Feeler For 2nd Gen Roof Rack
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by zscott, Jan 21, 2014.
Thread Status:
Not open for further replies.
  1. Jan 22, 2014 at 1:07 PM
    #41
    swimmerdude1127
    swimmerdude1127 Active Member
    Oh how I wish I could put something like this on my Access Cab...
  2. Jan 22, 2014 at 1:10 PM
    #42
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Pick up the soap....
  3. Jan 22, 2014 at 1:39 PM
    #43
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Originally I posted to get a "feeling" of wether or not there would be enough interest in these racks to make it worthwhile. Thus, a feeler. I don't know how to change the title of the thread now so I guess it will stay unless a Mod can change it.
  4. Jan 22, 2014 at 2:17 PM
    #44
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well sweet, let me know where to send monies and I'll hit you up next week :)
  5. Jan 22, 2014 at 3:04 PM
    #45
    pjskinner
    pjskinner Active Member
    This may not be a question you are able to answer, but what would you suggest the weight rating for it would be? BTW, this is exactly what I want. I need to figure out of I am going to do the DIY kit or one already assembled. Thanks!
  6. Jan 22, 2014 at 3:11 PM
    #46
    zscott
    Zach
    Utah
    The steel version that I have is strong. I can stand on one (I am about 160lbs) cross bar and there is next to no defection. Spread that across 6 cross bars and you have a pretty high capacity. The rack is mounted to all ten mounting points on the roof so the weight is distributed well there also. I would think that the actual roof of the truck where the rack mounts would fail before the rack itself would.
    I can't give an exact number but I would consider the capacity equal to the other commercial brands such as front runner and bajarack. I personally can't think of anything I would want to carry up there that the rack wouldn't be able to handle.
  7. Jan 22, 2014 at 3:14 PM
    #47
    VolcomTacoma
    Jeff
    NorCal
    Question, how much room is there at the end of the front of the side rails and your front most cross bar? Wondering if I won't need to extend the front rails, just weld all the crossbars a hair closer together to give myself more space up front for a LED Bar...
  8. Jan 22, 2014 at 3:15 PM
    #48
    pjskinner
    Sweet, I'm thinking A roof top tent for my daughter and I. She's 8 years old and I'm 150 pounds wet. It should hold.
  9. Jan 22, 2014 at 3:18 PM
    #49
    zscott
    Zach
    Utah
    Sounds like this is a common theme. If the access cabs had mounting points like the double cab it would be easily done.
  10. Jan 22, 2014 at 3:19 PM
    #50
    zscott
    Zach
    Utah
    Let me get some pics with the tape measure so you can see.
  11. Jan 22, 2014 at 3:25 PM
    #51
    zscott
    Zach
    Utah
    I wouldn't hesitate to put a RTT up there. Although I don't know how the wind noise would be on a tent. I have seen guys with it set up that way on here though.
  12. Jan 22, 2014 at 3:28 PM
    #52
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    just make it shorter for us access cab guys. most of us are so desperate well drill holes without a second thought
  13. Jan 22, 2014 at 3:42 PM
    #53
    pjskinner
    C'mon, we don't drive Tacomas because we care about noises. Between my aerobar set up and the BFG's, I can barely hear the radio at 40!
  14. Jan 22, 2014 at 4:32 PM
    #54
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I'd be in for for a DIY kit
  15. Jan 22, 2014 at 4:35 PM
    #55
    I8AJEEP
    I8AJEEP Dynamite Design Josh
    Josh
    Lexington NC
    05 DC TRD SAS
    SAS, with tons, 3linked front and rear…I stopped saving receipts for my sanity
    are these in production yet? I want a set of side plates
  16. Jan 22, 2014 at 4:45 PM
    #56
    S Rod
    S Rod Well-Known Member
    Scott
    Virginia Beach
    2010 DCAB SB Storm Trooper
    3" Suspension Lift "Old Man Emu" with Bilstien 5100's, Dash CAM (1080p w/IR's), Rear View Mirror Re-locator, Color Matched LEER 180 Shell, Piaa 520 Lights on LineX-ed Push Bar, LineX-ed Side Step Bars, Blacked out Back Bumper, iPad mount, Relentless Front Plate Bumper.....
    I have a LEER 180 Topper that has a 3" to 4" hight difference. Have you considered higher side members?
  17. Jan 22, 2014 at 4:46 PM
    #57
    VolcomTacoma
    Jeff
    NorCal
    Haha custom kits :). I asked for shorter rails so it will be flusher to the roof :)
  18. Jan 22, 2014 at 4:47 PM
    #58
    zscott
    Zach
    Utah
    I am going to start a list in the OP of those who are interested. Once I get payment, I will change the color of your name and start getting them put together to get shipped out. Turn around time is pretty quick but I would like to do these as batches mainly for ease and to possibly cut down costs and give you guys some savings if possible.
  19. Jan 22, 2014 at 4:48 PM
    #59
    zscott
    Zach
    Utah
  20. Jan 22, 2014 at 4:52 PM
    #60
    VolcomTacoma
    Jeff
    NorCal
    Wow it's bigger than I thought! I'm definitely in for what we spoke about. Just rails with shorter mounts and all mount hardware.
Thread Status:
