Faulty Air Pressure Sensor Valves?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Mar 30, 2011.
  1. Mar 30, 2011 at 1:45 PM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Looks like my right rear tire has an air valve that doesn't allow me to fill up the tire. It's also prompting a check tire pressure light. Are these things really over $100? Has anyone here replaced them with a regular tire valve? Having a tire pressure sensor on an off road truck doesn't seem to make much sense considering that an owner might be constantly airing down the tires... :confused:
  2. Mar 30, 2011 at 1:52 PM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    Remove the valve core and see if its faulty. Maybe you can just replace that instead of the entire assembly.
    There is a reset button under the steering wheel that allows you to set the pressure of your tires to any pressure you'd like. If you air down, you can reset it. Air up, reset.
    It sure helps to let you know if you have a slow leak.
  3. Mar 30, 2011 at 1:52 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    you have a 2011 truck? take it in, and tell them to figure it out.
  4. Mar 30, 2011 at 1:56 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This ^^^^^^^
  5. Mar 30, 2011 at 5:15 PM
    K Williams
    Long Island, NY
    Same thing I was thinking...
