fender flare fasteners
Discussion in '1st Gen. Tacomas (1995-2004)' started by rvhop, May 7, 2018.
  1. May 7, 2018 at 3:09 PM
    rvhop
    rvhop [OP] New Member
    Rick
    2001 tacoma crew cab 4wd
    none
    Hello to all,
    I have a 2001 Tacoma 4wd. I want to take the fender flare off and paint them. I was taking the passenger side off. I removed the 2 10 mm fasteners, but the 3 small fasteners have me stumped. I cant find a socket or wrench to fit and there is no slots for screwdrivers. It looks like a small round hole in the center of the bolt heads. Any advice will be appreciated.
    Thanks, Rick
  2. May 7, 2018 at 4:50 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do you mean the red and blue plastic clips that snap the flair to the body?
    You're basically going to break those off as you pull them off (just yank).
    I just ordered a bunch of replacements off Amazon
  3. May 8, 2018 at 10:33 AM
    rvhop
    Rick
    none
    No these are metal screws with a washer 0r shoulder made on to them. I made have to cut them off. Thanks for your reply.
  4. May 8, 2018 at 11:02 AM
    jbrandt
    Justin
    Maybe a pic or 2 would help. I’m not sure what fasteners you’re talking about. My (factory) flairs, there are 4 or 5 screws on the inside of the fender, and a couple more bolts on the front/rear of the fender that attach to the bottom of the body, all 10mm bolts/screws.
  5. May 8, 2018 at 11:14 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Rick,
    Hope this helps.
