FEELER: tooter II.VII 2 inch thick intake manifold spacers
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by tooter, Jun 4, 2014.
  1. Dec 5, 2016 at 5:31 PM
    #141
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    I'm definitely in... Just let me know!
  2. Dec 5, 2016 at 5:56 PM
    #142
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    He never replied so nothing will come of it.
  3. Dec 5, 2016 at 8:47 PM
    #143
    Cagedodger
    Cagedodger Well-Known Member
  4. Dec 5, 2016 at 11:17 PM
    #144
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Tooter told me wasn't going to give up the drawings and doesn't trust anyone with his confidential drawings...I can respect that..his time and effort. He would only use a CNC place he has vetted. I gave up on this and with CARB wasn't sure how much work was the install and removal each time.
    You take a stock flange and double the thickness, but tooter spent the time with the dyno to get the right thickness. It would require someone to measure theirs and reverse engineer the measurements.... if you wanted to go that route.
    Tooter is off doing other projects for now... this was the last PM he was kind enough to respond.
  5. Dec 6, 2016 at 6:51 AM
    #145
    jowybyo
    Joe
    Baltimore, MD
    It's his choice obviously, but it seems a bit overboard for a product he doesn't even want to make anymore.
    Last I read it was 2" thick, is that not the final thickness?
  6. Dec 6, 2016 at 12:01 PM
    #146
    imom
    CAL
    2014 Regular Cab
    I wouldn't bet the farm on that number...so best if someone who has the original tooter to measure the thickness with caliper to tell you. Otherwise you are starting a a certain point and without dyno to verify if that was the right thickness. If you got the original thickness required and then it's just a matter of taking the original intake and tracing all the hole locations and getting longer bolts. Your CNC machine can do the rest.
    Kuntrykid likes this.
  7. Dec 7, 2016 at 3:16 AM
    #147
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have no caliper but I have a measuring tape with inches and mm and the IM spacer.......I'll bet it is 2" and take that farm.................
  8. Dec 7, 2016 at 3:42 AM
    #148
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I just measured mine with calipers and it's 2". That said, it's not like that is some magic number or something. It's roughly big enough to have an effect, and small enough that the manifold still has clearance. He supposedly verified that it provides results on a dyno, but it's not as if he arrived at that thickness after a long series of trial and error. It's just an intake spacer that some guy designed in his garage, not some grand feat of engineering that has been honed to perfection.
  9. Dec 7, 2016 at 5:11 AM
    #149
    jowybyo
    Joe
    Baltimore, MD
    Thanks for confirming the dimension. We don't plan on selling these but I will look into getting a few made.
  10. Jan 27, 2017 at 8:27 PM
    #150
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Count me in on one if you decide to.
    WorldWar546 and Kuntrykid like this.
  11. Jan 27, 2017 at 8:53 PM
    #151
    Cagedodger
    Ditto here.
  12. Feb 19, 2017 at 9:17 PM
    #152
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    How would this work on a 3rd gen 4 banger?
  13. Feb 20, 2017 at 12:44 AM
    #153
    jowybyo
    Joe
    Baltimore, MD
    It's the same engine so it would work the same.
  14. Feb 20, 2017 at 1:09 AM
    #154
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    Sub'd
    I'd be down in the future
    tacoburrito likes this.
  15. Feb 20, 2017 at 6:56 AM
    #155
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    Thanks
  16. Feb 20, 2017 at 8:59 AM
    #156
    militarytj
    militarytj Active Member
    Tj
    2012 tacoma - sport
    7 in` k&n . Copper svt max. 265/17s. 3in level and blocks. LED rear lights.
    All tease.... sucks no plans could be given, I got a machine shop at my disposal. Complementary of the Army ;)
  17. Feb 20, 2017 at 3:50 PM
    #157
    bijick
    E
    Stl
    Make some measurments!! Or maybe I'll supply them once I get my lce header
  18. Feb 20, 2017 at 4:51 PM
    #158
    militarytj
    Tj
    2012 tacoma - sport
    I wouldn't know what to do bro, I'm a structure tech on helicopters lol. But I got people that will make me whatever I want.....
  19. Feb 20, 2017 at 4:59 PM
    #159
    akkyle
    Kyle
    Alaska
    I want to note that I'd be in if the price could somehow be lowered. Hard to justify the original asking price by tooter for a marginal lower peak torque.
  20. Feb 20, 2017 at 7:17 PM
    #160
    militarytj
    Tj
    2012 tacoma - sport
    I'd pay 255 all day for that amount of gain..... not including possibly taking the measurements and tweaking them for more gain, I myself would mill it out of steel or the appropriate heat bearing metal.
