Feeler: Fishing Rod Holder
Discussion in 'Group Buys' started by C O R E, Apr 8, 2013.
Thread Status:
Not open for further replies.
  1. Apr 8, 2013 at 5:31 AM
    C O R E
    C O R E [OP] Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
    TW, I'm considering making "kits" of these where I ship a box with all of the pre-cut parts and fittings and a can of PVC cement with instructions but have no clue if there would be a market and how much I could sell them for. I know what I have to get to make it worth it can I get some feedback on how much you think these could go for and if you may be interested? Thanks! I hope I'm not breaking any rules posting this feeler...
  2. Apr 8, 2013 at 9:30 AM
    C O R E
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    I'm thinking for a 10-rod holder like the one pictured should be in the +/- $90-100$ range for a kit... alot of the expense is tied up in the rod sleeves.
    $50 for the frame, and 5$ each for the holders
    Does that sound reasonable?
  3. Apr 8, 2013 at 9:40 AM
    Dantwenty2
    Dantwenty2 Well-Known Member
    Saugus, CA
    2009 TRD OFF-ROAD DCSB
    Fox 2.0 coilovers, yellow fogs, Peltyfry bed light bar with Rigid Duallys.
    Why not just make the sleeves out of PVC? I did that when I built the rack for my tube and it works well. Would drastically reduce the price.
  4. Apr 8, 2013 at 9:46 AM
    C O R E
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Thanks for the tip I thought about this and you're right except I'm sold on how the sleeves are flared on the end and I doubt I could do that to the PVC without deforming it. The flared end is not only for looks, but I imagine that it is a bit more friendly to your equipment. Then again, I also thought about putting door edge trim around 1 end or something soft to avoid having to flare it. I may end up goin that route.
    That would knock the price down to probably the 60$ neighborhood.
  5. Apr 8, 2013 at 10:05 AM
    wareagle1
    wareagle1 Well-Known Member
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
    That looks great OP. Could you possibly make a 3 rod that would mount onto the rail system? I kayak quite a bit and the nose of my yak sits all the way against the cab.
  6. Apr 8, 2013 at 10:14 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    The rod sleeves are easy to make. Heat a peace if PVC pipe with a heat gun then shove a wine bottle in to it. I just made a few for my kayak. It took less then 10 minuets to make. Rod holders are pretty easy to make so I'm not sure if its worth the trouble.
  7. Apr 8, 2013 at 10:25 AM
    C O R E
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Yea that's kinda why this is a feeler..
    Doesn't using the heat gun to heat the PVC to flare it cause it to discolor though? that's what I'm afraid of... but it's not that big of a deal I guess if they get painted.
  8. Apr 8, 2013 at 10:30 AM
    raskal311
    S. Cal
    Not sure i used black abs. Ill give it a shot when I get home and ill let you know. Buy I think if you don't over heat it it should not discolor. You only need to soften it a bit to make it flange.
  9. Apr 8, 2013 at 10:39 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Is this for transport, or beach fishing, or both? Either way pretty good idea!
  10. Apr 8, 2013 at 10:50 AM
    wheelerkr2
    wheelerkr2 Well-Known Member
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    Try something like this, made it a couple weeks ago out of a piece of wood and pvc pipes. Its mounted to the rail system by bolts and I cut out a part on the pac for the reel to sit in.
    ghettofunnel likes this.
  11. Apr 8, 2013 at 11:03 AM
    wareagle1
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
    Thanks man! That's exactly what I was looking for.
  12. Apr 8, 2013 at 11:06 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Brilliant. I'm stealing this idea :D
  13. Apr 8, 2013 at 11:15 AM
    wheelerkr2
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    No problem! quick tip: to cut out the part for the reel we just clamped the pipe to the work bench and used a hand held power saw then sanded down the edges a bit. PM for any questions on it!
  14. Apr 8, 2013 at 1:35 PM
    TACO TX
    Kelly
    Denison ,Texas
  15. Apr 8, 2013 at 2:18 PM
    wheelerkr2
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    My bad haha, OP's setup is sick for more serious applications and for people with lots of gear!
  16. Apr 8, 2013 at 5:51 PM
    Captain Stabbin
    Captain Stabbin Well-Known Member
    Justin
    SOMD
    2010 DCSB
    I bounce it offa stuff.
    That's a pretty sick setup. Does it need to be secured in the bed or does it just sit in there?
  17. Apr 9, 2013 at 5:21 AM
    C O R E
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Sits between the wheel wells and doesnt move side-to-side, and can be ratchet strapped to the front cargo loops in the bed to keep it from moving forward or back.
    The idea is that it's easily removable instead of being bolted in.
  18. Apr 9, 2013 at 5:29 AM
    TacomaBuilder67
    TacomaBuilder67 Well-Known Member
    San Antonio,TX
    '12 PreRunner DCSB V6 TRD Sport MGM
    Bull Bar, KC Apollo Lights, LED interior lights, TRD Center Caps,Tailgate Anti Theft Mod,TRD Shorty antenna,
    That's an awesome set up Clint. I would be down for one of those. By the way, we need to have another San Antonio get together.
  19. Apr 9, 2013 at 10:40 AM
    C O R E
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Yea man throw something in the SA Monthly Meet thread see if anyone else is down. Going to plumb in on-board air to my cousin's 98 taco this saturday probably to operate his airbag spring helpers.
  20. Apr 17, 2013 at 7:18 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    Sub’d. :popcorn:
Thread Status:
