Federal or california emissions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebigcatladd, May 20, 2023.
  1. May 20, 2023 at 1:05 PM
    thebigcatladd
    thebigcatladd [OP] New Member
    There is no emmissions sticker under the hood. On the door it states"This vehicle conforms to all applicable federal vehicle safety and theft preventions standards."
    Does this mean that I do not have to put a carb cat on here if the state I register it in does not require a carb cat. Am I good to go with a EPA cat?
  2. May 20, 2023 at 1:31 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    If you live in Lala land (Calif.) You'll have to install a carb-compliant cat. If outside in the normal USA. just any cat for it will do.
  3. May 20, 2023 at 1:59 PM
    TacoTuesday1
    SD CA
    this. Which CA cats cost a lot more. Smog station likely going to either ask for a receipt, check for stamp plaque on part, or both.
  4. May 20, 2023 at 3:38 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    That Cali state is F’d up with emissions
    1 Limited Toyota likes this.
  5. May 21, 2023 at 4:44 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    You in Ca.? In a more Cat. friendly state? I wish our icons stated where a member was located.
  6. May 21, 2023 at 5:06 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
  7. May 21, 2023 at 5:08 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    They do. Just depends how you have your profile set up.
  8. May 21, 2023 at 6:16 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    I’m in Mass, we have to get our trucks inspected every year at $35 a pop, but they just plug into your OBD to make sure your ball joints are good make sure your horn works all your safety stuff and all set​
