Fernando's 2004 DC! "THE TANK" Got Juanton Soup!
Discussion in '1st Gen. Builds (1995-2004)' started by Fernando, Jul 8, 2013.
  1. Nov 8, 2020 at 1:21 PM
    #2061
    Fernando
    Fernando [OP] Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Hoodie weather!
  2. Nov 8, 2020 at 1:29 PM
    #2062
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I use the crawl box in low and rear case in high all the time. My crawl in the 2.28 so I use it to get between trails and in the dunes and personally think it takes to much throttle input for a lot of control crawling. 4.7 for crawling. Double low is to much for the auto personally and can count on both hands how many times I’ve used it (made it harder than just using the single 4.7)
    I’m constantly shifting in and out of 4wd to 2wd and vice versa. Takes unneeded stress off the front when in 2wd between big obstacles.
    crawl box and transfer case should be toward is low. Middle is nothing and back is high. 4wd is just two positions 4 or 2. If you put the tcase or crawl box in newuteal nothing will happen and it’ll grind like crazy trying to shift out of it after trying to drive without turning the car off in my case lol.
    Fernando[OP] likes this.
  3. Nov 8, 2020 at 1:48 PM
    #2063
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Man....i got some bad info from dude. :duh:
    Thanks @malburg114 for taking the time to explain :cheers:
    malburg114 likes this.
  4. Nov 8, 2020 at 1:50 PM
    #2064
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Which is why I tell everyone with an auto that 2.28 is perfect. Once you take into account the torque converter it basically doubles the crawl ratio. With 2.28 and 2.57 I've never once felt like I wished I had lower gearing on hard obstacles.
    On another note, snow wheeling was a joke. Had about 2" at 6000' and about 3" at 8800'. At least it was an 1 1/2 hours out of the house. lol
    malburg114[QUOTED] likes this.
  5. Nov 8, 2020 at 2:09 PM
    #2065
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks to all you guys. I went out and played with it again. Feeling more comfortable with the sticks (thats what she said). This thing is so badass.
    Man, im glad i stayed home then. Lol. Hopefully we get some good stuff soon and we can go play bro
  6. Nov 8, 2020 at 7:38 PM
    #2066
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I've noticed that grinding as well. In the crawlbox switching from low to high, it'll grind every now and then when the truck isn't moving and transmission is in neutral. I have HD detent springs, and try to shift slowly but still happens which I think is kinda weird since nothing should be spinning?
  7. Nov 8, 2020 at 8:06 PM
    #2067
    malburg114
    Las Vegas, NV
    I just push it fast and hard and no issues. Or turn the truck off and do it.
  8. Nov 8, 2020 at 8:08 PM
    #2068
    malburg114
    Las Vegas, NV
    I think anything more than 5:1 is to much with the auto but that’s me personally. I know plenty of people who wheel 2.57 with an auto with no issues. My dad has been wheeling an atlas 3.8 with a manual in a jeep for years and gets down lol
  9. Nov 9, 2020 at 6:21 PM
    #2069
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ok...maybe last question again....can i shift on the fly from 2wd to 4wd like i use to or will that make bad noised?
  10. Nov 9, 2020 at 6:22 PM
    #2070
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Only if your front hubs are locked. If you have everything hooked up on the factory case sensor wise you should be GTG.
  11. Nov 9, 2020 at 6:33 PM
    #2071
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I used a 12 volt electric blanket on my last couple trips.
    Shit was amazing!
    In 17 degrees it was almost too warm in my sleeping bag.
    Sure it draws 6 amps but I have 230 ah of battery.
    rob1208 and Fernando[QUOTED][OP] like this.
  12. Nov 9, 2020 at 6:55 PM
    #2072
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I dont have manual hubs
  13. Nov 9, 2020 at 6:55 PM
    #2073
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    That sounds amazing!
    otis24[QUOTED] likes this.
  14. Nov 9, 2020 at 6:55 PM
    #2074
    slander
    Hickory, NC
    Does the ADD still.work?
  15. Nov 9, 2020 at 6:56 PM
    #2075
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I would assume yes :notsure:
  16. Nov 9, 2020 at 6:57 PM
    #2076
    slander
    Hickory, NC
    Then yea the 4wd should still work as factory. Did you extend the wires on all the sensors?
  17. Nov 9, 2020 at 6:59 PM
    #2077
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Yes. Those were extended
    slander likes this.
  18. Nov 9, 2020 at 6:59 PM
    #2078
    slander
    Hickory, NC
    Then you should be good to go and it should all work like factory.
    Fernando[QUOTED][OP] likes this.
  19. Nov 9, 2020 at 7:22 PM
    #2079
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks brotha!
    slander likes this.
  20. Nov 12, 2020 at 8:41 PM
    #2080
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Do you still have the push button?
