Feed Your Addiction: Tacomaholics "Anonymous" Support Group
Discussion in '2nd Gen. Builds (2005-2015)' started by boogie3478, Aug 2, 2017.
  1. Aug 22, 2019 at 6:40 AM
    #6641
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    bat ears
    Right!!! I am the same way. Now that the kiddo sits up front we listen to some stuff I have no clue what it is and she cranks it up. I get some weird looks from people because it's definitely girly.
    All toyota factory speakers are junk even the JBL ones are paper just like the ones in Brian's video just a little bigger magnet and a little better sound.
  2. Aug 22, 2019 at 6:58 AM
    #6642
    boogie3478
    boogie3478 [OP] Well-Known Member
    14 TRD Off-Road V6
    All the mods
    If that happens I'm selling the truck. :D I'm back and forth about covering the holes with sound deadener or some thick painter's plastic. The audio system I'll end up with isn't going to be super high end where that kind of extra seal will make that much of an acoustic difference. I might just end up using the sound deadener simply because I have a ton of it left and if I ever need to get into the door to fix anything I'll just cut out the hole and reseal later.
  3. Aug 22, 2019 at 7:10 AM
    #6643
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    The stinger fast rings or something similar will make a big difference even for what you have
  4. Aug 22, 2019 at 8:25 AM
    #6644
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Yeah I'm looking at those as well but they are pretty expensive just for precut foam. For the front 6x9 and rear 6.5 speakers the kits would be around $40.
  5. Aug 22, 2019 at 8:35 AM
    #6645
    boogie3478
    14 TRD Off-Road V6
    All the mods
    The foundation has been set! Well cut and fitted but you guys get the idea.
  6. Aug 23, 2019 at 10:38 AM
    #6646
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Used a UV dye kit and blacklight to see if my oil leak has returned. Big thanks to @NunyaBizness for providing the outro pic! :thumbsup:
    Watch the video HERE.
    lynyrd3, irayfz6 and Nunya Bizness like this.
  7. Aug 23, 2019 at 11:12 AM
    #6647
    Nunya Bizness
    You are welcome. Ill check it out after work!
  8. Aug 23, 2019 at 11:15 AM
    #6648
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Really hating not having a garage on days like today when it's constantly raining and I have a new part that just arrived that is itching to get installed.
  9. Aug 26, 2019 at 6:10 AM
    #6649
    lynyrd3
    Bill
    East Central Upstate NY
  10. Aug 26, 2019 at 6:32 AM
    #6650
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Very quiet lately.
    lynyrd3[QUOTED] likes this.
  11. Aug 26, 2019 at 11:18 AM
    #6651
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    Boogie I picked up a couple of the rotopax you have linked in your build and wanted to ask how the weather stripping you did in your video was holding up?
    boogie3478[OP] and lynyrd3 like this.
  12. Aug 26, 2019 at 11:19 AM
    #6652
    lynyrd3
    Bill
  13. Aug 26, 2019 at 11:54 AM
    #6653
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Weather stripping doing great and still keeping everything inside bone dry. Must have for the black rotopax boxes.
    Z7Xtreme[QUOTED] likes this.
  14. Aug 26, 2019 at 11:57 AM
    #6654
    1999TacoMan
    1999TacoMan Well-Known Member
    Brian
    Fort Worth,Texas
    2019 Tacoma TRD OR 4x4 DCSB (Sold)
    Hi everyone, my name is Brian and I'm a tacomaholic.
    lynyrd3 and boogie3478[OP] like this.
  15. Aug 26, 2019 at 12:01 PM
    #6655
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Hi Brian! Welcome! You're in the right place
  16. Aug 26, 2019 at 12:11 PM
    #6656
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Greetings Brian!
    lynyrd3 likes this.
  17. Aug 26, 2019 at 12:15 PM
    #6657
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Save measurements for this! I want to do something similar, but it's low on the list right now. I looked into doing it in aluminum, but the materials cost is a little silly.
  18. Aug 26, 2019 at 12:27 PM
    #6658
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Will do. Are you running the rear molle panel as well?
  19. Aug 26, 2019 at 12:28 PM
    #6659
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I went with the Pioneer AVH-4200. It's a nice headunit. And not too expensive. It's when you start adding the Maestro module, and SiriusXM box is when it gets expensive. I don't know what plugs the 2nd gens have in them, but I was able to replace the cigarette light plug with an HDMI and USB port, and keep the stock 3.5mm AUX plug and USB that the truck came with. There were also a few more adapters: one for the radio antenna, one for the GPS and SAT antenna. It all looks stock and stuff.
  20. Aug 26, 2019 at 12:29 PM
    #6660
    Z7Xtreme
    Chuck
    In a tree somewhere
    Very good!!!! Thanks boogie
