Feels like something is loose in the steering?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danmckennat, Aug 14, 2010.
  1. Aug 14, 2010 at 12:30 PM
    danmckennat
    danmckennat [OP] Well-Known Member
    chardon, ohio
    2009 tacoma access cab offroad package
    i noticed the other day driving my 09 trd access cab down a dirt road that once in a while i could feel in the steering wheel like the front suspension was loose or something in the steering was loose. i only notice it on dirt roads or rougher terrain or going over bumps. i dont offroad the truck or beat on it so not sure. anyone else notice this before?
  2. Aug 14, 2010 at 12:36 PM
    wtbthree
    wtbthree Give 'er
    Will
    Colorado Springs, CO
    SC'ed 2010 DC
    3" Revtek lift, 17" FJ rims, 285 BFG KO's, sunroof, TRD piping, Wickedflow muffler, Avid step rails TRD supercharger,
    I did a couple weeks ago, (I live on a dirt road) but it seems to have subsided, or at least i haven't noticed it recently. It felt like there was a little bit of "play" in the steering. like a small gap before the wheel would engage the with the column. I know there is a TSB out there for a "steerign column rattle" and this could be part of the symptoms. As Ive said, my trucks driving fine tight now, but I've kept this in mind if it comes up again and/or gets worse.
    Might help you out: http://www.tacomaworld.com/forum/2nd-gen-tacomas/96634-steering-column-rattle-tsb.html
  3. Aug 14, 2010 at 6:25 PM
    danmckennat
    chardon, ohio
    no body else have ever experienced this?
  4. Aug 14, 2010 at 7:14 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    do you have a lift, could be your alignment
  5. Aug 14, 2010 at 8:12 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2009 SR5 DC LB 4x4
    Eibach springs w/ 5100 Bilstein shocks set to "0", Rear TSB
  6. Aug 14, 2010 at 8:32 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    i have the same problem only im too lazy too fix it yet... there was a fix out there on this site, involving putting a zip tie right next to the steering column, thus removing the play. it involves the column going through a ring that mounts it to the firewall, and the column is not a tight fit, and bumps, potholes,etc. will make it "clunk" from one end of the ring to another. placing the zip tie around the ring will force the column against one side, thus eliminating the play in the column. sorry for the lack of pictures, i wish i knew that thread, its not from a long time ago. keep in mind that its only a mm or two of play, so dont go freaking out about zip tying your steering column to one side or another, and besides, the ring the tsb gives you does the same thing. this is a mod, and its free if you diy :D
  7. Aug 14, 2010 at 9:20 PM
    SKINUM
    SKINUM Well-Known Member
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    If u run across the thread again plz let me know. Im beginning to think this is an issue im having on an 07 FJ.
  8. Aug 14, 2010 at 9:26 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    I totally feel this on rough trails, and have in all my 4x4s--not just toyotas (don't tell anyone I've owned other trucks....). It's just play, and as long as you're checking on all the important things now and again, it'll be fine. I like that there seems to be a TSB though. It would be nice if it wasn't there...
  9. Aug 14, 2010 at 9:31 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    If I can fix it with a ziptie though that would be great! I can grab my wheels at 3 and 9 o'clock and shake them and make the clunking noise.
  10. Aug 14, 2010 at 9:32 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    Just read the TSB--super stoked to get this done! Thanks to the OP for bringing it up, it bothered me a lot when off road; I hope this fixes the clonking...
  11. Aug 14, 2010 at 9:37 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    Hmm... That almost sounds like wheel bearings... How many miles?
  12. Aug 14, 2010 at 9:40 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    U would think but the wheel bearings are fine and tierods are good. I can grab the tire at 12 and 6 and there is no movement. 60,000
  13. Aug 14, 2010 at 9:54 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    Wierd... I'd go on a "loose anything" hunt if I were you... And try the zip tie! At least if you try the zip tie you'll rule that in/out.
  14. Aug 14, 2010 at 10:09 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
  15. Aug 15, 2010 at 8:55 AM
    danmckennat
    chardon, ohio
    nope no lift or anything done to my truck, completely stock
  16. Aug 15, 2010 at 9:15 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Yea, it's just the column shaft. Both my old 08 and my new '10 have it. The TSB should fix it (the zip tie thing was a pre-TSB fix that works fine as well). It's not a suspension or safety issue... just a minor annoyance.
  17. Aug 15, 2010 at 9:18 AM
    danmckennat
    chardon, ohio
    has anyone got the tsb done on it yet? or just do the zip tie fix?
  18. Aug 15, 2010 at 10:09 AM
    Bodete
    Missouri
    2009 SR5 DC LB 4x4
    I did the zip tie method. The steering doesn't clunk anymore but it still vibrates really bad. It did help.
  19. Aug 15, 2010 at 11:44 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Vibrations are most likely your tires. Check proper inflation, get the re-balanced (if using the toyota rims ensure they have the proper adapter to balance correctly). If they still fail, request a road force balance test... if they fail they should pro-rate a replacement set for you.
  20. Aug 17, 2010 at 8:06 PM
    danmckennat
    chardon, ohio
    took it too dealer to see if they will do the TSB
