Fender Flare separating from Body
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pittrider, Feb 23, 2016.
  1. Feb 23, 2016 at 2:58 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    The very first sport dclb that came in at my local dealer had this happening. I know on the 2nd gens there is a rubber gasket between the flare and the body, the 3rd gen just has 2 sided foam mounting tape. I can picture dirt and crud getting all in there.
  2. Feb 23, 2016 at 3:20 PM
    Pittrider
    Pittrider [OP] Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    You can see the foam in the first picture starting to pull away from the metal near the top (above where it already has). Was wondering if it could be caused by temperature swings, but hasn't been too drastic here so discounting that. Maybe not enough pressure put on it at assembly, or the tape was touched by something that caused it to lose some strength, like a Texan's finger touching it! :)
  3. Feb 23, 2016 at 5:45 PM
    crepr12
    crepr12 Well-Known Member
    2016 TRD Sport AC 4x4 V6 Manual
    Hmmmnn...Checking my flares in the am
  4. Feb 23, 2016 at 5:54 PM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Stopped by the dealer on the way home and had them have a look and put a note on my account.
    Service advisor talked to warranty manager, all good, they'll fix it at next service. That's not until June, so I'll keep an eye on it.
    scottalot likes this.
  5. Feb 23, 2016 at 9:36 PM
    justintackitt
    justintackitt Well-Known Member
    2016 Tacoma DCTRD4X4
    I was thinking JB weld
    TOY33 likes this.
  6. Feb 24, 2016 at 2:16 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Maybe Toyota will iron out a solution for the 2026 models before the 4th gen.
  7. Feb 24, 2016 at 2:38 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Maybe there should be clips too? Tape, really?
    12TRDTacoma likes this.
  8. Feb 24, 2016 at 3:17 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    You have no idea how ''sticky'' some of the new adhesive tapes are. If installed correctly, they are far superior to holes in the body that tend to be rust spots waiting to happen.
    [My son is a chemist that makes some of these tapes, I've played with some he was working on, they are very strong IF the surfaces are prepped correctly and the tape isn't contaminated when applying.
  9. Feb 24, 2016 at 3:19 AM
    ZachMX
    The 2nd Gen had clips along with the adhesive that were plastic so no rust and extra set of protection from separating.
  10. Feb 24, 2016 at 3:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah, I'll take the clips and someone else can trust stuff just all taped together. If you live in a rust zone, tape will not save you. The frame will obviously rust out before the fenders will on these trucks anyway.
  11. Feb 24, 2016 at 3:31 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    No one knows what ideas I have other than me & take a look at some of the crash pics of 16s that've been posted up, that "sticky" tape popped right off. If it was as good as you want me to believe, it would have stayed stuck to the crashed fender. Adhesives and fasteners are NOT universally substitutable. They can work in conjunction with another to be better than either is individually but if only using one or the other, fasteners FTW............just another manufacturing cheap out.
    12TRDTacoma and ZachMX like this.
  12. Feb 24, 2016 at 8:37 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The 2016 uses the same number of clips to hold the flares on as the 2015 did. They didn't switch mounting methods. They're not just held on with tape.
    Jeff
  13. Feb 24, 2016 at 8:51 AM
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    Maybe they forgot to tape my engine, and that's why it's so slow? :notsure:
  14. Feb 24, 2016 at 8:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They don't build them like they used to is the first thought that comes to mind.
    Along with adhesive with the clips? What the hell are you talking abuit? My 2012 just had clips on the flares and that's it.
  15. Feb 24, 2016 at 10:00 AM
    #35
    fxntime
    Auto manufacturers have been using tape only for many years. Dodge was doing it at the turn of the century and I never saw many falling off. Considering they actually use adhesives to glue supercars together nowadays, some wimpy pound of plastic doesn't cause any issues IF the surfaces are prepped correctly. Smutz, oil, silicone or some other material like those is enough to cause lack of adhesion.
    I've put flares on with just tape, 13 years later, they were still on without an issue. I think people might be shocked at what is held together now with adhesives. [including some Toyota door skins]
  16. Feb 24, 2016 at 2:55 PM
    #36
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    More like dismayed. Glued hoods and taped doorskins and plastic motors all for 8x what the really good Toyota trucks used to cost. Whoopie!
    schmack b likes this.
  17. Feb 24, 2016 at 3:10 PM
    #37
    ZachMX
    My bad, the gasket or whatever it is that mates the two. chill bro.
    12TRDTacoma[QUOTED] likes this.
  18. Feb 24, 2016 at 3:24 PM
    #38
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nochill bro. Jk jk. Not mad at all. I was about to be upset at the fact that Toyota didn't include what you were talking about on mine. Not you at all.
    ZachMX[QUOTED] likes this.
  19. Feb 24, 2016 at 6:51 PM
    #39
    Northern Taco
    -30 one morning here and +12 the next, plays havoc on tape.
    The foam tape could be compressed when I pushed on the flare. The 2nd gen had a nice rubber gasket to keep crap out of the seem, and just looked more finished. My $0.02
    A lot of Polaris snowmobiles are bonded together with adhesive (aluminum parts)
  20. Feb 24, 2016 at 8:56 PM
    #40
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    I owned a 2nd Gen too, so I would have to agree. Seems it was a better fit to me, and although not disappointed, seems like the earlier versions "probably" would have less issues. Not really sure, but as long as it gets fixed, it's all ok by me.
