Feedback and thoughts on this billy setup
Discussion in 'Suspension' started by Bobcat Luke, Jan 31, 2020.
  1. Jan 31, 2020 at 11:51 AM
    Bobcat Luke
    Bobcat Luke [OP] IT
    Austin, TX
    2020 Cement TRD Sport DCSB
    Sup y'all, I've gone through hundreds upon hundreds of pages researching taco lifts and it has almost left me more confused than I was when I first joined
    :bikewheelie:
    So some context before we start:
    • I just want to fit some 275s or 285s but maintain or improve the reliability of my vehicle
    • I want to avoid rubbing, so I'm fine with trimming or getting a CMC if need be
    • My truck is my daily driver, with about 50 miles a day commute being on the highway
    • 99.9% on road, I don't plan on doing any offroading (lol i'm ready to be flamed) besides maybe going fishing or driving to a camping spot
    So many people on here say to avoid the spacer+block setup, but usually these are guys who off-road regularly (I don't). As the saying on here goes "buy once, cry one" so i'm willing to dish out a bit more cash to get the proper setup for my situation. But I don't want or need anything crazy like some Icons, kings, fox, full coilovers etc. Like I said, this is my daily driver pavement princess lol.
    So after talking to @Texoma about my situation and what i'm looking for, we came up with this initial setup:
    • Front and rear Bilstein 5100s
    • OME 888 Springs
    • 3 leaf AAL
    • JBA UCAs
    • Relentless Fabrications plates for cmc if need be
    I would like your opinion on this setup and I also have a couple questions:
    • I'm compiling a list of everything I will need to purchase so I can have an idea of how much money i'll be dropping. What are the smaller things that people tend to forget about when going with a lift like this (fix needle bearing issue, diff drop, bump stops, extended break lines etc.)
    • How does this compare to the Bilstein 6112/5160. These billys are supposedly an upgrade to the 5100s, so would I even want them as a daily driver setup?
    • Would a Dakar instead of an AAL in the back be overkill?
    • Or should I just get a simple 2 and 1 spacer+block or spacer+AAL and call it a day?
    I appreciate any feedback, advice, or cautionary tales y'all want to share!
  2. Jan 31, 2020 at 1:02 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You may consider wheelers super bumps for front and rear. You'd be surprised how often you actually hit your bump stops. This will smooth the ride out and protect your investment.
    So far, only 1% of 4wd vehicles have had the front driver diff needle bearing issue on lifts I've installed. Tou can go ahead and be proactive, or take a chance that you'll be ok.
    Stainless braided brake lines are much more than just being extended for lift. They also provide security from abration and line cuts, as well as better brake pedal response from it being a solid line rather than rubber which expands when pressurized.
    6112/5160 is an upgrade over the 5100 shocks. They do have a smoother ride than the 5100's which are slightly stiffer.
    Dakar or any other aftermarket leafpack will have better load carrying capability than the stock leafs with AAL. Ate you consistently carrying heavier loads? Camper, tool box, ect?
    You can go with a 2" front spacer and a single AAL in the rear for about $100. I dont suggest any larger spacers than that because your ride quality will be greatly degraded .
  3. Jan 31, 2020 at 2:09 PM
    Bobcat Luke
    Bobcat Luke [OP] IT
    Austin, TX
    SCS got back to me and said the Stealth 6s will be back in stock come March/April which is perfect since it gives me time to save up and buy everything all at once. That way when I come to you we can install lift, tires, wheels at the same time. I'm hyped to see the end product!
    Texoma[QUOTED] likes this.
  4. Feb 1, 2020 at 7:28 AM
    Bobcat Luke
    Bobcat Luke [OP] IT
    Austin, TX
