Feeler: Power Vent Windows
Discussion in '1st Gen. Tacomas (1995-2004)' started by nzbrock, Aug 31, 2016.
Would you buy this?
  1. Yes
    41 vote(s)
    82.0%
  2. No
    9 vote(s)
    18.0%
  1. Oct 22, 2016 at 4:29 AM
    #41
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Great job. I'm sure more people would open the rear vents if it was just a simple button. I know that I would.
    GQ7227 likes this.
  2. Mar 6, 2017 at 12:34 PM
    #42
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    What happened to this?
    DustStorm4x4 likes this.
  3. Mar 6, 2017 at 1:18 PM
    #43
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I'm totally down to buy one right now if you're selling them. I'm doing a retrofit for power windows in my Xtracab and I have two unused switches since I used parts from a Doublecab.
    I'm building the harness soon so if this is something you'd sell it'll be easier for me to install while I have all the wiring out. If not could you share how to build them? I need this in my life!
  4. Mar 6, 2017 at 1:25 PM
    #44
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Is this still a thing? I'd be interested. The only reason why I do not use the vents is because it is inconvenient to do so. If there was a button then I'd be opening them all day!
    GQ7227 and DustStorm4x4 like this.
  5. Mar 6, 2017 at 1:27 PM
    #45
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Are you wiring them to the rear power window switches for the double cab, to your xtra cab? If so, that's awesome keeping the factory look.
  6. Mar 6, 2017 at 1:33 PM
    #46
    BartMaster1234
    Tyler
    Flux Capacitor
    Might help you better if you read into my build thread: https://www.tacomaworld.com/threads...t-build-thread-write-up.455447/#post-13422087
    I'm using a Double Cab master window controller since that's what the donor truck I got parts from had. The front two switches control their respective windows, but the rear window switches don't have anything connected. I never planned to utilize the rear window switches until I came across @nzbrock's build thread where he did this.
    I was originally going to use cheap Chinese aftermarket power window kits (which was just a weak 12v motor with switches that hooks up to the manual window regulator gear where the handle would go) and cheap 3rd party lock actuators. It would have looked so ugly if I just stuck a bunch of window switches and lock switches into the '95-'00 style door panels so I decided I wanted to do it properly.
    Luckily enough, a member on here was parting out his Limited '04 Double Cab, plus he was local. Took the 5 hour drive to Chico to pull the parts and here I am.
    Do check out my thread though it has a lot of details.
    DustStorm4x4[QUOTED] likes this.
  7. Mar 6, 2017 at 2:02 PM
    #47
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I'm still planning on making the parts, just haven't had the time. So this is currently on the back burner.
    GQ7227 likes this.
  8. Mar 6, 2017 at 2:03 PM
    #48
    BartMaster1234
    Tyler
    Flux Capacitor
    Do you have the plans for this anywhere? While I have all the wiring out I want to run some wires to this so I can just plug it in when I eventually get this.
  9. Mar 6, 2017 at 2:05 PM
    #49
    nzbrock
    Noah
    San Marcos, TX
    No posted plans. The motors just require two wires each. I ran the wires on the driver side and then across behind the rear wall panel to the passenger side.
  10. Mar 6, 2017 at 2:06 PM
    #50
    BartMaster1234
    Tyler
    Flux Capacitor
    Sounds good. Any ETA on this?
  11. Mar 6, 2017 at 2:09 PM
    #51
    nzbrock
    Noah
    San Marcos, TX
    No ETA yet. I have to pull my window vent pieces off my truck so I can take measurements. Then test print parts, test fit, etc.
  12. Mar 6, 2017 at 2:10 PM
    #52
    BartMaster1234
    Tyler
    Flux Capacitor
    Cool!
    So how does this mount to the cab, I heard you welded it or something?
  13. Mar 6, 2017 at 2:12 PM
    #53
    nzbrock
    Noah
    San Marcos, TX
    I welded the motor mount bracket to the stock linkage bracket that bolts to the cab. They just both happened to be aluminum.
    I plan to 3d model and print a bracket that would replace everything.
  14. Mar 6, 2017 at 2:14 PM
    #54
    BartMaster1234
    Tyler
    Flux Capacitor
    Alright! Please do put me down on a list when you end up selling these. Hell, I'll be the first one to buy one.
    Would adding a passenger switch on each side be something that's feasible?
  15. Mar 6, 2017 at 2:15 PM
    #55
    robupstateny
    Rob
    Upstate NY
    Oh I'm so waiting for this. Put me down for one!
  16. Dec 9, 2019 at 6:54 PM
    #56
    Goober1997
    Goober1997 Well-Known Member
    Colin
    2002 2.4l 5Spd Tacoma Base
    Any follow up on this? Really interested in either buying or building this set up, what size motor was used?
    GQ7227 likes this.
  17. Dec 10, 2019 at 6:50 AM
    #57
    nzbrock
    Noah
    San Marcos, TX
    I haven't made any progress on a kit. Since posting this I moved from FL to PA, and now I'm in TX.
    I still want to look into this more, once I have my shop up and running in the spring I can probably start on this again.
    Here's the motor I used originally: https://smile.amazon.com/gp/product/B00O7IHVIA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I got this motor to use on version 2 since it's : https://smile.amazon.com/gp/product/B00D838WX8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    The custom part is how the linkage works, and how the motor mounts.
    I also learned that 01-04 uses different interior pieces from 95-00.
    95-00 has an opening in the plastic to mount the bracket (easier).
    01-04 does not have an opening, so the bracket is hidden behind. This is much harder to figure out and mount since it would involve removing the interior plastic to get to it.
    TacoHank1998 and GQ7227 like this.
  18. Dec 10, 2019 at 6:56 AM
    #58
    GQ7227
    GQ7227 mw survivor
    J A Y
    and its most likely the actual # of 95.5-2000 models still active on the roads is quite a bit less than the 01-04 models, due to the crushings :(
  19. Dec 10, 2019 at 6:09 PM
    #59
    Goober1997
    Colin
    Hell yes, thanks for the reply! quick question, how'd you make it only rotate enough to get the window open, without it rotating complete rotations and possibly break the linkage system or burn the motor?
  20. Dec 11, 2019 at 6:54 AM
    #60
    nzbrock
    Noah
    San Marcos, TX
    The linkage I used from a minivan works to stall the motor when it's at the end of rotation (about 180 degrees). This is how almost all of them work, same with regular window motors. They hit the end of mechanical travel and stall, then there is usually a sensor of some sort that cuts power to the motor in case you keep holding the button.
    In this case the stall amperage was low enough to not cause any issues, and the motor isn't strong enough to break anything. I bench tested the stall amperage but I can't remember what it was off the top of my head.
