FEND-X Tacoma Wheel Liners
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by cnote4l, Jul 7, 2018.
  1. Jul 7, 2018 at 8:49 PM
    cnote4l
    cnote4l [OP] Gear Tech Customs Vendor
    Cody
    Evergreen, CO
    2016 TRD OR
    TacomaWorld!!
    ____________________________________________________
    Featuring the most extreme, completely custom Tacoma wheel liner!​
    FEND-X Wheel Liners. Gear built to fend off the harshest conditions! Our Wheel Liners are on the verge of indestructible, yet incredibly flexible. Fend-X Liners are laid with unique molecular properties that can withstand the most extreme weather conditions.
    • Custom Designed
    • Reduce Road Noise
    • Tire Clearance Gains
    • Waterproofing Barrier
    • Superior Impact Strength
    • Extreme UV & Chemical Resistance
    FEND-X Liners are built for the wild. Gear engineered for maximum protection while maintaining proper ventilation / airflow to the engine intake. Features a super slick surface which makes pressure cleaning the wheel wells effortless. FEND-X Liners create the perfect backdrop for any aftermarket setup. We’ve upgraded every aspect of the traditional stock wheel liner by increasing the coverage, durability and aesthetics! Our Gear responds extremely well to heat / cold-forming while retaining memory (shape) and structural integrity.
    (1) Fend-X Wheel Liner
    6 ft Length x 2 ft Width x 1/8" Thickness
    Dimensions vary based on configuration*
    100% custom made in Colorado!
    :oldglory:
    Available to Order@ www.geartechcustoms.com
    Gear Tech Customs designs & manufactures Fend-X Wheel Liners and PROTEC Splash Guards. Combined provides the ultimate engine/wheel well protection in one package.
    Properly disposed of Stock Liners :devil:
  2. Jul 9, 2018 at 12:41 PM
    t8fanning
    t8fanning Active Member
    Utah
    2018 Quicksand TRD OR
    33" KO2s, TC UCA, 3" OME lift, ARB front bumper
    How much space do these lines give you over the stock ones near the cab mount where most tires rub?
    Acivichb and cnote4l[OP] like this.
  3. Jul 9, 2018 at 6:44 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    do you have a template for use with plate bumpers? i have a pelfrey and wouldn't mind something to help cover up the area below the headlight.
    cnote4l[OP] likes this.
  4. Jul 9, 2018 at 9:01 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    1 inch +/- gain. Pics should show the area in question here, this is the Wheel Clearance allowed with 285s / no CMC / Factory Fender Flares = Zero rubbing on Wheel Liner.
    We have an ARB bump on 3rd Gen but can cut Liners to spec for any bumper. Got a pic of the area?
  5. Jul 10, 2018 at 12:48 AM
    hirod
    hawaii
    ill try take a pic tomorrow
  6. Jul 10, 2018 at 7:02 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Interested. I don’t see any mouthing holes in the liner, does it just sit up in place inside the wheel well? Sick of dirt/mud getting flung up into my engine bay because of no liners. Is Aug 8th when they are shipping?
  7. Jul 10, 2018 at 12:49 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Correct, the wheel liner holds itself in place based on our design span from fender to frame. This in effect locks it from any side to side motion.
    Oem fenders have inward tabs that the fender flares will reattach too once the oem liner is removed. The Fend-X liner can run above these tabs and along the edge of the entire fenderwell. (Follow outer edges in pic below)
    Nowadays, no two Tacomas are alike which is primarily why you see no mounting holes. Mounting possibilities are endless with the Fend-X liners, and can be tailor to any Build.
    August 8 is end date of Prezorder session. Shipping is set to start week of August 12-18, for orders placed week of July 8-14 and proceed in weekly waves until current on pre-orders. At that point, there will be established lead times listed on product page.
  8. Jul 11, 2018 at 2:20 PM
    ToyoTacoTurner
    ToyoTacoTurner Am I really well-known?
    Houston
    2016 BBP TRD OFF ROAD DCSB 4x4 (OV TUNED)
    PRO GRILL-Meso lights-Speakers-rear black bumper-Debadged
    I feel like some voodoo shit is going on to keep those things from drooping in....
    What kind of magic are y'all using!?
  9. Jul 11, 2018 at 8:33 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    NSA :stirthepot:
    Our photos show liners mounted with zero hardware to depict its versatility. That said, we still recommend anchoring the Fend-X liner spaced out 2-4 points max. Any over that threshold is overkill because liner will retain shape and never drooop
  10. Jul 12, 2018 at 7:13 PM
    hirod
    hawaii
    a few days late. had a hard time getting a good angle. not sure if these pics help
    Catfish21 and cnote4l[OP] like this.
  11. Jul 19, 2018 at 11:03 AM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    The underside of bumper would remain exposed based on how aggressive it angles forward. Could have 2 shields fabricated given the dimensions
  12. Jul 21, 2018 at 12:54 AM
    hirod
    hawaii
    i think I'll just try out the design you already have and see if i can fold the forward section up. with all the discounts you're offering it's kinda worth it to just give it a try. which give me the most material to work with? the aftermarket bumper one or the factory bumper version? thanks
    cnote4l[QUOTED][OP] likes this.
  13. Jul 24, 2018 at 2:39 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Factory Bump option is longer and would give you the most material to work with!
  14. Aug 30, 2018 at 8:55 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    First and foremost, BIG thank you for the support and patience throughout the process! I'm relieved to announce that all pre-orders placed during July 7-26th are scheduled to ship Weds. Sept. 5th! All remaining pre-orders placed between July 27th - August 12th, will likely ship Sept. 12th. Following each shipment, all orders will receive tracking information and shipping confirmations, these notifications will be delivered via email and derived directly from the website!
  15. Sep 11, 2018 at 11:18 AM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    (15) Fend-X sets hit the streets last week. Pre-orders placed between July 7-26 have shipped! Check e-mail inboxes for confirmations & tracking
    :mudding:
    Catfish21 likes this.
  16. Sep 11, 2018 at 3:52 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    This is awesome. I will need this at some point in the future. My liners are chopped up and could use replacing. Subbed!
    cnote4l[OP] and ChadsPride like this.
  17. Sep 12, 2018 at 2:43 AM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    good. i'm tired of getting mud, dirt and debris on the inside of my wheel wells.... Hurry please! :playball:
  18. Oct 16, 2018 at 12:53 PM
    Pdog7
    Pdog7 Well-Known Member
    2018 TRD OR DCLB
    OME BP-51 Nitto 285's C4 Low Pro Bumper Mobtown Skids
    Think of getting a set of these and wanted to hear feedback from those of you that have received and installed yours. Pics would be great!
    cnote4l[OP] and Colorado_Taco17 like this.
  19. Oct 17, 2018 at 12:30 AM
    Catfish21
    Stockton, Ca.
    i'll let you know when they get here. then i'll install.
  20. Nov 13, 2018 at 8:14 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Seen a few different install photos floating around, I'll try to compile some
    :hungry:
