Feedback on a budget lift
Discussion in 'Off-Roading & Trails' started by Heats13, Jan 12, 2021.
  1. Jan 12, 2021 at 8:44 PM
    Heats13
    Heats13 [OP] Member
    Heather
    2020 TRD sport
    Diff breather 265/70R17 KO2 Rear air bags Brake controller RSI smartcap
    Hi, hoping to find some people who have done this budget friendly faux lift and get your thoughts. Good? Bad? Ugly?
    I also need tires so I can go bigger if I do this lift and then replace parts over time until it's the real deal. Or be stuck with just a smidge over stock size for a couple more years :(
    Mixed used but want to be able to tackle tougher trails.
    Here's the details:
    ReadyLIFT 69-5212
    Lift Kit Suspension; SST ® Series; 2-3/4 To 3 Inch Front Lift; 2
    Inch Rear Lift; Without Shock Absorbers In Kit - Shock Change
    Not Necessary; Black Components; Includes Sway Bar Drop
    Bracket/ Differential Drop Brackets/ Skid Plate Spacers/ Strut
    Extensions/ Rear Blocks/ U-Bolts
  2. Jan 12, 2021 at 8:46 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    No. That's a pretty sheit lift, top hat spacers and blocks are never a good idea.
    Do Bilstein 5100's and an add a leaf for a budget lift.
    Heats13[OP] and bryflies like this.
  3. Jan 13, 2021 at 4:00 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Srjohnstun15 likes this.
  4. Jan 13, 2021 at 4:51 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Wouldnt mind a block in the back but keep it under 1". Spacer in the front that gives 3" of lift will show its weakness once you start "tackling tougher trails".
    Grab 5100's or eibacks pro kit and an AAL and youll be under a grand and much happier.
    JMHO
    Heats13[OP] likes this.
  5. Jan 14, 2021 at 10:29 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You get what you pay for.
    If you want to offroad with it, steer clear of this type of crap. Block lifts give you all the disadvantages of a lift, and none of the advantages as your performance is going to decrease.
    Get yourself a set 5100s and an add-a-leaf in the back.
    But have you gone offroad with it at all yet? A bone stock truck is more than capable enough to get a novice in trouble. There's likely no need for lifts or anything just yet. If anything, all you really need to do is get yourself some better all terrain tires in the stock size.
    If all you have is $200 to spend, do NOT spend it on a lift. Spend it on gas. Go out and drive what you have.
    And please, just in general, don't buy your components from Amazon. Buy from a reputable off-road/truck specialist.
