Fed up, 2.7 Cold Start Issues Continuing...
Discussion in '4 Cylinder' started by travis9287, Oct 2, 2011.
  1. Oct 2, 2011 at 8:58 PM
    travis9287
    travis9287 [OP] Well-Known Member
    Travis
    Tuscaloosa,AL
    2003 Tacoma, 2006 GX470, 2000 Jeep TJ, 1985 C10
    a lot lol
    Well i posted awhile back about my cold start issues with my 2.7. on the first start in the mornings it turns, turns, and i have to throtle it pretty hard til it warms up, then it seems like im good unless the engine cools off completly. I have no clue what it could be, I replaced my fuel regulator, The EGR return pipping gasskets. I Looked for the CSI but i dont have a clue where to look? think this is my problem? where is the CIS? or the Timer?
  2. Oct 3, 2011 at 8:09 PM
    travis9287
    Travis
    Tuscaloosa,AL
    a lot lol
  3. Oct 5, 2011 at 5:03 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Have you tried looking at the Idle Air Control valve? Cleaning the throttle body? I have zero experience with the 1st gen engines, so just guessing.
  4. Oct 5, 2011 at 12:34 PM
    travis9287
    Travis
    Tuscaloosa,AL
    a lot lol
    No i havent, Im just trying to elminate things, thanks for the advice.
  5. Oct 18, 2011 at 6:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Did you check the PCV valve is rattling freely?
    Check EGR valve moves freely.
    Are all the little rubber hoses connected :) in good shape or dry, brittle and broken? Engines do not like vacuum leaks.
    Check engine wiring being burned, pinched or damaged (especially by critters!).
    I like having a spare fuel pump relay around.
  6. Oct 20, 2011 at 12:10 PM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    you mite also want to have a tech use a scan tool and see what the engine temp sensor is saying when trying to start it cold.the sensor could be bad and the computer would not nessarly know that so the engine ligth would not be on.
  7. Oct 20, 2011 at 6:58 PM
    travis9287
    Travis
    Tuscaloosa,AL
    a lot lol
    Just got it scanned and it indeed did come up with the coolant sensor! so ill probably replace that and see what that does!
