Feeler: 1st Gen Parts Post SAS
Discussion in 'Arizona' started by 1999RegCab, Mar 15, 2016.
  1. Mar 15, 2016 at 7:08 PM
    1999RegCab
    1999RegCab [OP] Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Truck's at the shop for a SAS. Going with 1 tons, so all my current drivetrain parts need to find a new home.
    This is a feeler thread to see's if there's any interest in the parts.
    Parts parts are still in the truck :)
    Front Coilovers: $600
    - ICON Vehicle Dynamics (IVD) Coilovers. Have about 22,000 miles on them. Holy grail of Coilovers for the 1st Gen Tacomas IMHO. I've tried/sold pretty much every coilover brand out there and these are by far the best ones (King are my second favorite). The valving is just PERFECT for these trucks. Have some surface rust as they went through a couple of winters before I relocated to AZ.
    F1E3B0BA-322A-4623-A5DB-03C10EA45189_zps_354e465bafcd3a23ac3f9a6a94020f9ffcbdd0c7.jpg
    4035E29A-CF3E-4471-AB1B-B2ADF3202E24_zps_b7908a2e1ccca87f7a53a829a5ce2f51db16f772.jpg
    68DB4EAE-2DFA-487C-9A0A-1C79E0D5023C_zps_7e531b1084b9592bb41d7eab588672da5b7714ac.jpg
    Wheels/Tires: $500.00
    -BFG KM2 33X10.50 15. These are the skinny "pizza cutter" ones that are easy on the ball joints and steering parts. Tires have about 25,000 miles, good wear, could easily put another 25,000 miles if used on a lightweight truck like mine. They are now starting to get a bit louder as the thread goes down. Have done a bunch of wheeling trips and these tires plain work. Smooth ride on the highway, great on the rocks. Could use a rebalance. I've been using these in my DD, but could be used as a trail set if you already have street tires.
    -Procomp 1069 Series 15X8 Aluminum wheels, 3.75 back spacing, 6 5.5 bolt pattern, originally polished but now painted black. They DO clear the calipers just fine. Have the typical stratches and dents you would expect from wheels used off road. The 3.75 back spacing pushes the tire about 2" outside of the wheel wells, so they clear the spindles just fine but without having the tires stick out too much. These are very lightweight and strong wheels but very strong. Make tires changes a bit easier :)
    BBB26B40-7B0F-4683-9BD4-9CE94F11880F_zps_fa5a6aac9dabded10e209f4b0e6eaa21e57aef90.jpg
    [side shot front/rear showing how far the wheels push the tires out. Not too bad]
    7AD8D0E1-8A3E-42F3-BC7E-3D352B1D2557_zps_2fa72b0f4be33c0ff473196b69f3cf65a00dc832.jpg
    Rear Springs: $350.00
    -AllPro 3" springs. LOTS of flex, best replacement leaf spring for the tacoma I ever tried. Same performance as Alcan/Deaver springs but cheaper. Comfortable ride both on/off road. NOTE: they give you a real 3" of lift. I have stock shackles and the truck is a bit ass high. If you have longer aftermarket shackles, you will end up with way too much lift in the rear.
    100959AE-8973-4478-8117-D81646800FFB_zps_898f832242d6d13a48003e41a1209ab36017854c.jpg
    26C3E258-C989-45AE-B052-FBE6EB8742A7_zps_447014c3d5b9adb2ae0db560a83b8d05a6e53277.jpg
    [this pic shows how much lift you'll get. Again, this is with stock shackles. That's a 33" tire, notice how much space there is between the top of the tire and the top of the wheel well. Could fit a bigger a 34" tire easily, maybe even a 35"]
    720E9527-920F-422F-A409-0010CC428C02_zps_6083043fad5644f90931b72b1198a9d1580974bc.jpg
    Rear Shocks: $80.00/pair
    -Bilstein 5100. They work for up to 3" of lift. Awesome shocks, they are a perfect match for the Allpro springs. They make for a very comfortable ride. Have surface rust as the went through a couple of winters in the Northeast before I relocated to AZ.
    BED06BED-0AD6-442D-9A63-8B9EE06174C8_zps_23d5592e40cd2a5ace1e0949a3dd3762f21a04d4.jpg
    0180EBDD-2AAB-4FD4-B24F-E3991D5D158E_zps_c7a994495a9afec3c1feb93a168b115ccb6e9cb4.jpg
    Front IFS Axle: $250.00
    Clamshell diff with 4.56 OE gears, Lockright Locker and new driver side oil seal.
    - Unknown miles, have manual locking hubs so the diff is spinning only when I go wheeling.
    OE AISIN Manual Locking Hubs: $150
    -Recently serviced, good to go for another 10 years lol.
    -These are way better than the Warn version, and are hard to find as not many 1st gen tacomas came with these from factory.
    Spindles for manual hubs: $200
    -If you want to get rid of your ADD diff set up, these is what you need!
    OE CV axles: $80
    -Both recently rebuilt with new boots, grease, etc.
    -These have stronger shafts than the crap they sell at autozone, and are hard to find at scrap yards as not very many 1st Gen tacomas came with these CVs.
    Brand new spare CV from NAPA: $60
    -Better than autozone, but not as good as OE. I would use these Napa ones any day before the ones from autozone.
    OE steering rack: $100
    -About 136,000 miles. Leaks a little, but it still works just fine. Great for a spare, though I daily drive it and wheel it frequently just fine.
    -One of the tie rods ends (forget which side) could use a replacement. Still holds an aligment but last time tech said it should be replaced in the upcoming future.
    Brand new poli bushing kit for steering rack: $20
    -New, never installed. It has the correct size bushings. Never installed it because I decided to do a SAS.
    Brand new poli bushing kit for sway bar: $20
    -New, never installed as I got rid off the sway bar. It includes new poly bump stops.
    B4CF78BF-B00A-4CFD-9F1C-D1934F73BF52_zps_9091bde20e6599c83b82b20a928c93b7c5796979.jpg
    Rear Axle: $500
    Non TRD 3rd member with Motive 4.56 gears and lockright locker. Diff has about 80,000 miles on it.
    -Comes with everything drum-to-drum (ebrake, new brake shoes, extended breather, extension bracket for the rear brakes, etc.)
    -Note: Lockright Locker was professionally installed by "ZUK" last year (gearinstalls.com). He inspected gears for tear/wear and bearing clearances, made adjustments as needed with new shims and brought everything back to better than factory specs; basically an an overhaul. Gears were in perfect shape. ZUK is an authority when it comes to gear set ups for Toyotas. He does gear set ups for people from all over the country and has an impecable track record.
    3rd Member Only: $325
    C9C90051-2741-4118-A731-DDE0DB63D63F_zps_a33bf74bce382221ce672206426b7ba65d8a91fa.jpg
    1A2A75C2-E970-449E-B311-DA69C4D4060A-125_ffba4fba1fc4ea4b33f5f8b19486bfaa285cba2e.jpg
    AD776CFD-764C-4DA3-980B-03D6C7E143A7-125_8511cf1bdfbddfff601d5c18aba70e7fc690983c.jpg
    8EB02C07-5AF4-4FD8-BD49-AB4B2DFEAB07-125_23c8b86ab165a3e60d26878f37039a80ed0dec38.jpg
    4A7BE7A4-0FA4-4168-9E06-24A493FBB46E-125_4263a092cd004ef1d999d3d4f8ecf34fa6efe896.jpg
    This is all I have for now. Let me know if you might be interested in some of these parts. I would much prefer to sell locally to avoid the hassle of shipping heavy stuff, but would consider shipping as well.
    Thanks.
  2. Mar 17, 2016 at 5:23 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    So what are you looking for price wize?
    Rim/tires
    Hubs/shafts?
    How do you think that the allpro's would hold up if you took a leaf out ?
    Good luck with the swap.
  3. Mar 17, 2016 at 5:30 PM
    RPS1030
    RPS1030 Well-Known Member
    Maybe thinking about the Rear Housing and Shafts?
  4. Mar 17, 2016 at 6:01 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    I think the Allpro's should hold up fine with a leaf out. They have a bunch of thin leafs forming the leaf pack (can't remember how many). If you have extended lift shackles and are concerned about getting too much lift, I might be able to include my OE shackles with the leaf packs to keep the 3" of lift the lift springs have.
    With or without the 3rd member? Need e-brake cable, brake lines and all the other crap?
    Sorry i have not posted prices yet. I will soon.
  5. Mar 17, 2016 at 9:35 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    need prices on axles, have the hubs already.
  6. Mar 23, 2016 at 11:58 AM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    *PRICES ADDED*
    Sorry about the delay. I was having issues posting messages and replying to PMs. The browser would crash on me each time I tried to reply. Using Google Chrome now and things seem to be working better.
    I'll be checking my PMs frequently.
    Thanks!
  7. Mar 30, 2016 at 6:02 AM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    weekly bump.
    all prices OBO. Make an offer.
  8. Mar 31, 2016 at 1:33 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Pm sent.
  9. Mar 31, 2016 at 1:37 PM
    ID4VID
    ID4VID Gooner for Life
    David
    San Francisco
    1999 Tacoma SR5 4X4 "Great White"
    2.5" ICONs & ICON rear shocks 2.0
    id take the wheel package if youre willing to ship
  10. Apr 1, 2016 at 9:43 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Replied to.
    Would consider palletizing the wheels/tires if you pay for shipping :)
  11. Apr 2, 2016 at 1:35 PM
    ID4VID
    David
    San Francisco
    Send me a pm with how much shipping would be to 94116, thanks!:hattip:
  12. Apr 2, 2016 at 2:33 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Will do.
    When the truck is at the shop for SAS I'll ask them to put the wheels/tires on a pallet and ship it from there since they ship stuff on pallets all the time.
    ID4VID likes this.
  13. Apr 3, 2016 at 5:09 PM
    AZ_Trails
    AZ_Trails New Member
    Tucson, AZ
    2000 Toyota 4Runner
    Definitely not stock.
  14. Apr 3, 2016 at 7:22 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    PM replied :)
  15. Apr 11, 2016 at 11:40 PM
    ID4VID
    David
    San Francisco
    any word yet on shipping? still interested if still have em
  16. Apr 13, 2016 at 9:21 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Still have them. There have been some delays with the start date of the build, so the tires are not available yet.
  17. Apr 14, 2016 at 11:22 PM
    ID4VID
    David
    San Francisco
    cool, just checking in :boink:
  18. Jun 5, 2016 at 9:05 AM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Bump.
    Truck's at the shop finally. If there's anything you want send me a pm.
  19. Jul 10, 2016 at 7:03 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
  20. Jul 11, 2016 at 2:30 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    I'm just now seeing this thread...
    @Toyboata road trip?
