Feels like the end!?(traded in)
Discussion in '2nd Gen. Builds (2005-2015)' started by Juforrest, Jun 8, 2016.
  1. May 1, 2020 at 11:00 AM
    #1381
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Are you talking about that little filter there?
    Slashaar likes this.
  2. May 1, 2020 at 11:40 AM
    #1382
    Juforrest
    Juforrest [OP] Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    The theory is yes. A quality filter that won’t plug up and get sucked into the fan is the key. My truck currently has 79k miles and no issues. (Currently knocking on wood)
    Slashaar, pink_pony[QUOTED] and MarX like this.
  3. May 1, 2020 at 1:49 PM
    #1383
    MarX
    Mark
    NE Kansas
    Here's a link to one I got. Good peace of mind.
    https://www.amazon.com/dp/B003CJOTSA
  4. May 1, 2020 at 4:10 PM
    #1384
    pink_pony
    pink_pony Well-Known Member
    2012 Tacoma TRD Sport 4x4
    Slashaar and MarX[QUOTED] like this.
  5. May 1, 2020 at 4:10 PM
    #1385
    pink_pony
    yeah, mine bit the dust at 85k
    thanks
    Slashaar and MarX like this.
  6. May 1, 2020 at 7:39 PM
    #1386
    pink_pony
    Forgot up ask, so did you remove the foam filter from inside the pump before you ran it with this new filter? I mean, if the foam going into the fan is the weakness, should I remove it?
  7. May 1, 2020 at 7:44 PM
    #1387
    Juforrest
    Justin
    Seattle
    Yes take out the foam.
  8. May 1, 2020 at 7:56 PM
    #1388
    MarX
    Mark
    NE Kansas
    That foam getting old falling a part has caused issues from what we've all read. That's what there filter helps to avoid by removing it and putting in the filter.
    https://youtu.be/JOk8oBuyu1s
  9. May 2, 2020 at 10:48 AM
    #1389
    MarX
    Mark
    NE Kansas
    4.3 miles this morning. 10:05 pace so not fast or slow. :benchpress:
    Slashaar and Juforrest[OP] like this.
  10. May 2, 2020 at 11:57 AM
    #1390
    Juforrest
    Justin
    Seattle
    40 minute Hiit workout this morning.
  11. May 5, 2020 at 4:50 PM
    #1391
    Juforrest
    Justin
    Seattle
    Just bought a Optima yellow top 27f from Amazon warehouse deal for $200 and ordered 1amp diode at the same time.
    MarX and Slashaar like this.
  12. May 5, 2020 at 4:57 PM
    #1392
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I'm sitting somewhere around there. I used Fuelly to track. v See Signature v
    MarX and Juforrest[QUOTED][OP] like this.
  13. May 5, 2020 at 4:59 PM
    #1393
    Slashaar
    Josh
    Kansas City, MO
    Or you can pony up and delete it. https://hewitt-tech.com/store/index.php?l=product_detail&p=47
    MarX likes this.
  14. May 5, 2020 at 5:52 PM
    #1394
    Juforrest
    Justin
    Seattle
  15. May 9, 2020 at 8:15 PM
    #1395
    pink_pony
    Slashaar[QUOTED] likes this.
  16. May 9, 2020 at 10:01 PM
    #1396
    Juforrest
    Justin
    Seattle
    I have not. I looked into a couple years ago and there were some people having issues with it.
  17. May 10, 2020 at 4:22 AM
    #1397
    pink_pony
    can you elaborate please? Are they have issues with their truck running well / throwing codes, or getting them to pass a smog emissions check?
    MarX likes this.
  18. May 10, 2020 at 5:57 AM
    #1398
    Juforrest
    Justin
    Seattle
    Throwing codes is mostly what I remember. It’s been a couple years so might be worth researching.
    pink_pony and MarX like this.
  19. May 13, 2020 at 4:04 PM
    #1399
    Slashaar
    Josh
    Kansas City, MO
    I keep thinking about it. Seems like a lot of work. I'll think seriously about it when/if I go to a dual battery setup.
    MarX likes this.
  20. May 13, 2020 at 4:06 PM
    #1400
    Slashaar
    Josh
    Kansas City, MO
    They sorted that with the PPP harness. It's just a bank that sends fake readings to the ECU to trick it and give you no codes.
    "The SAIS Pump Proxy Pack is an Add-On to our popular SAIS Bypass Kits. Normally our SAIS Bypass Kits can’t clear a P0418 or P0419 but now they can with the additional installation of a Pump Proxy Pack. The other option for clearing a P0418/P0419 code after installing a SAIS Bypass kit is to replace the SAIS Air Injection Pump with a new and expensive pump. That is a particularly expensive repair if you have to pay for the labor on a 4.7L engine where the Air Injection Pump is located under the intake manifold. Installing a Pump Proxy Pack is much less expensive and less labor intensive than having to replace an air injection pump and you can just leave the old faulty pump in place."
