Faulty Gas Caps/Small Fuel Emmission Leaks?
Discussion in 'Technical Chat' started by AFGator, Nov 21, 2007.
  1. Nov 21, 2007 at 1:39 PM
    AFGator
    AFGator [OP] Member
    Jeff
    Guam, USA
    2006 TRD Off Road Double Cab
    Hey all,
    I bought a gently used (6000 miles) 4 door 2006 V-6 back in June of 2007. While I was test driving the vehicle, the check engine light came on... so the dealership ran a diagnostic, determined it was a fuel emmission leak coming from the gas cap, and replaced the cap.
    The truck's been running like a dream until this week when the check engine light came back on, so I took it by Auto Zone for another diagnostic and it's supposedly the same problem.
    Has anyone had the same problem? Could the problem be something else?
    Rambo MARINE Recon likes this.
  2. Nov 21, 2007 at 8:30 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    make sure you are putting the gas cap on all the way.... (or your attendant of you are in oregon.)
  3. Sep 7, 2023 at 11:00 AM
    Socialwork05
    Socialwork05 Active Member
    2011 tacoma 4x4 v6
    Any advise, 2011 tacoma, dealer replace gas cap and engine and traction lights off for 1 day, took it to a different mechanic for a smoke test after PO456 code and determine that test smoke shows smoke coming from gas cap. could it be something different. thanks
  4. Sep 8, 2023 at 7:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did they cap off the vent line at the charcoal canister? You have to do that on Toyota LDP systems when doing a smoke test or you will always show a leak and it will be coming out of the filler neck area as that's where the vent comes out.
