Fender Flares
Discussion in 'Wheels & Tires' started by tacomagirl_09, Aug 25, 2008.
  1. Aug 25, 2008 at 11:04 PM
    tacomagirl_09
    tacomagirl_09 [OP] Member
    Utah
    '96 LX Toyota Tacoma
    4" Pro Comp Lift Kit, K&N Cold Air Intake, Powerade Throttle Body Spacer, Jardine Performance Exhaust, Tow Package, 8" MTX Subwoofer, Cut-out Bushwacker Fender Flares.
    Today my tacoma didnt pass safety inspection because my tires are too wide.. They told me to go get fender flares. I measured from the wheel well to the edge of my tire and that is 7" inches! Those are going to be some long fender flares and it's going to look gay!! What should I do? i love my rims and my bf goodrich mud terrain tires! Should i get the stupid fender flares so i dont get pulled over and fined or is there any other alternatives?
  2. Aug 25, 2008 at 11:07 PM
    Swwacoma
    Swwacoma Doomsday Squad
    Estero, FL
    08 PreRunner SR5.
    Get some cheap flares just so you can pass inspection and then take them off. Closet them until your next inspection.
  3. Aug 25, 2008 at 11:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check out some bushwacker fender flares.......they look really good. or.......do what swwacoma said and get a cheap set just for inspections. by the way....welcome to tw!!
  4. Aug 25, 2008 at 11:10 PM
    tacomagirl_09
    Utah
    and where might i get cheap ones?
  5. Aug 25, 2008 at 11:11 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    welcome to the forum!
    Try here
    Bushwacker Fender Flares - Cut-Out
  6. Aug 25, 2008 at 11:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for cheap....try ebay.
  7. Aug 25, 2008 at 11:12 PM
    tacomagirl_09
    Utah
    do they make them 7" wide? thats a lot of tire to cover
  8. Aug 25, 2008 at 11:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it would be close enough for the leo not to notice it or pay any attention to it.
  9. Aug 25, 2008 at 11:16 PM
    tacomagirl_09
    Utah
    i wont have to drill into the side of my taco will i? how exactly do they put them on?
  10. Aug 25, 2008 at 11:18 PM
    neontrail
    Idaho
    Cut-Out Fender Flares install using set-screws or factory bolt locations -some drilling or cutting may be necessary depending on your specific vehicle
  11. Aug 25, 2008 at 11:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats gonna be the drawback.....drilling is required. here is the instruction sheet for the bushwacker cut out style flare.
    http://www.bushwacker.com/Instructions/31919a.pdf
  12. Aug 26, 2008 at 12:02 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Couldn't she use double sided tape. Or glue magnets on the fender flares. Pull up near the station, put them on. After passing inspection, get out of their line of site & remove them.
  13. Aug 26, 2008 at 12:04 AM
    genxer36
    Sean
    Bethlehem,GA
    I can't believe they are nit picking you on tire size.
  14. Aug 26, 2008 at 12:05 AM
    Swwacoma
    Estero, FL
    08 PreRunner SR5.
    Exactly what I was thinking. Double sided tape can work wonders.
    I don't, however, know much about fender flares and what would be considered cheap. Go to Walmart and make your own, lol. Creativity at its best.
    Welcome to the board, btw.
  15. Sep 1, 2008 at 5:17 PM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    what do u have to pass an inspection for?
  16. Sep 1, 2008 at 5:24 PM
    Swwacoma
    Estero, FL
    08 PreRunner SR5.
    Certain states require inspections every x amount of years to make sure your car falls with in certain predetermined criteria. Guess its meant to keep the roads safe and such.
  17. Sep 1, 2008 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you are happy with the way your truck looks, screw the flares. Borrow a set of stock wheels and tires from a nearby member, go get inspected, pass, put the larger ones back on. :D
  18. Sep 1, 2008 at 5:28 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    x2
  19. Sep 1, 2008 at 5:32 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    +++My thoughts exactly!
  20. Sep 2, 2008 at 3:31 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Yeah, F the man :D
