Fender plastic pitting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by greez82, Feb 28, 2017.
  1. Feb 28, 2017 at 2:29 PM
    greez82
    greez82 [OP] Shreddin the gnar
    Adam
    So Cal
    2017 Quicksand DCLB TRD OR 4x4
    Good point need to look into some sliders, wonder if those will help.
    Kvanriper likes this.
  2. Feb 28, 2017 at 2:32 PM
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    My concern about plastidipping is it's only a temporary solution.. It's going to keep happening. I know the solution finish might just dye it, but it makes sense that dyeing the pits could make them much less noticeable. But again, not a final solution.
    Realize the running boards will stop it but I'm not much of a running board fan... It probably also costs less to get new back fenders after some time than it does to get running boards...
  3. Feb 28, 2017 at 2:35 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Problem is with mud flaps is my tires will knock them off. Won't last a day off road! Not a big fan of mud flaps either...
    I know you can put a satin bra over them. Basically a matte sheet of plastic that you'd never be able to tell was on there. Only problem with that now is my fenders are too pitted to put one on. Putting on a bra now would just make things worse.
  4. Feb 28, 2017 at 2:37 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    I haven't used it yet. Check the reviews on Amazon or ask there from the folks who've used it.
  5. Feb 28, 2017 at 3:28 PM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Besides the clips I think the flares use double-sided tape, you have to retape before putting them back on
  6. Feb 28, 2017 at 3:53 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    TRD sport has paint film installed on the leading edge of the rear flares to prevent this.
    Gustavoo700 likes this.
  7. Feb 28, 2017 at 3:54 PM
    greez82
    Adam
    So Cal
    My OR has paint film also
  8. Feb 28, 2017 at 3:56 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    For a long term fix, I'd have it bedlined.
    Not pretty. But, far more effective than any alternatives.
  9. Feb 28, 2017 at 3:59 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Plasti dip them and you'll be fine.
    over60 and greez82[OP] like this.
  10. Feb 28, 2017 at 4:03 PM
    GPsevinSixx
    Ros Angerus
    You'll need something closed off on top and not open as typical sliders are.
    over60 likes this.
  11. Feb 28, 2017 at 4:05 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    I have color matched flares with 2000 miles and it looks the same as OP but black underneath the paint obviously. I was mad but what can you do lol shitty paint I guess! It honestly feels like they put the thinnest coat of paint on these new tacomas. :frusty:
  12. Feb 28, 2017 at 5:30 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    It's not shitty paint in my opinion... it's the rocks/sand/etc that you are throwing against your paint every time you drive... The paint cannot take that and look new forever....
    Either, protect it from new, or stop the shit from hitting there...
    Very simple... You don't like running boards & mud flaps that's, OK, but get used to your paint job looking like shit..!!
    Can't drive a Corvette Off Road and expect it to look Showroom when you get home...!!
  13. Feb 28, 2017 at 8:09 PM
    QuicksandTaco
    Cody
    Oregon
    Yeah we get that. But after 2 months and 2000 miles, paint chipping and pitting like that is absurd. I had a Dodge Ram an 35's that stuck out much further for years without the paint looking "sand blasted" I put 50k miles on it without issues! So in my opinion, yeah the paint job on the plastic fender flares of the Tacoma are shit. They should've put more thought into it. In my opinion. Which they don't care about anyway haha.
    jake slatnick likes this.
  14. Feb 28, 2017 at 8:27 PM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    The paint on these trucks is shit. You are absolutely right.
    I've heard and seen the black trucks have the thinnest little coat of black you could ever imagine.
  15. Feb 28, 2017 at 8:59 PM
    #35
    greez82
    Adam
    So Cal
    The reason I posted this was because I couldn't see how the edge of the rear fender is getting blasted so badly, it does not look like it should be getting hit where it is.
    I am frustrated because it is a fairly large area that is completely pitted from 15 or so miles of off roading. My truck has 3500 miles. I have owned numerous off road vehicles and I am no stranger to trail damage especially rock chips. Again this is happening very aggressively in a specific spot, there is a 8-9 inch section that is pitted really bad. As mentioned before I have mudflaps and my truck is stock. Based on the location of the area that is being affected, it does not look like it should be subject to debris from the front wheels but I can't imagine where else it would be from.
    I am hoping plasti dip will help protect and not get too damaged but thinking about how quickly it got blasted the dip will likely be a very short term fix and need to be constantly re-applied. Im hoping someone smarter than me will think of something. Of course I can always just let it get pelted for a while and maybe replace the fenders down the road. It just doesn't seem right that after 15 mellow miles of off-road fire trails that there should be that much damage............ :annoyed:
  16. Feb 28, 2017 at 9:05 PM
    #36
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My old 2000 started looking like that after 6 or 7 years of use, the material must not be as durable today.
  17. Feb 28, 2017 at 9:08 PM
    #37
    greez82
    Adam
    So Cal
    I may be wrong but the plastic seems pretty standard. To get pitted the way it has in this short amount of time it must be getting a heavy stream of abrasive dirt, rocks, etc from the front wheels. I would understand if I was doing high speed pre running. It doesn't make a whole lot of sense
    shakerhood[QUOTED] likes this.
  18. Feb 28, 2017 at 10:26 PM
    #38
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    I have the same issue. My fenders are in absolutely terrible shape after one off roading trip.
    shakerhood likes this.
  19. Feb 28, 2017 at 10:44 PM
    #39
    SnowFarmer
    SnowFarmer I intend to live forever, or die trying.
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    I lived in the Sierra for many years and drove a 92 Extracab 4x4, I never really noticed but at the end with no mud flaps, I had stripped the paint to primer behind the wheels. All from CalTrans using the volcanic sand as grip during the snow months. That stuff is Brutal.
  20. Feb 28, 2017 at 10:46 PM
    #40
    Getskyhigh
    Getskyhigh @el_yota_
    Fernando
    2016 MGM Tacoma TRD OR 4x4 MT
    Mines got the same thing
