Feels like I have a transmission shudder- any advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dave7432, Jul 20, 2022.
  1. Jul 21, 2022 at 12:18 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Those were the exact symptoms I was having. I was convinced it was the torque converter so I replaced it and shudder is now gone. I've put a few thousand miles on it so far since then and shudder has not returned.
  2. Jul 21, 2022 at 12:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Add LubeGuard and pray it goes away.
    It doesn’t actually fix the problem. But it can make the shudder go away for awhile.
  3. Jul 21, 2022 at 12:55 PM
    dave7432
    dave7432 [OP] Member
    2009 Tacoma TRD
    Did you try anything else before replacing? Curious what you paid to have it replaced?
  4. Jul 21, 2022 at 1:12 PM
    MA_TACO
    Wesley Chapel, FL
    I tried pan flush and refill with Instant shudder fix which worked for a while but kept coming back. I only paid $199 for the torque converter plus a couple of seals, Maxlife ATF etc and replaced it myself
  5. Jul 21, 2022 at 1:21 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    A zero cost and easy first step would be to make sure you actually have the correct level of ATF in there.
    kwanjangnihm likes this.
  6. Jul 21, 2022 at 3:14 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Had the same thing as you. Drove me crazy. So I did a transmission flush and put in a tube of the shudder fix stuff and it went away after about 100-200 miles
  7. Feb 22, 2024 at 1:47 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    This is an old thread but to any of you who used the lubegard fix, how has it lasted over time?
  8. Feb 22, 2024 at 2:16 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Converter lockup.
  9. Feb 23, 2024 at 8:57 PM
    pahaf
    paul
    NorCal
    i put on about 20-25k since adding lubegaurd. it doesnt shudder anymore or make vibes......seems to have solved the issue.
    Anchovy likes this.
  10. Aug 7, 2024 at 6:20 PM
    Vance4
    Vance4 Member
    Following
