Feeler: Retrofit projector headlights....Ideas wanted....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacorunner, Jun 30, 2011.
  1. Jun 30, 2011 at 2:26 PM
    09tacorunner
    09tacorunner [OP] Well-Known Member
    Duke City
    09 PreRunner TRD OffRoad
    Hello TW! This is a repost from my last thread that I introduced my self with, I got a friendly welcome from those who replied!
    I have been looking to do Retrofit Projector headlights and have been looking at the retrofit source website. I know I want to do the Morimoto mini projectors but what I am stuck with is all the different options to choose from. Would everyone that has Retrofit head lights post what you have, where you bought them, and all your options you chose. thanks so much!
  2. Jun 30, 2011 at 2:35 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Subbed. Ill get my info up for you in a bit
  3. Jun 30, 2011 at 2:44 PM
    09tacorunner
    Duke City
    thanks so much bro! :)
  4. Jun 30, 2011 at 2:54 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  5. Jun 30, 2011 at 3:08 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    I got my kit from The retrofit source.
    It's the FX-R stage 4 with 35w Denso ballast
    Proabaly my favorite mod right now you won't be disappointed.
  6. Jun 30, 2011 at 3:18 PM
    09tacorunner
    Duke City
  7. Jun 30, 2011 at 3:20 PM
    09tacorunner
    Duke City
    Oh I know I won't be disappointed when I do it! My cousin just put a set on his Scion TC and they are drop dead gorgeous! and even on a tacoma they are just as good looking especially with the entire housing blacked out!
  8. Jun 30, 2011 at 3:28 PM
    memario1214
    Colton
    Missoula, MT
    I got my kit from TRS as well...
    Mini D2S with 35w 5000k Morimoto Ballasts
    Gatling gun shrouds
    Blacked out my bezel and left the bowl chrome. I am pleased with how it turned out!
  9. Jun 30, 2011 at 3:30 PM
    AsianAnts
    AnT
    set oven to 300 degrees and turned it off. put light in oven for 10 min. take light out and start prying it apart. the only cutting was the reflector bowl and trimming on the shroud to fit on the projector
    keep in mind this was for a fx-r projector. I dont know if you require cutitng the bowl for the mini or the diff projectors... but all projectors will require you to drill 4 holes into the bowl to mount it there.
  10. Jun 30, 2011 at 3:38 PM
    09tacorunner
    Duke City
    yeah yours look great! thanks for all the replies! i am narrowing down the options of what to get! when i make my purchase i will put up a thread of my progress. one last question for everyone. about how long did it take to install beginning to end?
  11. Jun 30, 2011 at 3:39 PM
    memario1214
    Colton
    Missoula, MT
    Incorrect... There is a mounting ring on the Mini D2S as well as the H1. No cutting is required
  12. Jun 30, 2011 at 3:40 PM
    09tacorunner
    Duke City
    i don't mind doing the 4 mounting holes, I kind of expected that! also is it easier to put the light in the oven? or is their another route i can take?
  13. Jun 30, 2011 at 3:40 PM
    memario1214
    Colton
    Missoula, MT
    Mine took me all day (approx 8 hrs)... This is including the time it took me to paint the bezel and let it cure
  14. Jun 30, 2011 at 3:41 PM
    09tacorunner
    Duke City
    the mounting ring, is that an adaptor plate? some of the kits say it comes with an adaptor plate what is that used for?
  15. Jun 30, 2011 at 3:42 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Subbed, i'll be doing a set of these soon.
  16. Jun 30, 2011 at 3:43 PM
    memario1214
    Colton
    Missoula, MT
    There is a little collar that goes around the projector and slides into the same slots that you normal bulb does. This makes it so that you don't have to dick with the rotation of the projector (adapter ring is only on D2S and H1).
  17. Jun 30, 2011 at 3:44 PM
    09tacorunner
    Duke City
    there are days that i don't drive! so eight hours doesn't sound to bad! but since i have the smoked headlight housing I wouldn't need to paint them so it could be slightly less time!
  18. Jun 30, 2011 at 3:45 PM
    09tacorunner
    Duke City
    ah okay that makes sense!
  19. Jun 30, 2011 at 3:45 PM
    memario1214
    Colton
    Missoula, MT
    Considerably. If you went the route I took and do not paint the bezels... I am confident (with even minor mech knowledge) that you could do it in about 3 hrs
  20. Jun 30, 2011 at 3:46 PM
    09tacorunner
    Duke City
    so this is helpful for you as well :D
