FEELER: BIG 3 and Winch kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by manethon, Oct 31, 2013.
  1. Dec 13, 2013 at 1:13 PM
    #41
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    big 3 upgrade available for a first gen v6??
  2. Dec 13, 2013 at 1:18 PM
    #42
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Can be available for any truck or car.
    IF custom lengths are required we just need to know how long you want them to be( price subject to change in longer lengths)
    im just sorting out the logictics of it all, once i have it all figured out ill post price, and all the relative details.
    STay tuned.
    Could a mod move this thread to group buy as i feel the second gen market place is limiting the exposure and people with first gens/ tunda/ 4runners etc are missing out.
  3. Dec 13, 2013 at 10:36 PM
    #43
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    I'm interested in this one as I was planning on just buying everything locally and doing it all myself but if the price is decent I'm in, as long as you can ship to Canada. I also need to relocate my winch solenoid in under the hood.
  4. Dec 13, 2013 at 11:00 PM
    #44
    skygear
    skygear                    
    If you do it yourself. Some great info for the masses.
    1. Crimper. I purchased my own and should run around $100 to your front door. Or go to you local marine/boat hardware store and they are good about letting you use there's in store.
    2. Soldier the end one crimped. Why? You ask. This is for a couple reasons. Helps better prevent corrosion in the wire and connection. Also helps for a stronger more solid connection.
    3. Heart shrink tubing. Helps with the determination of which wire you are dealing with. More importantly, helps better protect against corrosion.
    4. Wire wrap. Not a necessity, but helps with the insulating value of the cable, provides an extra layer of protection from abrasion and heat. If you want the cool factor, you can get sleeves in various colors ether in the split loom or the actual sleeves.
  5. Dec 13, 2013 at 11:06 PM
    #45
    skygear
    skygear                    
  6. Dec 14, 2013 at 4:40 AM
    #46
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Put me on the list for the big 3 with winch!
  7. Dec 14, 2013 at 9:02 PM
    #47
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    What you state is true to a point ,
    The wire that they have released has the outdoor elements in mind.
    IF the wire is trimmed at the proper location with respect to the terminal lug and terminated correctly with a shrink tubing over it there wouldnt be a need for soldering. The wire has a tin coating around the outside to reduce corrosion from elemental factors. The uber series has additional properties that benefit off road applications.
    Not going to get into a debate about it but this wire is specifically released with outdoor element applications in mind.
  8. Dec 16, 2013 at 5:34 PM
    #48
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    got some good news, i got prices and full descriptions available for you guys
    ill post them up tonight
  9. Dec 16, 2013 at 8:45 PM
    #49
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    ALL Kits will use the Uber series wire,
    -The Uber Series Cables Utilizes a unique CCA strand that has a higher Copper content than their audio renowned Reference Pro strand.
    -Uber Series Cables have Tinned Coated strands for protection as this cable is meant to be used in all applications regardless of elements
    -Uber Series cables are light weight, high conductivity, weather resistant and Amazingly flexible.
    Uber Big 3Kit : $59.99
    5ft green power cable,4900 strands,
    10ft clear ground cable,4900 strands,
    1/0 awg ANL fuse holder + 2pcs fuse
    1/0 awg lugs ( 5 red and 5 black), gold plated
    20 Cable ties, black color
    -Addition of winch cables + 4 lugs : Add $39
    Winch cables alone: $45
    Uber Battery Relocation Kit $89.99
    20ft green power cable 4900 strands
    3ft clear ground cable,4900 strands,
    20 Cable ties,
    It has been confirmed that each kit fits in a flat rate box for shipping.
    The aforementioned prices are before shipping
  10. Dec 16, 2013 at 9:09 PM
    #50
    4x4Taco09
    Dane
    Louisiana
    Ill be looking to get the Big 3 +winch
  11. Dec 16, 2013 at 9:39 PM
    #51
    BradyT88
    BradyT88 Well-Known Member
    So what exactly is the plan with the big 3 kit? 5 ft of green wire for the pos. alt to pos. batt and 5 ft of clear for neg alt to neg bat and 5 ft of clear for neg bat to frame or body? I haven't actually looked at the wiring up the hood.
  12. Dec 16, 2013 at 9:50 PM
    #52
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Why CCA wire and not OFC ?
  13. Dec 16, 2013 at 10:07 PM
    #53
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    IN!
  14. Dec 16, 2013 at 10:08 PM
    #54
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    OFC is not needed,
    The cable does have a large % of Copper in it,
    And is rated well over 265amps over 20feet length.
    If you were building a street A/B/C car and limited to the amount of runs you can make id say sure and id try justify the massive increase in cost if there was any noticeable gains.
    My fellow Audio competitors have ran multiple and multiple tests and saw no real significant gains between OFC and CCA and these guys Chase after every single .10 Db. Alan Dante has the loudest SPL Vehicle in the world and he uses CCA..... for what its worth.
    The above statement is that of my opinion and experience in the industry as a competitor
    This is what the kit offers,
    If there are other requests like added lengths, extra lugs etc please let me know and ill see what i can do
  15. Dec 16, 2013 at 11:09 PM
    #55
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    in for the uber big3 kit!
  16. Dec 17, 2013 at 1:02 AM
    #56
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Does anyone have any ties or links with other web sites to help spread the exposure of this group buy? I want to stress that this not only for 2nd gen tacos but should work for all makes.
  17. Dec 18, 2013 at 7:45 PM
    #57
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Post on the tw Facebook page too. Ill ask around too I'll need these soon
  18. Dec 19, 2013 at 8:37 AM
    #58
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    i guess i can post on the facebook page as well good thinking
    Thanks mate
  19. Dec 19, 2013 at 9:10 AM
    #59
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    how long will this offer be available?
  20. Dec 19, 2013 at 12:51 PM
    #60
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    well we are prepping for the GB, so there is still quite a bit of time.
    id like to spread the word as much as i can to say thanks to the guys for helping us out
