Feeling / noise under drivers side floor board
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmf21, Nov 12, 2011.
  1. Nov 12, 2011 at 7:47 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    For the past month or so I have started noticing this noise and feeling under the drivers side floor board. It's almost like I'm driving over those rumble strips on the freeway. I can feel it on every rotation of the tires. The faster I go the less I notice it but it's still there.
    Anyone have any idea what this is?
  2. Nov 13, 2011 at 9:28 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    anyone?
  3. Nov 13, 2011 at 9:30 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    wheel bearings maybe?
  4. Nov 13, 2011 at 9:34 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    It's not making a grinding noise or anything like that so I don't think it's the bearings. It's hard to describe what it feels like. It's almost like I'm going over rumble strips on the highway but not feeling every one. The rotation feels like a circle that's out of round or a flat tire feeling.
  5. Nov 13, 2011 at 9:35 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    try this..
    Check the rotor make sure its not warped check pads while your there.. Check cv joints. Three when was the last time you greased all the u joints up?
  6. Nov 13, 2011 at 9:36 PM
    TACOMABOSS
    96 SR5 4x4
    In my dads Tahoe(i know its not a Tacoma) one of the wheel bearing went out and it kinda felt like driving over the rumble strips. idk just a thought
  7. Nov 13, 2011 at 9:38 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    forgot to mention that the trucks an 04 4x4. Don't know what parts rotate up front on a 4x4 when it's not use.
  8. Nov 13, 2011 at 9:40 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    everything rotates up there unless you have manual hubs.
  9. Nov 13, 2011 at 9:41 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I should probalby clearify the feeling a little better. The feeling is more like I'm running over those reflectors that are down the center of the road.
  10. Nov 13, 2011 at 9:49 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    have you check drive shaft u joints and center bearing?
    Mike likes Tacos likes this.
  11. Nov 13, 2011 at 9:57 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Haven't checked those. What's the proper way to check them. Is it to grab the drive shaft and try to turn it by hand or something? If I can, does it mean the ujoints are bad?
    While I'm at it I probably need to do some greasing since I don't think it's ever been done since I've had it. I also forgot to mention that I can feel the problem in the gas pedal sometimes as well as the floor.
  12. Nov 13, 2011 at 10:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Vibes felt in the floor pan or the seats indicates the source is in the rear half of the truck somewhere. I suspect driveline. As someone has already mentioned, grease all the fittings on the rear driveshaft.
  13. Nov 14, 2011 at 3:56 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I really don't have any vibes. It's not that type of feeling. I greased everything up today but still have the feeling under the drivers side floor. My mother says it sounds more like a woooff.
  14. Nov 15, 2011 at 12:28 AM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Carrier Bearing?
  15. Nov 15, 2011 at 12:35 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Manual hubs are tight its why I have em :D
    and he has an 04 so he add
  16. Feb 15, 2018 at 2:41 PM
    moorej42
    moorej42 Member
    Idaho
    2005 Tacoma. 4.0 L. Double-cab
    Leer cap
    @cmf21
    Did you ever resolve this issue an determine the source of the problem?
    I have a 2005 Tacoma with 171,000 Miles. I have been experiencing the same thing.
  17. Feb 15, 2018 at 3:13 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Maybe:
    - something stuck in the tire tread (rock, nail, screw, etc).
    - an out-of-round tire
    - loose lug nuts
