Feedback on SeaFoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by NWTacoma95, Aug 20, 2013.
  1. Aug 20, 2013 at 4:59 PM
    NWTacoma95
    NWTacoma95 [OP] Member
    Bellingham, WA
    95 Tacoma LX Ext Cab
    3" suspension lift
    Hello, I have a 95 tacoma with about 250,000 miles. It has run well ever since I bought it ( Three years, and ten thousand miles ago). I was wondering if I should give seafoam a shot to see if it might clean it out and give it some more horse power. Maybe I've been missing out and not knowing it? Anyone with seafoam experience?
  2. Aug 20, 2013 at 5:14 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I would say go for it! I love seafoam, I seafoam my truck 2-3 times a year just to keep the engine running smooth. I bet you'll feel a difference in all aspects after doing a seafoam treatment.
    If you do it... make sure to run it through a vaccum line, and put some in the gas tank. You can also run some in the oil about 100 miles before you do an oil change. Also, after running it through a vaccum line, let it sit for 10 minutes or so, then start it up and let all the gunk come out. You should also take it on an open road and just gun it to help clear it up. Good luck!
  3. Aug 20, 2013 at 5:53 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    Thank you. Very helpful!
  4. Aug 20, 2013 at 5:56 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I've used it several times. It's some good stuff and it can be fun to haha
    FYI I usually put a third in the tank, a third in the oil, and pour the rest into a vacuum line or somewhere really close to the throttle body and let it die and leave it alone for about 15 mins. Then afterwards (100 or so miles) I change the oil, filter and plugs. Just what I've always done.
  5. Aug 20, 2013 at 6:37 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Here is some good reading on seafoam that should help.
    Seafoam
  6. Aug 20, 2013 at 6:54 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yes yes yes...did mine yesterday
  7. Aug 20, 2013 at 7:35 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Finally got the balls and did it the other day... runs much smoother at idle and throttle response is like a whole new truck!
  8. Aug 20, 2013 at 7:47 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  9. Aug 22, 2013 at 9:40 PM
    NWTacoma95
    Bellingham, WA
    3" suspension lift
    Thanks for all the feedback. Did it today. Put Seafoam in, ran it pretty hard for about 75 miles, then changed the oil. Boy it made a big difference! I put half a can in the crank case, half can induced through a vaccuum line, and another can into the gas tank. It let out a lot of smoke from the exhaust pipe for a while, but then the smoke completely went away and ran so smooth! I will do this again for sure!
  10. Aug 22, 2013 at 11:16 PM
    bellassaiw10
    Currituck NC
    Rear Cat finally kicked the bucket though haha
