FEELER: Rear View Mirror Height Extension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Relik, May 25, 2011.
  1. May 25, 2011 at 3:41 PM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey all,
    Well I'm just another tall Tacoma driver that had an itch about attacking the idea of raising the center rear view mirror.
    I designed and grew this piece out of plastic (ABS) that mounts to the stock "slide" while creating a new entended "slide" that the mirror can mount to. Also tapped a screw in to secure it.
    Its not much, but I got a 5/8" lift (Using the top of the auto shifter as a reference). I could not go any higher since the electrical connector is now flush with the headliner.
    Minimal issues so far with prototype:
    -Very slight vibration on bumps, but not much noticable difference. I'm thinking a padding/tape can be added between the extending part of the plastic piece and window for stability (Cantilever bending)
    -Now the large black wire cover cannot fit back on, so it must be modified or a new cover must also be made...
    What you all think?
  2. May 25, 2011 at 6:18 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Cool, you selling those?
  3. May 25, 2011 at 7:09 PM
    Relik
    Eddy
    Thousand Oaks, CA
    I was debating so, so I posted this thread...figure if there was enough interest I would :D
  4. May 25, 2011 at 7:24 PM
    Woodstocktaco
    Woodstocktaco Well-Known Member
    Woodstock, GA
    09 SR5 ORDC 4X4
    3" OME lift, 885 coils, Dakar rears, diff drop
    Initial prototype shows promise. I'm not that tall (5'10") and even I have to constantly pull the mirror up to center it on the back window. I'd be interested if cosmetic issues can be resolved so it looks "OEM".
    If you don't mind a suggestion - apply for a patent before some Chinese plastic factory copies it and starts pumping them out before you finish the final prototype. There are probably other applications that could benefit from this idea.
  5. Nov 12, 2011 at 5:28 PM
    megablip
    megablip New Member
    2012 Stock 4WD AC OR Silver
    I too agree that the mirror is very low. I am 6' 1'' and it seems as if that damn mirror is always in the way. I would go as far as to say it is dangerous. Looking out for pedestrians has become even more of a challenge.
    Reading about moving the pivot point up (never occurred to me) did help a tiny bit, but it still needs to move up that extra inch. I did realize that the headliner felt a little low and the windshield narrow by a bit, but the mirror is the real crux of the visibility problem.
    Took me around 400 miles to pinpoint my frustration (call me slow)!
    Can't believe Toyota can get away with that (and didn't fix it for the 2012). At the very least a third party extension arm or extender (like you have made) would be enormously helpful.
    I know you did this months ago, but do you have any pics of what you eventually came up with?
    I applaud your efforts with this problem.
  6. Nov 13, 2011 at 6:14 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    At 6'2" I've had the exact same problem. That mirror is just too low in the windshield. If the OP's solution is finalized and looks like OEM I would definitely buy this product.
    So how's it coming OP? :D
  7. Nov 17, 2011 at 8:03 AM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
    I would be interested :)
  8. Feb 2, 2012 at 5:48 PM
    G.T.
    G.T.
    CONUS
    Yes please. Dropped you a PM but it may have slipped through the cracks.
  9. Feb 2, 2012 at 6:20 PM
    Fore
    Fore Well-Known Member
    07 PreRunner
    6' 2" me too!
  10. Feb 2, 2012 at 6:21 PM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    I would be interested in one as well.
  11. Feb 2, 2012 at 6:23 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
  12. Feb 2, 2012 at 6:43 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I just flipped mine upside down and it raises it up.
  13. Aug 10, 2015 at 7:55 PM
    Dogdad
    Dogdad Well-Known Member
    Metairie,Louisiana
    2015 Pyrite Mica Double Cab
    Lol...reading this thread from two years ago and the post before mine looks like it shut down this thread and everyone went and flipped their rearview mirror....
