fender flares fitment
Discussion in '1st Gen. Tacomas (1995-2004)' started by felotacoma, Aug 10, 2010.
  1. Aug 10, 2010 at 8:05 PM
    felotacoma
    felotacoma [OP] Active Member
    felipe
    miami
    99 PreRunner SR5
    hello guys, question on fender flares:
    would the OEM 2000-2004 fender flares fit my 99 sr5 tacoma? they seem a bit bigger than the OEM for a 99 let me know thanks.
  2. Aug 10, 2010 at 9:45 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    FYI the 01-04 flares are bigger/wider than the 98-00 flares. The 98-00 flares are like the size flares that come on S-Runners & Stepsides. Not for sure but as far as fitment I think thay are all the same except for the rear stepside flares.
    Also the stock 01-04 flares from Prerunners & 4WD are mainly held on with clips. The holes for the clips on the body are square so simply drilling holes to install these clips is not possible. Plus the clips are pretty expensive. Not sure how the stock flares for 98-00 & S-runners are attached.
    To install the stock looking flares on a Tacoma that did not come with flares, what you want to look for are the TRD flares, these bolt on by drilling holes. Or get some Bushwacker flares, the street style or OE style flares look like the stock ones, they're probably cheaper than the TRD flares too.
  3. Aug 10, 2010 at 10:38 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Personally, I'd look at some aftermarket flares. Junglefenderflares.com or bushwacker.com It'll end up costing a bit less than factory new, unless you found someone selling used for pretty cheap.
  4. Aug 11, 2010 at 3:43 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    YES, They "WILL" fit with NO issues. I had my 2000 factory flares on my 2003. The older ones are smaller like said above, but they do bolt right on and fit perfect....;)
  5. Aug 11, 2010 at 6:13 AM
    04prerunner
    04prerunner Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
  6. Aug 11, 2010 at 12:52 PM
    3fitty
    3fitty Well-Known Member
    Lambone
    Gulf Coast
    01 Prerunner
    Bilstein 5100 front, 5125 rear and Skyjacker AAL. Manaflow Catback exhaust. aFe Pro-Dry air filter.
    So what kind of 2003 Tacoma did you have? Was it Prerunner or 4WD? Stepside? We know for a fact that the 2000 factory flares are too small to cover the "square" holes on our Prerunner and 4WDs. The Stepside flares look more like the 2000 TRD flares.
  7. Aug 11, 2010 at 1:07 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    x2, theres no way they cover those holes
  8. Aug 11, 2010 at 6:36 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    How about the larger Bushwacker "Cut-Out" flares?
  9. Aug 11, 2010 at 7:13 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    unfortunately they dont fit the Double cabs :( but either way those are a little to big for my liking
  10. Aug 11, 2010 at 7:28 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Thanks for the info. Wasn't interested in them myself, just wondering. Is it just those flares specifically? I thought all the stock flares were the same from single, extra, & double cabs?
  11. Aug 12, 2010 at 6:46 AM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    on our Dcab's, theres not enough room for the (cut-out-style) fender from bushwacker to fit. (it would hit the rear door). that style fender is for the ext cabs and reg cabs only
