Faulty gas cap or something else?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scrappydawg1141, Aug 8, 2022.
  1. Aug 8, 2022 at 3:57 PM
    Scrappydawg1141
    Scrappydawg1141 [OP] Member
    Kevin
    2017 Toyota Tacoma
    Hello Everyone.
    Everytime I get gas within 5 miles the check engine light comes on. I replaced the fuel cap but no change. I dread taking my truck to the dealership but with the check engine light on I lose the traction control and cruise control. I've reset the check engine light but it only lasts a day or two before coming back on. Could this be an oxygen sensor?
    zoo truck and na8rboy like this.
  2. Aug 8, 2022 at 3:58 PM
    Bishop84
    Bishop84 Well-Known Member
    What code? Without knowing you'll never be able to solve it.
  3. Aug 8, 2022 at 4:59 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Do you also get an intermittent Track On light? I had a Duralast locking cap that would throw a CEL and Track On light. Don’t remember the trouble code.
    Junkhead likes this.
  4. Aug 8, 2022 at 5:21 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    You need to read the codes before resetting, next time it happens post them here for some help.
    You aren't "topping off" the tank by chance are you?
    Modern vehicles are fill to the click and that is it, putting additional gas after the first click can put liquid gas in the vapor recovery system and will can result in an expensive repair.
  5. Aug 9, 2022 at 5:18 AM
    Scrappydawg1141
    Kevin
    2017 Toyota Tacoma
    Thank you all for the responses. The traction control and cruise control lights are the only ones that come on. I will in fact post the codes next time it happens.
    And yes, an old Army habit of always topping off when fueling is what I do. Didn't realize this could cause an issue.
  6. Aug 9, 2022 at 5:23 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Yep, this right here... Not good to do on modern vehicles.
  7. Aug 9, 2022 at 6:41 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    That’s it. A very costly repair. Charcoal canister is f….. up.
  8. Aug 9, 2022 at 10:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Could be an 02 sensor. You'd need to read the code.
  9. Aug 9, 2022 at 11:02 AM
    Scrappydawg1141
    Kevin
    2017 Toyota Tacoma
    I am. Of course when I want the check engine light to come on so I can get the code it won't. It's running just fine at the moment. I'm hoping it's just that oxygen sensor. Thanks for the response.
    I will post the code when I check it
  10. Aug 9, 2022 at 11:09 AM
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    i got a locking gas and every so often the ! pops on the right screen and on the center it actually says gas cap..... so I have to take it out put it back on tighter and restart the truck....my tuck is a 2022 yours is a 2017 not sure if you have the screen that shows that.
    but a truck that is 5 years old should not have the O2 sensor failing already unless you have like 200,000 miles on it
  11. Aug 9, 2022 at 11:10 AM
    Scrappydawg1141
    Kevin
    2017 Toyota Tacoma
    Good info.
    I'm at 100,058 miles
    erwigg likes this.
  12. Aug 9, 2022 at 11:32 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Well maybe we are on to something, that's is a no no.
  13. Aug 10, 2022 at 4:29 AM
    Scrappydawg1141
    Kevin
    2017 Toyota Tacoma
    So here's the thing,...usually by now the check engine light has come back on. It hasn't. All I've done is tightened the cap every time before starting my truck.
  14. Aug 10, 2022 at 4:33 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Cheap test is to buy a new gas cap and use it to see if the check engine light comes on again or not.
  15. Aug 10, 2022 at 4:57 AM
    Scrappydawg1141
    Kevin
    2017 Toyota Tacoma
    Hey TexasWhiteice,
    I actually replaced the cap with a new locking cap but it didn't correct the problem. I've been tightening the old cap everytime before starting the truck and the check engine light has yet to come back on.
  16. Aug 10, 2022 at 5:50 AM
    zoo truck
    None
    The code should be registered in the cpu's memory how many times it happened. Something doesn't sound right why your not seeing it.
  17. Aug 10, 2022 at 6:50 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Correct, the codes should be stored and retrievable even if the light has gone out. The codes do not erase themselves when the light goes out.
