Feels like a miss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DavidIndy, Oct 22, 2016.
  1. Oct 22, 2016 at 11:51 AM
    DavidIndy
    DavidIndy [OP] Member
    David
    2006 Taco 2wd extCab
    Highlander wheels
    My 2006 4cyl Taco (140K) developed a "miss" this last week.
    I replaced the plugs 10k ago.
    I just replaced the coils and its better, but not gone.
    Injectors, a sensor or real problems?
    HELP?
    Thanks
  2. Oct 22, 2016 at 4:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do you get a CEL?
    What is the CEL code it if you have one?
    Check your coolant level and see if it is dropping.
    Cylinder Compression and Leak Down Test will check for the issue.
  3. Oct 22, 2016 at 5:57 PM
    DavidIndy
    David
    Highlander wheels
    I just did a flush and fill a couple months ago.
    level is still good.
    timing chain jumping a tooth would be worse than this i think.
    it develops the "miss" about 2200 RPM.
  4. Oct 22, 2016 at 7:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would clean the MAF with MAF Cleaner and reset the ECU by removing the Battery Cable for a few minutes.
    I seriously doubt that your timing chain jumped a tooth.
  5. Oct 22, 2016 at 7:41 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Is the check engine light on?
  6. Oct 23, 2016 at 4:33 AM
    DavidIndy
    David
    Highlander wheels
    no check engine light.
    im going by the local parts store to have them check for any codes on the comp today.
  7. Oct 23, 2016 at 2:14 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Just because the plugs are only 10K old does not mean they're fine. Have you pulled them to check gap and for cracked insulators?
    It's also very odd that you are not getting a CEL it is indeed misfiring, are you sure it's not just an exhaust manifold gasket leak or cracked manifold causing a "ticking" under load?
  8. Oct 24, 2016 at 10:23 AM
    DavidIndy
    David
    Highlander wheels
    It idles fine. The miss or vibration starts about 2200 rpm - more under a load versus cruising.
    I had the frame replacement recall done a couple months ago. Driveshaft or U joints?
  9. Oct 24, 2016 at 10:29 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Start with new plugs
  10. Nov 5, 2016 at 4:34 AM
    DavidIndy
    David
    Highlander wheels
    hey everybody, thanks for the replies.
    I took it into the dealer thinking it could be frame recall related -
    it ended up being the front u-joint.
    The service manager said they went thru the truck torquing up everything, then dug deeper finding the u-joint.
    it runs great and feels like new.
    I really like the results of the frame recall:
    I sit up higher and it rides more like a truck than a car,
    and it will haul more as the rear leaf springs are a bit beefier.
    Thanks all.
  11. Nov 5, 2016 at 5:50 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    :eek: So your front universal joint was causing a miss? :anonymous:
    OK
    Blockhead and Sub_Par like this.
  12. Nov 5, 2016 at 12:26 PM
    Taco'09
    Taco'09 Well-Known Member
    Yes, its the well known front ujoint cyl 3 engine miss.
  13. Nov 5, 2016 at 3:51 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Just pokin a little fun!
  14. Nov 19, 2016 at 6:55 AM
    DavidIndy
    David
    Highlander wheels
    its ok fellas... Im about as backyard mechanic as it gets... This was about as weird as ive ever had in a vehicle.
    I guess the fact they went thru the truck before finding the u joint makes me feel a bit better.
    I did get the dealer to cut the labor in half as I wanted it changed when they replaced the frame and the advisor talked me out of it.
