F'd up while working on drum brakes. Help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Dec 12, 2018.
  1. Dec 13, 2018 at 9:36 AM
    #101
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Totally agree. I need to do this after many years of braided lines on my bikes.
  2. Dec 13, 2018 at 10:01 AM
    #102
    btaco623
    btaco623 Well-Known Member
    Central Ohio
    '17 TRDOR
    Hood Blackout, 5100,LED Low's, SuperSprings
    Did you try the c-clamp method that was mentioned? Take off res. cap then use c clamp to compress the cylinder. Similar to how you get the pistons on disk brakes to compress when changing fronts. Need to take the shoes off first.
    tonered likes this.
  3. Dec 13, 2018 at 10:06 AM
    #103
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With the bleeder open, the OP might be able to press them back in with finger pressure as long as they are aligned. I can do that on my bikes with bigger pistons that those.
    Woodrow F Call likes this.
  4. Dec 13, 2018 at 10:06 AM
    #104
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    It's probably fixable. Take the brake pads off, open the reservoir, make sure the pistons are centered and push back in using a c clamp as mentioned. Inspect the seals, make sure they are back in place and not torn. Re-assemble the brakes. Bleed the brakes. A one man brake bleeding kit is pretty helpful. One driven by a compressor is even nicer.
    Flash1034 and tonered like this.
  5. Dec 13, 2018 at 10:07 AM
    #105
    Woodrow F Call
    Colorful Colorado
    Probably easier this way. Excellent point.
    tonered[QUOTED] likes this.
  6. Dec 13, 2018 at 10:10 AM
    #106
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    not sure if anyone mentioned this in the six pages of this thread but backing up does NOT adjust these rear brakes. Making sure they are properly adjusted before putting back together, then always use the e-brake. Using the e-brake is what keeps the rear drums in our trucks adjusted.
  7. Dec 13, 2018 at 10:16 AM
    #107
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    sounds like a shit show. This happened on my front brakes when I had my dad helping me. Pressed on the brake pedal without the disc or block in place. Grabbed a rebuild kit as it destroyed the dust covers. I have not touched the drums yet but I need to get in there and clean them.
    good thread of tips here for drums. One of the things I never touch since they never need any service for years.
    tonered likes this.
  8. Dec 13, 2018 at 10:21 AM
    #108
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  9. Dec 13, 2018 at 10:24 AM
    #109
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  10. Dec 13, 2018 at 10:29 AM
    #110
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Must be an old model. They haven't had rear drums in close to a decade.
    I used to gather info there from time to time when my wife had a Prius. Don't laugh. Many of those "nerds" are some serious wrenchin' fools.
  11. Dec 13, 2018 at 10:32 AM
    #111
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers: Just trying to draw a minor distinction.
    Yeah, but it is going to be a much smaller percentage in that community. Some neat engineering has poked its head out over there. Homemade plug-in conversions and such, not too mention a couple hot rods and soft roaders.
  12. Dec 13, 2018 at 10:41 AM
    #112
    BillsSR5
    bill
    2014 SR5
    true, I picked up some very good DENSO wiper blade replacements based on some of those Nerds advice on them. https://media.tenor.com/images/cc127125c1e41a3d64d52825f0204dd4/tenor.gif
  13. Dec 13, 2018 at 10:46 AM
    #113
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    now all that's left to do is a dozen roses for your girl friend followed up by dinner at a really nice restaurant.
    mateo_roberto likes this.
  14. Dec 13, 2018 at 10:53 AM
    #114
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If the boots are fine it’s fine
    Bleed it & go
  15. Dec 13, 2018 at 11:09 AM
    #115
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    How many miles on your truck? I have 127k and rears were still good. You have a 2017...is the dealer telling you they needed replacement?
  16. Dec 13, 2018 at 3:09 PM
    #116
    Plain Jane Taco
    USA
    I cleaned and adjusted the rears on mine at 50k miles and they practically looked new, save a bit of dust. Not expecting to replace the shoes for the foreseeable future.
  17. Dec 13, 2018 at 3:15 PM
    #117
    Plain Jane Taco
    USA
    I don't know. Given that Toyota sells thousands more Tacos a year than they do Prius...especially with cheap gas these days...I be willing to bet the percentage is just as high, if not higher.
    Sure, the actual total numbers might favor the Tacoma owners. But when you look at the number of Taco vs Prius sales....the percentage is not so different I bet.
    I'm tellin' you....there's some serious Einstein wrenchers over there. o_O
  18. Dec 13, 2018 at 4:14 PM
    #118
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    about 47k taco recall about brake in jan.2019,
  19. Dec 13, 2018 at 4:34 PM
    #119
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    Even though there is an adjustment. in most cases if the park brake is not engaging well or not holding well its because the brake shoes are not adjusted tight enough against the drum.. by adjusting the cable for the park brake all your doing is not allowing the shoes to retract all the way back as if the park brake is semi engaged even with handle all the way down. 1st thing to do is adjust the star wheel to make sure they are properly adjusted then if you still have an issue with the park brake then the next step would be to adjust the cable.
  20. Dec 13, 2018 at 4:37 PM
    #120
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    Take the cap off Reservoir so the fluid can be pushed back up
    tcjacado likes this.
