Feeler* 6" BDS w Fox coilovers and shocks
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by BohlaaH, Jan 30, 2016.
  1. Feb 28, 2017 at 7:02 PM
    BohlaaH
    BohlaaH [OP] Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Would be much more than just shocks, crossmember, skid plate, brake lines, lift blocks; she's a heavy beach
  2. Feb 28, 2017 at 7:21 PM
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    I only need the front coilovers
  3. Feb 28, 2017 at 7:31 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    I'll let you know as it happens
  4. Feb 28, 2017 at 8:14 PM
    4DR4x4
    4DR4x4 Re-Blued....fresh clear
    Ocala, Fl
    06 4DR 4x4
    I want the whole kit. U pull off the DB kit and let's make a sweet deal-
    BohlaaH[QUOTED][OP] likes this.
  5. Feb 28, 2017 at 8:24 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Ten four! I have light racing UCAs I'll be selling with the kit as well. Just trying to save some Moolah up right now. My original price will probably go up a little woth those added. I'm hoping for June - august to have the kit removed and up on the marketplace formally!
  6. Mar 1, 2017 at 7:47 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Is BDS 6'' kit bolt on? I Thought you had to cu / weld all drop bracket lifts? Are you just going to have the bracket cut out?
  7. Mar 1, 2017 at 12:12 PM
    4DR4x4
    Ocala, Fl
    06 4DR 4x4
    Nah, it's direct bolt in. Only piece to weld in is the turn radius bump stops I belive. u'll do more work w ratchets than a weld rod.... :rofl:
    excorcist[QUOTED] likes this.
  8. Mar 1, 2017 at 3:35 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Yeah I'm gonna have to get creative for th crossmember, I'm absolutely replacing the piece that was cut out (makes room for the driveshaft on 4x4 models) and those turn stops I never welded on, nor are they necessary. It's for rubbing with the larger tires I'm pretty sure. Either way they aren't needed.
  9. Mar 8, 2017 at 5:16 PM
    4DR4x4
    Ocala, Fl
    06 4DR 4x4
    I found a thread here about a 1st gen dude who reversed his DB lift. He got a complete front frame crossmember from a junked truck that was cut out along the frame seam weld and spliced it back into his own frame. Joker was some kinda welder cause when he was done it looked factory! Shizzle was tight yo! Lol anywayz maybe u have to go the same route? Or did ur lift get installed with a small channel notch in the crossmember instead? I seen that trick too- just enough crossmember gets cut out to make room for the front drive shaft and it looks like maybe 4" deep x 4-6" wide??? Fella that did that one was on a 2nd gen w a rough country db 6" kit. He also did a fab job of boxing in his custom notch w plate and looked dam factory when he was done- if I can find the threads again I'll try and copy em here for ha
  10. Mar 8, 2017 at 5:24 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    It was cut to make just enough room. There is a scrap 2014 in town I was going to steal the crossmember from. I have almost everything in place for when I do this. The reverse install might take a day or 2 but it's gonna be interesting!
  11. Mar 8, 2017 at 5:28 PM
    4DR4x4
    Ocala, Fl
    06 4DR 4x4
  12. Mar 8, 2017 at 6:02 PM
    4DR4x4
    Ocala, Fl
    06 4DR 4x4
    Shit , spent 30 mins tryin to find that reversal link to the first gen, tellin ya it was slick when done. Simple bolt on stock parts after that for the guy. If you had a way to put your truck down long enuff to sell me the goodies and let me get it installed here I would ship you my crossmember at my cost but I see ya got one already.... lol
  13. Mar 8, 2017 at 6:03 PM
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Would have also been an option. She's my daily tho so that would be hard for me
  14. Mar 8, 2017 at 8:47 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
  15. Mar 8, 2017 at 11:05 PM
    #35
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    I'll put some up of what I can find. I'll wash my truck and put some up for you guys
  16. Mar 8, 2017 at 11:08 PM
    #36
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Here's what it looks like for height. I'll take more pics specific to the kit. Such as shocks and hardware.
  17. Mar 8, 2017 at 11:10 PM
    #37
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Also, see my media page and build thread for more info.
  18. Mar 9, 2017 at 3:20 AM
    #38
    4DR4x4
    Ocala, Fl
    06 4DR 4x4
    :drool: :popcorn:
  19. Mar 10, 2017 at 8:28 AM
    #39
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    He's selling this kit to go supercharger like myself. He likes the lower with meaty tires vs the hillbilly brotruck stance lol
  20. Mar 10, 2017 at 10:19 AM
    #40
    BohlaaH
    ALEX
    2015 TRD Sport DCLB
    Go home Cale
