Fender Flare Fix Suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasonb, May 27, 2024.
  1. May 27, 2024 at 9:38 AM
    jasonb
    jasonb [OP] Well-Known Member
    Franklin, TN
    2012 TRD Sport 4x4
    SCS Ray10 Matte Gunmetal 16x8 w BFG KM3 285/75R16 Bilstein 5100 Shocks w 887 Coils, SPC UCA's, and Icon 1.5" AAL's
    Anyone have any ideas on how to fix/reattach my fender flare? Definitely looks like my truck was in an accident and the shop that did the repairs cut a lot of corners.
    When I pulled the flare off, there was only the one orange clip remaining. Then I'm not sure what the things the clips attach to in the flare are called, but all the red circles are for areas where one of those "things" belonged but was removed. The one blue circled "thing" is just broken.
    Open to any and all suggestions because I'd like to avoid buying a new flare from ebay for 300 bucks.
  2. May 27, 2024 at 10:05 AM
    Rickman1
    Rickman1 Member
    Rick
    Arizona
    2006 Speedway Blue TRD Sport Prerunner
    jasonb[OP] likes this.
  3. May 27, 2024 at 10:24 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Unfortunately you will need a fender flare. Definitely looks like there was body damage at some point.
    SR-71A and jasonb[OP] like this.
  4. May 27, 2024 at 10:32 AM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    Looks like your flare is pretty well broken , not sure a good fix...Maybe find a used one.....
    I got a set of after market flares off Extreme Terrain.com for cheap. Redrock was the brand and I got an open box discount $179 or something like that. The aftermarket ones don't use those clips. Also I painted the chrome bolts black.
    I had to do a lot of repairs at the time and I didn't want to skimp too much, so my budget was tight. I think I would have liked OEM flares better but I didn't want to pay the OEM price.... which for plastic pieces is down right robbery..
    My rear panel on this side has a similar dent. The flare does a good job covering it but there is a scratch it doesn't quite cover...Oh well....Good Luck!
    ScrippsRanch67 and jasonb[OP] like this.
  5. May 27, 2024 at 1:52 PM
    jasonb
    Franklin, TN
    2012 TRD Sport 4x4
    Yea it's looking like that's what I'll have to end up doing. I guess I'll just see if I can get lucky with craigslist, facebook marketplace, or the 2nd gen parts marketplace before committing to the ebay route.
    RockfordTaco2006 likes this.
  6. May 29, 2024 at 4:43 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    If you want to have a little DIY adventure, you can pick up a cheap plastic welding kit (basically a modified soldering iron with a bunch of different plastic filler rods) and some ABS stock of more or less the right thickness, and try to graft new tabs onto your flare. Then tape it in place with painter's tape, drill pilot holes from inside the bed, and put them on with christmas tree plugs from the inside. If you can't get it to work, you're out 15 bucks and learned something, and have a specialty tool around for whatever you might get up to in the future.
    I did it as an experiment/"temporary" fix and ended up running it for 4 years until I replaced it with knock-off Bushwhackers.
    Brangus likes this.
  7. May 29, 2024 at 9:16 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Lakeland Toyota
    Toyotaoverstock.com
    Genuine Toyota parts at better than other dealer prices.
    Steves104x4 likes this.
  8. May 30, 2024 at 6:20 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    flare is toast. I removed mine to rhino line them and broke a few of those off. I repaired them with strips of cotton soaked in CA glue as a quick fiberglass repair. But I had the pieces
    deanosaurus and Steves104x4 like this.
