Fender/wheel arch rub possible fixes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by narkohleptic, Oct 31, 2017.
  1. Nov 6, 2017 at 1:34 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I just had 265/75/16 WildPeaks installed. I ended up with 2.2 deg caster on the left side and 1.7 on the right which solved "most" of it. I had some rubbing at the rear of the front fenders like you, which I trimmed with some snips (which I will clean up with dremel at some point). I've driven it around a few times since trimming all is good so far. I did a few things with the liner which I need to photo and post. But basically added a tapping metal screw near the 10 o'clock section of the wheel well liner ( if the front bumper is at 9 o'clock ). Good luck with it.
