Fender flare install on a non TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by poseytaco, Feb 25, 2012.
  1. Feb 25, 2012 at 8:12 AM
    poseytaco
    poseytaco [OP] Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    I have a 2000 non TRD and have a set of stock flares. They fit perfect but don't have the clips that come on a Trd. What is the best way to install these securely.
  2. Feb 26, 2012 at 10:00 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Call the dealer parts dept. see if thay sell just the clips. Thay should be able to. Good luck.:D
  3. Feb 26, 2012 at 10:58 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    The dealer has the clips there red's and blues they go in designated slots in the fenders, there are from what I remember on my 04 7 per wheel hsg, and there about $1.50 a clip. When I replaced mine I inserted them in the fender first I would do it different if I were to do it again, install them in the flare first. I thought I had a picture from when I did mine that showed where each clip went but I deleted the pic.Buy a few extra's in case you mess up.
  4. Feb 26, 2012 at 2:31 PM
    GVY
    GVY All those moments will be lost in time
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    Bushwacker Cut-Out Fender Flares, ARB Winch Bull Bar, 3" All Pro Bilstein Coilovers, All Pro UCAs, Wheeler Off Road Custom Rear Bumper, All Pro Standard Leaf Pack, Bilstein 5125 rear shocks, All Pro steel-braided brake lines, U-Bolt flip kit, JBA cat-back exhaust, KC 6" Daylighters & 2x6" driving lights, AFE Pro Dry Air Filter, Deck plate mod, Toytec 1" shackles, Rhinolined bed, Tiregate Prerunner, Procomp 85 gloss black steel wheels, 285/75/16 Toyo Open Country M/Ts
  5. Feb 27, 2012 at 6:47 AM
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    My truck is not a Trd. It doesn't have slots in the fenders.
  6. Feb 27, 2012 at 11:06 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Well the TRD trucks with factory flares have square holes if you don't have the holes best look for another type flare and sell what you have.
  7. Apr 7, 2013 at 10:06 PM
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I really wanna put flares on my 98. I can get them off an 02 I like the big ones. Is there a way to mount these or has any one done this
  8. Apr 7, 2013 at 10:35 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    don't believe it has anything to to with being TRD.
    2001 I believe is the first year with
    fender holes in the sheet metal, for the flares.
    prior to '01...
    aft. mkt or factory flares mounted to the inside lip
    of the fender. The upper side of the flare stays in place
    simply from mounting inside the fenders lips.
    The fronts utilize metal clips w backing nuts...
    the rears simply mount to predetermined fender lip locations
    that have plastic inserts that are threaded into.
    Muh '00 came with the chrome eyebrow wheel well surrounds.
    those use the same mounting hardware that most fender flares
    would use as well.
    In other words...
    if you go to a dealership and look up the chrome wheel well eyebrow
    mounting... you would need order that mounting hardware.
    So you have nothing mounted to the fender wells currently ?
  9. Apr 7, 2013 at 10:46 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    I had the little basic chrome sr5 but wanna put big flares on f newer tacoma. I know they had clips in the sheer metal but can I get away with mounting just the wheel well mounts?
  10. Apr 8, 2013 at 1:05 AM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I don't know if '01-'04 fender flares
    will bolt up to earlier models.
    so can't say
    but if you try... you'll know more
    if yer not afraid of it...
    you could cut some holes in the fender(s)
    to fit the inserts. (likely a pita)
  11. Jun 1, 2013 at 11:24 PM
    michaelw.grey
    michaelw.grey Well-Known Member
    mike
    pensacola, florida
    98 4x4 SR5 3.4L V6 AUTO Ext Cab
    Full ome kit with 882's,icon uca's, line x bed, 32" bfg muds, 2nd gen rims, low pro tool box,
    so did you cut the holes? did it work? ive been wanting to do the same to my 98 as well. Please let me know how it turns out.
  12. Jun 7, 2013 at 12:52 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    yeah on my 2000 the flares are just screwed into the inner fender wall. they're also less...flarey, than the 01-04 flares. i actually removed mine to repaint and they went back on like a charm i think it was a smarter design on toyota's part because i can revert to complete stock body if i want (not that the fenders werent stock) without any clips or holes glaring back at me.
  13. Jun 8, 2013 at 12:02 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Why is there a need for the square holes and clips? I pulled the flares off my 2001 to paint them and never put the red and blue clips back on. They are only held on by the screws in the fender well and it's been that way for about a year now without problems. :confused:
  14. Jun 8, 2013 at 11:26 PM
    michaelw.grey
    mike
    pensacola, florida
    how did the bushwackers mount? and how much were they?
  15. Jun 8, 2013 at 11:28 PM
    cbassd
    cbassd Member
    sebastian
    Nor cal Davis
    02 tacoma
    tc uca, 2.5 icon coilovers with resis, trd supercharger,flow master,u-bolt flip kit,,, all-pro standard pack leaf springs,10 inch travel 2.0 fox shocks with remote resis,21inch led bar,ham and cb radio,4xinnovation sliders, custom from bumper, prp bucket seats and deist 5-point harness
    i cut mine with a disk blade
