FEELER: 2 inch thick 2.7 intake manifold spacer
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by tooter, Aug 31, 2013.
  1. Oct 4, 2013 at 7:59 AM
    #141
    tooter
    tooter [OP] play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Sure will, Hagen... :)
  2. Oct 4, 2013 at 12:57 PM
    #142
    MaxT
    MaxT MaxT
    St Marys, GA
    2022 Blue Crush TRD Sport MT
    Go Rhino Power Steps, MESO Puddle Pods, KDMAX Tune, Accumulator delete MOD, Mud Flaps, OEM Power Tailgate Lock, Hood Struts, Kicker Key Amp, New Speakers, New Shift Knob, OEM Bed Mat, MESO Total LED Taillights, LED 3RD Brake Light, Hitch 4TH Brake/Running/Backup Light, Scan Gauge III, Borla Cat-Back Exhaust, Jowett Oil Filter Cap, MESO Map and Dome Dual-Color Lights, Driver's Side Grab Handle Future: OEM LED Headlights, Peragon Bed Cover, Borla Exhaust Mid-Pipes
    I'm left off of this list but at the top of the list on the other posting. Please add me to this list also.
    Patiently waiting.
    Max
  3. Oct 5, 2013 at 3:02 PM
    #143
    tooter
    Greg
    Los Angeles
    You're good, Max. :thumbsup:
    The BUY LIST is the one we'll be actually working off of. That long list is just the people who are interested and have not decided to buy yet.
    And while you're patiently waiting I actually have the first production spacer and took some pics with it attached to the intake manifold. :)
    The nylon isn't a true black, and has a definite blue cast to it similar to how anodized aluminum can have. If you get it out into sunlight, it's definitely blue, but in regular ambient light it looks more blackish. Next to the intake manifold you can easily see the difference. For some reason, the camera doesn't seem to pick up the blueness, but it's there in real life. One advantage is that the spacer is all but buried under the fuel rail, bunches of wires, and hoses when it's installed on the engine.
    This one gives you a good idea of exactly how much longer the spacer makes the curled runners. It's also an additional advantage in that the longer section is perfectly straight just before the air enters the head.
    Bobber Bill likes this.
  4. Oct 6, 2013 at 8:21 AM
    #144
    highaltitude
    highaltitude Well-Known Member
    Asheville, NC
    2017 ZR2
    What kind of heat can the "nylon" withstand? These are not phenolic material correct? No melting issues or warping? The part looks very nicely done in fit and finish! Good job.
  5. Oct 6, 2013 at 8:33 AM
    #145
    tooter
    Greg
    Los Angeles
    Thanks. It's exactly the same material as the stock intake manifold. :)
  6. Oct 6, 2013 at 8:59 AM
    #146
    highaltitude
    Asheville, NC
    2017 ZR2
    Nice, I had thought about phenolic when I was making mine, but none of the cnc shops want to cut it. They said it is really tough on equipment. Did you just decide to go that thick? Was wondering why its so big?
  7. Oct 6, 2013 at 10:04 AM
    #147
    tooter
    Greg
    Los Angeles
    I made a two inch spacer because that's the maximum allowable thickness that the 2.7 has the space to accept without causing major problems.
    And even at that thickness, it still had a minimal effect of lowering the torque peak by only 250 rpm and fattening up the curve in a few spots, so anything thinner would have even less of an effect. I would have liked to have gone even thicker but everything has its practical limits.
    The results are ok for just for a simple inert bolt on accessory, so I'm satisfied with that. :)
    Greg
  8. Oct 17, 2013 at 1:51 PM
    #148
    tooter
    Greg
    Los Angeles
    Here's the first batch in the process of being machined... :)
    I pick them up this coming Tuesday the 22nd. :thumbsup:
    Greg
  9. Oct 17, 2013 at 10:31 PM
    #149
    tooter
    Greg
    Los Angeles
  10. Oct 23, 2013 at 9:04 AM
    #150
    tooter
    Greg
    Los Angeles
    The first run of tooters is done... :)
    ...and I'll be picking them up today or tomorrow depending on how work goes.
    Greg
  11. Oct 23, 2013 at 1:53 PM
    #151
    MaxT
    MaxT MaxT
    St Marys, GA
    So when can we begin to process payments ?
    Max
  12. Oct 23, 2013 at 2:05 PM
    #152
    05taco2.7
    05taco2.7 Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
    Tooter FTW
  13. Oct 23, 2013 at 2:52 PM
    #153
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Hell, you should just keep one just to look at it. Them things are nice and purdy
  14. Oct 23, 2013 at 3:36 PM
    #154
    tooter
    Greg
    Los Angeles
    Right now I have six to look at... ;)
  15. Oct 23, 2013 at 4:10 PM
    #155
    tooter
    Greg
    Los Angeles
    Hey Max, :)
    Just now started a FOR SALE thread in this section with all of the info.
    Greg
  16. Aug 23, 2015 at 9:26 AM
    #156
    iniazy
    iniazy Active Member
    Ibrahim
    Dhahran, Saudi Arabia
    Toyota Fortuner SR5 1GR-FE V6
    Air-locker front, 72 Liter auxiliary fuel tank, ARB bumper, Warn Winch, OME 2.5" Lift, Rear tire carrier, Safari snorkel, Front Runner roof rack
    Hi Tooter, I'm fascinated with your work.
    This post caught my attention. I have a supercharged 2TR truck and I am in the process of adding a fifth injector to get enough fuel to the engine after 5000 RPM. There is an additional injector kit at URD, which is made for the 1GR engine. If the 1GR valve body has the same bolt pattern as the 2TR, I can use it for my fifth injector. Looking at this picture, is this the 2TR vs 1GR throttle body, or is it the Corolla vs Yaris one? My guess is it is the Corolla vs Yaris. So do you know if the 1GR has the same bolt pattern as the 2TR?
    Thanks,
    Ibrahim
  17. Aug 25, 2015 at 6:27 AM
    #157
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    This is so awesome!
    This is exactly what the car/truck/motorcycle communities need, thoughtfully designed and executed parts made by forward-thinking people with real know-how!
    Any d-bag can copy a drawing, extrude it and have it cut out of aluminum. LOL
    I remember talking to you about this when you were first developing the idea/design. I'm super stoked on your material choice, gaskets, thickness and pocketed design! Just awesome!
  18. Aug 25, 2015 at 7:46 AM
    #158
    Sone Taco
    Sone Taco Tacoma rules!!!
    Sone
    Rochester, NY
    2017 Barcelona red TRD OFF ROAD DCSB, 2005 Red AC 2.7 MT 190k mil, 1995 Maroon Reg cab 2.7 MT w/ 360k
    slowly but surely...
    Please add me to the list and let me know when to send $$?
  19. Aug 25, 2015 at 10:53 AM
    #159
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    Ya what became of this it looks like a 10 month gap. Is there a new thread.. I wanted to see the other buyers response before I consider. One.
  20. Mar 7, 2016 at 5:37 PM
    #160
    tooter
    Greg
    Los Angeles
    I hope you haven't been holding your breath or you'd have been a skull by now. ;)
    Sorry, I haven't been around here in a long time as I've been working on other projects.
    Greg
