Fender Flare Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lumberjack7, Nov 14, 2016.
  1. Nov 14, 2016 at 8:34 AM
    lumberjack7
    lumberjack7 [OP] Well-Known Member
    Central Massachusetts
    Hi TW Friends,
    I'm looking to take off a damaged Fender Flare on my 17 DBCAB Sport and I'm curious about if the Flare is held on with any 2 sided tape and/or adhesives?
    Also are they held together by bolts or are there clips or both? How easy is it to remove and replace?
  2. Nov 14, 2016 at 8:45 AM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    lumberjack7[OP] likes this.
  3. Nov 14, 2016 at 9:02 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    oem flares are mounted with screws and holes. think the rubber edge you see is just an insulator.
  4. Nov 14, 2016 at 9:04 AM
    Soccer Mom
    Soccer Mom Well Endowed Member
    2017 MGM SR5 DCSB
    METHOD | SOS | C4 | RIGID | PRINSU | OME | TC
    It is definitely sealed with a two sided tape adhesive strip. It is easy to get off the fenders but very difficult to get off the inside of the fender flare. IIRC the dealer quoted me $70 per fender flare for replacement adhesive tape
    It is also held together by orange and blue clips. You will break some when you are pulling the flares off. They are expensive at the dealer but I got replacements from NAPA for half the price
  5. Nov 14, 2016 at 9:08 AM
    brich999
    Bryan
    all tore up already
    i think mine forgot the adhesive seal, i can peel mine back and see gaps in there. well i could before i applied some 3m weatherstrip adhesive
  6. Nov 14, 2016 at 9:58 AM
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    2-3 screws on each, double-side adhesive + a ton of blue little clip that snap it in place, just remove the screws and pull very hard on the flare begining from one side and one clip at a time.
    https://www.tacomaworld.com/threads/black-fenders.399390/page-4#post-13307041
