Fender Flare popped off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter500ky, Feb 9, 2011.
  1. Feb 9, 2011 at 9:05 PM
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Ok so I got out of my truck today after normal driving.
    I look at my driver side front fender flare and notice it is not right.
    I examine it closer and notice the front towards the bumper had come undone popped off.
    I dont think warranty covers this and honestly I dont care to pop it back on myself.
    I tried to pop it back on but it doesnt want to go is there a trick to it or what?
    Anyone know, I was going to climb up under the fenderwell to look at it and what not but its like 6 degrees out and 3" of snow on the ground so figured I would ask TW for help.
    Thanks!
    Edit also any reason it would pop off by it self? It does not look like anyone hit me
  2. Feb 10, 2011 at 7:12 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    anybody have any ideas?
  3. Feb 10, 2011 at 7:16 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just push it back in, it's only held in there with little plastic clips
  4. Feb 10, 2011 at 7:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I washed my truck a couple weeks ago and noticed a couple of my plastic clips have fallen out. Probably what happened to yours. I'll be looking into finding new clips or replacing them with something once it gets warmer and I can work on my truck again.
  5. Feb 10, 2011 at 9:10 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    I tried that....
    gotcha what are those clips called so I can pick some up.
  6. Feb 10, 2011 at 9:56 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Thats affirmative, double checked it this morning all ice has been removed.
  7. Feb 10, 2011 at 10:02 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    those tabs and clips break super easy. It's possible that they broke and fell off the truck while driving. That may be why u cant push them back in, because theyre not even there.
  8. Feb 10, 2011 at 10:06 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Makes sense, thank you very much.
    It's not that big of a deal, just a eye sore.
  9. Feb 10, 2011 at 10:27 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    They're called plastic push rivets or fasteners.
    They come in all variety of sizes. I recently went to the auto store and bought a couple packs for my truck. I was missing them in varying locations myself. There are also screw rivets on our truck. Check your other panel to see which one and size you need.
    Just one example:
  10. Feb 10, 2011 at 10:33 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Cool thanks when it warms up Ill look at it.
    SO another dumb question.....
    Im guessing the whole flare just pops straight off? Like pull straight out? Then it should pop off so I can fix the broken one?
  11. Feb 10, 2011 at 10:33 AM
    especk
    Erik
    Redding, CA
    actually they look just like this. Alternating blue ones and orange ones. Atleast this is what they look like on my 2010 when I removed my fenders last weekend.
  12. Feb 10, 2011 at 10:36 AM
    especk
    Erik
    Redding, CA
    not really. If you just try to pull it straight off, you will break all of those clips and/or fender tabs. When I did it, I had to jack the truck up, remove all the tires, remove the big plastic mud gaurds that are in between the fenders and the truck, and only then did I have access to the clips so I could remove the fenders. You need to squeeze the clips with neddle-nosed pliers and then push them out.
  13. Feb 10, 2011 at 10:38 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    And this is why I asked lol thanks!
  14. Feb 10, 2011 at 10:41 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  15. Feb 10, 2011 at 10:45 AM
    especk
    Erik
    Redding, CA
  16. Feb 10, 2011 at 10:49 AM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
  17. Feb 10, 2011 at 1:55 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    If you have any broken spots where the clips go in the flair there is a great fix. I bought all new clips and found there were busted out sections where they attach to the flair. Use 100% Silicone and attatch the flair. Tape it well with masking tape and leave over night. It's going nowhere now. BTW ....the black one's at the $tealership are $303. !!
