Faulty TPMS fix
Discussion in 'Wheels & Tires' started by 07regtacoman, May 22, 2009.
  1. May 22, 2009 at 7:45 PM
    07regtacoman
    07regtacoman [OP] Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    For a year and a half I have had this stupid light on shortly after I bought my truck.10 hours at the dealer and no more light.What would happen was I got a light that would continously blink and then would go solid.Pressing the reset button would do nothing.Took it in and was said on the work order that the TPMS wiring harness behind the deck was crimping and caused a short curcuit leading to the trucks ecu causing the light to turn on.I didn't even know there was a wiring harness for that behind the deck.This light being on the whole time and they fixed it under warranty,Thank you Toyota.
  2. May 22, 2009 at 7:47 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Good to see toyota helped you out.
