Feeler/Interest gauge for 12-15 blackout interior parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cativelense, Sep 8, 2016.
  1. Mar 24, 2017 at 12:11 PM
    #1061
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Do any of you have a self pull it junkyard nearby? My friend has stuffed a Land Rover V8 into a 1975 TVR 2500M and he gathered all of the wiring harness from the donor Defender II in case he needed it. He finished the wiring portion and gave me the old harness. I spent some time sifting through it and bought a set of depinning tools from Amazon and had some fun polishing up my depinning skills. Now I have a five gallon bucket of a whole bunch of automotive wires in various colors, some connectors and lots of pins. Some time in any junkyard Toyota will probably yield a ton of wiring that you can use for numerous projects. Just a suggestion.
  2. Mar 24, 2017 at 12:13 PM
    #1062
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Yeah the ones I sourced have a little fin on top that you can just bend off.
    No idea how the ones they were using compare besides lack of the fin on top. I didn't really compare the dimensions.
    Edit: the ones they were using also have a nub that sticks up just at glance on the CAD drawing specs
  3. Mar 24, 2017 at 12:19 PM
    #1063
    JdevTac
    Josh
    MD/GA
    2nd gen
    Local pick n pull hardly has anything Toyota. Mostly a bunch of domestic junk.
    It's fine tho, cause I already have a crimper. Sourcing the correct pins by dimensions can be annoying but it saves a shitload of cash for high volume.
    If I had to do it again I probably would do the junkyard harness grab and depinning deal.
  4. Mar 24, 2017 at 12:28 PM
    #1064
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    ah you are right. I just noticed that. I may just get both and see what works. Technically I may need some that work in my HVAC area which do look similar to these.
    I was thinking about that. After time and travel it ends up being more effort.
  5. Mar 24, 2017 at 12:35 PM
    #1065
    nudavinci64
    Robert
  6. Mar 24, 2017 at 1:13 PM
    #1066
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    Maybe I'm in for headaches down the road, but I didn't use a crimper, just a smalllllll set of pliers to fold the tabs over on top of the wire and insulation.
  7. Mar 24, 2017 at 1:23 PM
    #1067
    nudavinci64
    Robert
    If its held on tight, I am sure it will work just fine. Crimper is the ideal. Prob goes $$$ crimper, Generic crimper, whatever you can use to fold it.
    If it was on pretty good, I would think it will be ok.
  8. Mar 24, 2017 at 1:24 PM
    #1068
    nudavinci64
    Robert
    I just ordered 5 or 6 different .64 connectors from Mouser. I figure one will be right and for the price I will have a ton extra and was still cheaper than one OEM wire. If I find a better one than what has been noted, I will post it up.
    Cativelense[OP] likes this.
  9. Mar 24, 2017 at 3:18 PM
    #1069
    JdevTac
    Josh
    MD/GA
    2nd gen
    It'll be fine, just not as secure as a good crimp. I actually use pliers sometimes to do the old fold over method if I don't have a crimper that fits. What I do after is solder the connection to provide further security, though solder isn't Meant to be an adhesive it at least ensures a good connection.
    wsurunner[QUOTED] likes this.
  10. Mar 25, 2017 at 3:48 AM
    #1070
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    Is there anyone with a 2014 or 2015 that has swapped to black steering wheel controls, willing to part with their stock silver pieces?
    Nuno, do you still have your stock steering wheel controls? I may need to buy a set.
  11. Mar 25, 2017 at 5:41 AM
    #1071
    Cativelense
    Cativelense [OP] Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Sorry man, sold them a long time ago. Try posting one of those WTB threads if you need one. You never know what's out there.
  12. Mar 25, 2017 at 5:53 AM
    #1072
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    Will do, thanks!
  13. Mar 25, 2017 at 5:54 AM
    #1073
    Cativelense
    Nuno
    CT
    No need to thank man. We're all here to help! Really hope you can find one if you need it.
  14. Mar 25, 2017 at 5:02 PM
    #1074
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Mine are available...
  15. Apr 26, 2017 at 10:03 AM
    #1075
    tacomized730
    tacomized730 Member
    lancaster,ca
    07 Tacoma 4x4
    satoshi grill with hella's inside, TRD CAI
    Does anyone know if this parts will fit an 07?
  16. Apr 26, 2017 at 10:09 AM
    #1076
    ChadsPride
    Sponsored by TacomaWorld.com
    Been putting off painting my gauge cluster rings and tweeter rings for too dang long....
    :annoyed::annoyed::annoyed::annoyed:
    rmepilot and nudavinci64 like this.
  17. Apr 26, 2017 at 11:22 AM
    #1077
    nudavinci64
    Robert
    I need to do that as well. Need to find the right color to use. Some black of course.
    Also need to wire the steering wheel ground for it to light up and figure out why the hell my Helux switch wont light up and my HVAC is dim.
    ChadsPride[QUOTED] likes this.
  18. May 8, 2017 at 12:30 PM
    #1078
    nudavinci64
    Robert
    Maybe someone here will have an idea. I posted up in another thread on this.
    This is for getting a 2013 to work with the new controls.
    I pinned the S8 connector and used pin 9 as noted by many folks. The controls are still not lighting up. Ill update later directly if I can. Tore the shit out of my truck to get this to work and irritated as hell. Had issues with Helux switching not lighting up and ongoing issue of the HVAC panel not lighting up bright anymore.
    Here are a couple photos of my S8 connector and my Ground.
    ON a more positive note I got around to Derping the gauge surround and emblem. I still need to clean up the emblem but you get the idea.
    ChadsPride and Cativelense[OP] like this.
  19. May 8, 2017 at 12:46 PM
    #1079
    JdevTac
    Josh
    MD/GA
    2nd gen
    If your ground is that black wire, I'm pretty sure you stuck your ground in the wrong slot. Should be the slot next to the green wire that's on the lower side of the picture. The diagram posted in that one thread is confusing as shit cause the terminals are numbered as if you are looking straight at the female side not the connector itself.
    I at least do remember it was directly next to the horn ground because I accidentally made contact with it and the horn went off lol.
    ChadsPride likes this.
  20. May 8, 2017 at 12:48 PM
    #1080
    nudavinci64
    Robert
    That is confusing. I looked a a document from toyota on the connectors and that showed that as pin 9. 3 over from the left. Like you said. I am probably looking at it backwards then. That is confusing. So If I move it over to the next pin I should have some luck? I will give that a try as yes it is the black wire.
