GMF Bolt on Rear Shock Relocate for 2nd/3rd Gen, back in production
Discussion in 'Automotive Group Buys' started by Arcticelf, Oct 22, 2020.
  1. Oct 22, 2020 at 10:28 AM
    Arcticelf
    Arcticelf [OP] Well-Known Member
    Gladiator
    I'm selling bolt-on rear-shock relocate for the 2nd and 3rd gen trucks. Price is $325 and includes lower 48 shipping.
    Also available: bolt on axle tabs with hardware. $70, shipped lower 48.
    DM me for shipping to AK or HI.
    In active production, hit me up for a set.
    You'd get a complete hardware kit, bolt on shock relocate and bolt on axle tabs.
    You'd need to supply a 12" King, Fox or other shock. Part Numbers: King: PR2012-SS Fox: 980-02-045. Installation requires cutting off the OEM shock mounts and axle tabs. Then drilling the frame for the hoops.
    Picture of the kit below.
    Installed pictures from @Subway4X4
    Axle Tabs. Measure from the outside edge of your leaf pack or ubolt plate and put the inside tab far enough that the shock body won't hit the leafs at full stuff or the frame at full droop. 1/2" should be enough for a 2" shock, 3/4" for a 2.5" shock. Also make sure you have room for the bolt/nut.
    5EECE659-377A-45A5-9303-B82447C09F72.jpg Shock hoop bolted in. The white stuff on the frame is anti-seize because salted roads suckD71158C6-A1AC-4DB2-B880-0CDE32710FB8.jpg
    Measuring for travel before locking in the tabs. 452E7561-96BC-4441-BB23-D677B4578406.jpg
    Measure the distance from the bottom of your bump stop to the bottom of the frame. Then set the shock with that much shaft showing, and adjust the axle tabs so they line up there. If the shocks are pressurized already you'll have to measure up from the bottom.of the shock, since they will keep expanding on you.
  2. Oct 22, 2020 at 11:37 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    :spy:
  3. Oct 22, 2020 at 12:00 PM
    Arcticelf
    Gladiator
    Round ONE: - all shipped
    65skyturbo - tabs only - Fully Paid
    crashngiggles- tabs only - fully paid
    jamlee - full kit - Fully Paid
    Iluvasiangurls - full kit - fully paid
    rheath08 - full kit - Fully Paid
    @Masshole_And_His_Taco - fully paid
    @Dex__43 - fully paid.
    ROUND TWO:
    CountryTaco - PAID - shipped
    SUMOTNK - PAID - shipped
    Brian422 - extra high clearance. - paid - shipped
    WrecklessAbandon - shipped
    ROUND THREE:
    @Millsy - axle tabs only - PAID. - shipped
    @Poke_squid PAID - Shipped
    @Jayden03d - bare metal
    @T.Barn - PAID. -. Shipped
    @widowmaker_13 - paid --axle tabs only. -- shipped
    @aappss01 - PAID. -shipped.
    TwistedTLM4 likes this.
  4. Oct 22, 2020 at 12:00 PM
    Arcticelf
    Gladiator
    The hardware kit. Top row is for the hoops, bottom row is for the axle tabs. The 1.5"x1/2 bolts attach the hoops to the frame, washers go inside the frame. The 3"x1/2 bolts in both kits are for the shocks. The 3.5"x1/2 bolts granger sent me by mistake, so you can use them or keep them.
    The 5/16 bolts are for the axle tabs, these will fit TIGHT on the tube, and may need some persuasion with a hammer to get settled. Make sure to measure off the leaf pack for your shock diameter so the shock doesn't crash into the leafs on full compression. IMG_20201210_151236758_HDR.jpg
    Shock hoops, top front is towards us, note the bolt for the shock goes from inside to out, and will need to be installed with the shock before these go on the truck.
    For weld on install you have to cut the bolt to exact length and install it the other way, or cut a hole in your bed to get the bolt out...
    IMG_20201210_150640716.jpg Outside view, front is towards the bottom of the picture, top is to the right.
  5. Oct 22, 2020 at 12:01 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Depends on install
  6. Oct 22, 2020 at 12:05 PM
    Arcticelf
    Gladiator
    Install is an hour or two with a grinder to take off the old shock mounts from the frame and axle.
    Then drill 4 holes in the the frame.
    Then bolt everything on.
    uploadadventure likes this.
  7. Oct 22, 2020 at 12:37 PM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    How is the lower shock mount going to be a bolt on?
  8. Oct 22, 2020 at 12:40 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    With bolts...
    JK, I have no idea. I would assume some kind of mount going around the axle with support to some other component?
    fatfurious2 likes this.
  9. Oct 22, 2020 at 12:44 PM
    Arcticelf
    Gladiator
    That's the magic.
    I figured out how to make a clamp on bracket out of 1/4" DOM to hold the tabs on the axle using two 5/16" grade 8 bolts. They don't move.
    You can also order without the axle tabs, source a set from RuffStuff, and make it all weld on if you want. The point of this kit is to make 12" shocks a reality for people without access to a welder. It's a huge huge performance upgrade for the ride of your truck.
  10. Oct 22, 2020 at 12:46 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Any pics of this kit installed. Thanks
  11. Oct 22, 2020 at 12:51 PM
    CttAznRanger
    Brandon
    Boston, MA
    How much holding power does it have, and how much force have you tried applying to the mount to see if it actually moves?
    I would want to see someone stress test this for science.
    This
  12. Oct 22, 2020 at 12:55 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Subbd - i'm interested too. Just curious how all this will hold up to abuse.
    RobP62 and CttAznRanger like this.
  13. Oct 22, 2020 at 1:06 PM
    pngo121
    Phi
    Pittsburg, CA
    Definitely have my interest now!
  14. Oct 22, 2020 at 1:08 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    need pics of it installed to see how it works first
  15. Oct 23, 2020 at 3:50 AM
    Arcticelf
    Gladiator
    OP updated with installed pictures from @Subway4X4 . He hasn't wheeled it yet, but @TwistedTLM4 has been wheeling his set up hard with no issues.
    I'll put a jack under a set of those axle tabs when the next set comes off the CNC table. I expect it will be more that strong enough to lift the truck. That doesn't matter though, because the tabs only have to be stronger than the force required to compress the shock or control the spring on rebound.
    Another key point of this kit: we get the top of the shock higher in the wheel well, so the lower mounting tabs aren't hanging below the axle. This means better ground clearance and less chance of hitting a rock with your shock tabs.
  16. Oct 23, 2020 at 4:45 AM
    CttAznRanger
    Brandon
    Boston, MA
    What's the recommended torque rating on those axle tabs? Two ugga-dugga's? more?
    Bigdaddy4760 and TwistedTLM4 like this.
  17. Oct 23, 2020 at 5:03 AM
    Arcticelf
    Gladiator
    It's a 5/16 grade 8, so 25 ft/lb according to this: https://www.portlandbolt.com/technical/bolt-torque-chart/ And generating 4,700 pounds of clamping force.
    That's tight with a 3/8 drive ratchet and box wrench.
    What keeps the tabs in place is the friction of 2 count, 1/2" wide pieces of DOM wrapped around the axle. It's hard to move them without a hammer when the bolts are finger tight, never mind torqued down.
  18. Oct 23, 2020 at 5:08 AM
    CttAznRanger
    Brandon
    Boston, MA
    Ah, then I definitely went overboard using 12 1/2" bolts to hold on my awning...
  19. Oct 23, 2020 at 5:10 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thats a pretty cool idea.
    12TRDTacoma likes this.
  20. Oct 23, 2020 at 6:05 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I'm interested.
    Potentially less chance of injuring myself this way.
