fatory tow package without 7pin connector
Discussion in 'Towing' started by Jfarrar, Mar 11, 2015.
  1. Mar 11, 2015 at 6:09 PM
    Jfarrar
    Jfarrar [OP] New Member
    Vermont
    09 Tacoma sr5
    I have a 2009 Tacoma SR5 with factory tow package. The truck only has 4 pin connector on the back of the truck, the fuse box has spaces with fuses in them for trailer charging, and brakes. So why don't I have a 7 pin connector, are there wires run to the back of the truck for attaching a 7 pin? The dealership said I had to replace the harness for a couple hundred bucks. Why would it be all setup for towing but not have the necessary wires run to the back of the truck? HELP
  2. Mar 11, 2015 at 9:09 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Why do you say it has factory tow package?
  3. Mar 12, 2015 at 5:53 AM
    Jfarrar
    Vermont
    09 Tacoma sr5
    The truck has transmission oil cooler, the larger alternator and battery, and hitch that is mounted to frame and bumper.
  4. Mar 12, 2015 at 6:07 AM
    Amajoy
    Amajoy Active Member
    Amanda
    Arizona
    2011 TRD DCSB 4x4 Manual
    3" revtek lift kit, DNA Cold Air Intake, 285/75/17 tires, XD addict rims, tint, smoked LED Halo projection headlights, LED fog lights, 30" Grill Light bar, LED interior light kit, blacked out tail lights, Bushwhacker fender flares, side rails, hood & window wind deflectors, 14" Magnaflow muffler (#12226)
    Just buy an adapter... It's a much cheaper alternative. My truck came with a 7 pin but my trailer has a 4 pin so I have to use an adapter. There is no winning, all depends on what you are towing...
  5. Mar 12, 2015 at 6:11 AM
    Amajoy
    Amanda
    Arizona
  6. Mar 12, 2015 at 7:48 AM
    Jfarrar
    Vermont
    09 Tacoma sr5
    That's the route I will probably go, however, is the wire for brakes already run from the cab to the back of the truck? I wasn't able to trace it back from the brake controller plug.
  7. Mar 15, 2015 at 11:41 PM
    Amajoy
    Amanda
    Arizona
    That I am not sure on for your truck/stock 4 pin, I would suggest taking it or calling uhaul and asking them. Sometimes the dealership isn't the best place as they are always trying to make money where it may not be necessary.
