Fender Trims/Suspension Installs 909/626
Discussion in 'Southern California' started by greenEFSI, Feb 12, 2020.
  1. Jan 11, 2021 at 8:42 AM
    #81
    greenEFSI
    greenEFSI [OP] TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    2005 Tacoma:
    2” Fender Trim
  2. Jan 11, 2021 at 8:51 AM
    #82
    greenEFSI
    Gio
    West Covina, SoCal
    2000 4Runner Build Progress:
    OEM Rear Hatch Shocks
    OEM Shifter Bushings
    OEM Rear Brake Drums
    OEM Rear Brake Shoes
    OEM Alternator
    Optima Yellow Top Battery
    JDM Corner Lights
  3. Jan 18, 2021 at 9:11 AM
    #83
    greenEFSI
    Gio
    West Covina, SoCal
    2020 Tacoma TRD Pro:
    Rear Fender Trim (Front was done a while ago)
  4. Jan 18, 2021 at 9:23 AM
    #84
    greenEFSI
    Gio
    West Covina, SoCal
    My Tacoma Build:
    I tore the front end apart 3 weeks ago and did a complete overhaul!
    OEM Axle Boot Kits
    OEM Front Diff Seals
    OEM Inner Tie Rods
    OEM Inner Tie Rod Jam Nuts
    OEM Inner Tie Rod Boots
    OEM Inner Tie Rod Boot Clamps
    OEM Outer Tie Rods
    OEM Secondary Brake Pad Spring
    Whiteline LCA Bushing Kit
    Whiteline Steering Rack Bushing Kit
    Marlin Crawler LCA Gusset Kit
    Total Chaos Cam Tab Kit
    Total Chaos Spindle Gusset Kit
    Custom LCA Bushing Reinforcement
    FK Uniball UCA Bearings
    Fabtech UCA Bushing Kit
    Dirt Logic Lower Coilover Bearings
    Sankei 555 Lower Ball Joints
  5. Jan 23, 2021 at 4:13 PM
    #85
    greenEFSI
    Gio
    West Covina, SoCal
    Mista_G, mightytacoman and G-shock! like this.
  6. Jan 25, 2021 at 5:29 AM
    #86
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    How is the blue paint marks holding up during the install? Goes on the gears hard I can tell ya
  7. Jan 25, 2021 at 6:26 AM
    #87
    greenEFSI
    Gio
    West Covina, SoCal
    It’s good! I didn’t have any come off or smear during install :thumbsup:
    mightytacoman[QUOTED] likes this.
  8. Feb 5, 2021 at 10:13 AM
    #88
    greenEFSI
    Gio
    West Covina, SoCal
    2019 Tacoma:
    Safari Snorkel Install
    bulalo likes this.
  9. Feb 8, 2021 at 2:04 PM
    #89
    greenEFSI
    Gio
    West Covina, SoCal
    Toyota 4Runner:
    Front Fender Trim
    mightytacoman likes this.
  10. Feb 20, 2021 at 5:18 PM
    #90
    greenEFSI
    Gio
    West Covina, SoCal
    2015 Tacoma TRD Offroad @Image976:
    @mightytacoman -3° Exhaust Cam Gears
    Oem Seals
    Oem Spark Plugs
    Cleaned throttle body
    Cleaned maf sensor
    Safari Snorkel
    SilverSurfer and bulalo like this.
  11. Feb 22, 2021 at 8:23 AM
    #91
    greenEFSI
    Gio
    West Covina, SoCal
    2019 Tacoma TRD Offroad:
    Resi Adjustable Front and Rear King's
    SPC UCA's
    ECGS Bearing
    Carrier Bearing Drop
    Extended Brake Lines
    Headstrong Rear Add-A-Leaf and Mini Block
    Summit Wheels and Toyo Tires
    CementMixr likes this.
  12. Mar 1, 2021 at 11:05 AM
    #92
    greenEFSI
    Gio
    West Covina, SoCal
    2019 Tacoma TRD Pro:
    Wescott 1.5" Spacer Lift
    Icon Progressive Rear Add-A-Leaf
    Wheelers F&R Superbumps
    Wheelers U-Bolt Flip Kit
    Matt Gecko LED Bed Light Kit
  13. Mar 4, 2021 at 6:13 PM
    #93
    greenEFSI
    Gio
    West Covina, SoCal
    2015 Tacoma TRD Offroad 6spd Manual:
    @JustDSM HP Tune
    jojotoo likes this.
  14. Mar 6, 2021 at 10:58 PM
    #94
    greenEFSI
    Gio
    West Covina, SoCal
    2016 Tacoma TRD Offroad 6spd Manual:
    ECGS Bushing
    Clutch Accumulator Delete
    Duro Bumps Front and Rear
    U-Bolt Flip Kit
  15. Mar 8, 2021 at 7:46 AM
    #95
    greenEFSI
    Gio
    West Covina, SoCal
    Koyo Transmission Cooler
    Custom Stainless Hardlines with AN Fittings
    OEM JDM Window Visors
    Scangauge
    OEM JDM Upper Console Modified
    Edit: Scangauge Mounted with JDM Upper Console
  16. Mar 8, 2021 at 10:41 AM
    #96
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    jojotoo and greenEFSI[OP] like this.
  17. Mar 8, 2021 at 11:12 AM
    #97
    greenEFSI
    Gio
    West Covina, SoCal
    Thanks! The last parts for it come in today. Once that's mounted up, he will be all set for a Moab trip :cool:
    jojotoo likes this.
  18. Mar 12, 2021 at 8:28 AM
    #98
    greenEFSI
    Gio
    West Covina, SoCal
    Tacoma TRD Offroad:
    @JustDSM HP Tune
    (Previously Trimmed Fenders)
    jojotoo and G-shock! like this.
  19. Mar 13, 2021 at 4:39 PM
    #99
    greenEFSI
    Gio
    West Covina, SoCal
    2015 Tacoma TRD Sport:
    Bilstein 5100 F&R Install
    Front Set at 3rd Perch
  20. Mar 13, 2021 at 4:40 PM
    #100
    greenEFSI
    Gio
    West Covina, SoCal
    SilverSurfer and mightytacoman like this.
