Fernando's 2004 DC! "THE TANK" Got Juanton Soup!
Discussion in '1st Gen. Builds (1995-2004)' started by Fernando, Jul 8, 2013.
  1. Jan 20, 2018 at 7:45 PM
    #1361
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    You won't
    Fernando[QUOTED][OP] likes this.
  2. Jan 20, 2018 at 7:47 PM
    #1362
    Fernando
    Fernando [OP] Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  3. Jan 20, 2018 at 7:50 PM
    #1363
    cbechtold
    Cory
    Pleasanton, CA
    Let's be real. You're next mod should be either a crawl box or a 4 speed Atlas. You'd be almost unstoppable out on the rocks.
    rob1208 and Fernando[QUOTED][OP] like this.
  4. Jan 20, 2018 at 7:51 PM
    #1364
    JKO1998
    JKO1998 Well-Known Member
    Utah
  5. Jan 20, 2018 at 8:02 PM
    #1365
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thought Bout the crawl box :)
    Lol!
  6. Jan 20, 2018 at 8:08 PM
    #1366
    cbechtold
    Cory
    Pleasanton, CA
    My only word of advice is that the crawl boxes are made for the toyota mini trucks, while the Atlas T-cases are built for the 16,000 pound military Humvees. Atlas is stronger, but the crawl boxes are cheaper. Choose your poison.
  7. Jan 20, 2018 at 8:15 PM
    #1367
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Can one do both?
    My buddy runs a crawl box in his sas runner??
  8. Jan 20, 2018 at 8:20 PM
    #1368
    cbechtold
    Cory
    Pleasanton, CA
    No. The crawl box is a reduction unit that bolts between transmission and transfer case. An Atlas replaces your existing transfer case. Both have adapters to fit properly, but as far as I'm aware, they don't work together.
  9. Jan 20, 2018 at 8:22 PM
    #1369
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Oh. Heard awesome things about an atlas.
    So what do these normally run? Crawl box is like 600ish right?
  10. Jan 20, 2018 at 8:23 PM
    #1370
    cbechtold
    Cory
    Pleasanton, CA
    Try $2000. For an Atlas, double that.
    jubei likes this.
  11. Jan 20, 2018 at 8:33 PM
    #1371
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    3/16will survive the rubicon. Just take it slow. No hard drops..
    I have seen crawl boxes for 1600 on cl and atlases for as low 1900 on cl
    And i think cory ment thry replace or add on to your t-case not replace transmission
    Fernando[OP] likes this.
  12. Jan 20, 2018 at 8:37 PM
    #1372
    cbechtold
    Cory
    Pleasanton, CA
    I'm factoring in tax/shipping. Craigslist is a whole different animal. I've seen some stupid low deals on there. Brand new 4 speed Atlas's are about $4000 though.
    Definitely meant transfer case.
  13. Jan 20, 2018 at 8:47 PM
    #1373
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Fuck thats alotta dough.. I can pick up some axles for that price
  14. Jan 20, 2018 at 8:50 PM
    #1374
    cbechtold
    Cory
    Pleasanton, CA
    Yea, buy junk yard axles for $3000 and then pour $7000 in parts into them.
  15. Jan 20, 2018 at 8:58 PM
    #1375
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Never ending........fmk
  16. Jan 20, 2018 at 9:05 PM
    #1376
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Idk. If he wants tons, I've seen super 60s on CL for 750, rotor to rotor. 14 bolts can be had for 300-400. Yes, after you have them you gotta gear em, lock em, and bearings are a good idea, but after you spend 3-4k, you should have some pretty solid axles.
    Now Kingpins would be a different story. Much more expensive...
    tacomgee likes this.
  17. Jan 20, 2018 at 9:15 PM
    #1377
    cbechtold
    Cory
    Pleasanton, CA
    I talked to a local junk yard about getting axles out of a '78 E350 and I was quoted $1500 both a D60 Kingpin and 14bolt. WFO Concepts also sells 14bolts and D60 Kingpins, but they're charging the same price last time I checked.
    Also upgrades are going to be pricey. You're looking at $4000 just for ARB air lockers and gears, and then you through in some chromoly axle shafts front and rear, new knuckles, hubs, brakes, etc. and you're easily looking at $7000.
  18. Jan 20, 2018 at 9:24 PM
    #1378
    FirstTimeFirstGen
    David
    Pacifica
    And what you're talking about are the compromises I'm willing to make. As much as i like kingpins, when i put tons under the jeep, it will be a super 60, not a kingpin. Too expensive. Same for ARBs. I love em, but my front will have a spool. I just will use the original hub locks instead of drive flanges so i can disengage when off the trail. Haven't decided on a locker for the rear. Probably a ratcheting or Detroit. Theyre just sketchy when cornering on pavement lol. As far as chromolies go, stub shafts yes, the actual axle shaft is overkill IMO. A couple buddies of mine run 43s on factory axle shafts and one tore his turbo 400 housing in half before breaking an axle shaft. it really depends on if you are planning on building a crawler or an ultra 4 rock racer/bouncer. I want to build a crawler with coilovers and bypasses so i might be able to play with it in the sand and desert too
    Shouldn't have to upgrade the brakes, knuckles,or hubs on a super 60 unless you're going rock racing or putting the axles under a heavy ass vehicle.
  19. Jan 20, 2018 at 9:28 PM
    #1379
    Fernando
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Wish i could sell a kidney. But dont nobody want that shit
  20. Jan 20, 2018 at 9:34 PM
    #1380
    cbechtold
    Cory
    Pleasanton, CA
    Yep. There's definitely a difference in build ethics and vision. Suspension-wise, we're not far off. I'm thinking 3 link front and trailing arms 4 link rear with bypasses and coil overs at all 4 corners. Plus and LS sounds like fun :cool:
