Feels like a miss.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mdb1grfe, Dec 12, 2020.
  1. Dec 12, 2020 at 7:50 AM
    mdb1grfe
    mdb1grfe [OP] Well-Known Member
    Butler County, PA
    2018 TRD OffRoad, Silver DC
    D-ring tie-downs.
    Around 1000 rpm and 1500 rpm on level road and just a little pedal to keep moving, my truck seems to have an intermittent miss. 65 to 70 mph also. Hard acceleration is no problem and around 3500 rpm the vvt kicks in. No warning lights. About 15k miles on the odometer. Anyone else have this.
  2. Dec 12, 2020 at 8:56 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Welcome to the 3rd gen Tacoma. You have the fuel pump recall performed yet?
  3. Dec 12, 2020 at 8:59 AM
    Juice Weasel
    Juice Weasel Well-Known Member
    3rd Gen Tacoma SR5
    yes mine does same thing 12k miles, i think its the computer "learning" driving habits, not a misfire. my fuel pump was not affected by recall. 2020 sr5. Maybe the guys who do the OVtune can chime in.
    tcjacado likes this.
  4. Dec 12, 2020 at 9:04 AM
    mdb1grfe
    Butler County, PA
    D-ring tie-downs.
    Yes I had the fuel pump replaced. Seemed to run a bit better after the work. My truck has acted this way since I got it. Had the Tranny TSB done in Aug 2018.
    So what im experiencing kinda describes how these trucks typically run?
  5. Dec 12, 2020 at 9:12 AM
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    I had it. Other owners on here have had it. After getting the fuel pump replaced and now the latest tsb transmission update I havent noticed it. I havent been on a highway yet only 2 lane roads since having those 2 things done but if Im not mistaken I dont think it shifts into 6th gear until it reaches 60 mph now.
  6. Dec 12, 2020 at 9:17 AM
    Bishop84
    Bishop84 Well-Known Member
    Ask for the TSB update, it addresses this, and the fuel pump helps as well.
    Junkhead and Juice Weasel like this.
  7. Dec 12, 2020 at 9:24 AM
    mdb1grfe
    Butler County, PA
    D-ring tie-downs.
    Are you talking about the TSB-0092-20 ? I did see the list on another Thread here and the 4th to 8th position of my VIN matched one on that list.
  8. Dec 12, 2020 at 9:32 AM
    mdb1grfe
    Butler County, PA
    D-ring tie-downs.
    Thx
  9. Dec 12, 2020 at 10:27 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Haven't noticed anything resembling a miss in my 2020 sr5, but did notice the engine lugging when in 6th gear going slow after a couple tanks of premium gas. It doesn't do it when i fillup with 87 grade.
    Juice Weasel likes this.
  10. Dec 12, 2020 at 10:39 AM
    mdb1grfe
    Butler County, PA
    D-ring tie-downs.
    With the engine design and calibrations Id say 87 octane is what it is designed for. Maybe the sensor electronics has to deal with something out of the ordinary like 93. This is my 3rd Tacoma starting with an '06. I certainly do like them. Let's face it, regardless the method, it does take a certain amount of work to move a certain amount of mass.
    Juice Weasel and Junkhead like this.
  11. Dec 12, 2020 at 10:47 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Manual states 87 or higher. Its not designed to run on 87. My taco drove amazing on 91E0, on stock tune. Now that im tuned to premium gas, it drives even better. I remember Ov tune stating in one of the threads that the 3.5 is happier with higher octane gas.
    My ranger was designed to run on 87 only and it was clearly stated in the manual.
    Lt. Dangle likes this.
  12. Dec 12, 2020 at 10:53 AM
    zoo truck
    None
    Not my 2020 v6. It lost power on hills, and hunted gears with 93 grade e10. Seemed after the third tank it got really noticeable, even fuel economy dropped 1mpg. I'm back to running only 87 now and the power is back plus it pulls hills without hunting. Fuel economy has steady crept back to within a tenth where i use to be.
    Junkhead[QUOTED] likes this.
  13. Dec 12, 2020 at 11:08 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Interesting, was the opposite experience for me in my taco. All the japanese vehicles that i had, ran better and got better fuel mileage with 91 or higher E0. Now, the domestics i had, preffered 87 with corn juice.
    You are the only guy on TW that says that it runs better on 87, strange.
  14. Dec 12, 2020 at 11:51 AM
    mdb1grfe
    Butler County, PA
    D-ring tie-downs.
    Just curious, in dollars per mile, what might the difference be? If I do short range travel like less than 10 miles round trip and multi shut down and starts, is a higher grade fuel better cost wise?
  15. Dec 12, 2020 at 12:07 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    93 fixes this on my truck. Light load and light throttle applications where engine miss is felt. Been this way for 57k miles now.
    My truck is not part of the fuel pump recall either.
    Lots of others have reported this issue as well with no real fix.
    Here's some more reading on the subject:
    https://www.tacomaworld.com/threads/slight-miss.448072/
    https://www.tacomaworld.com/threads/had-the-truck-two-weeks-it-runs-better-on-89-octane.668446/
    https://www.tacomaworld.com/threads/3rd-gen-engine-skip.649705/
    https://www.tacomaworld.com/threads/throttle-hesitation-slight-engine-skip.446950/#post-22564084
    https://www.tacomaworld.com/threads/2019-tacoma-1500rpm-diagnosis.608297/
    https://www.tacomaworld.com/threads/compression-of-our-motor-and-octane.634151/
    https://www.tacomaworld.com/threads/engine-shutter-at-53mph.579936/
    https://www.tacomaworld.com/threads/low-rpm-shuddering.582986/
    Not all of them are directly applicable, but covers the subject pretty well. There's also links in these threads for the "OcTanE is suPPoseD To bE 87" crowd relating to OV and the work he has done with the tune and stock maps.
    Junkhead likes this.
  16. Dec 12, 2020 at 12:09 PM
    Lt. Dangle
    Ohio
    Yeah, very interesting...
  17. Dec 12, 2020 at 12:11 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I have not had that happen, 2019 4 cyl, 6k miles.
  18. Dec 12, 2020 at 1:22 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Well you are paying a bit more, and get a but better fuel mileage. At the end of the day, its pretty much a wash. I just like the EO gas much better, my truck sits 5 days a week.
