Few noob questions....
Discussion in '1st Gen. Tacomas (1995-2004)' started by buster2209, Jan 25, 2010.
  1. Jan 25, 2010 at 7:31 PM
    buster2209
    buster2209 [OP] New Member
    I want to get a vehicle that can be used both off road (not rock climbing!) and can use as a daily drive. Initially was going to go with a Jeep but after extensive research, I realised the Rubicon is the only one that can actually go off road as stock. The Rubi is out of my price range plus I'm not entirely happy with the reliability or ride comfort of the Jeeps.
    To this end, the Tacoma springs to mind.
    My questions are really easy so should not pose a problem for you guys (and gals);
    The rear diff locker. How do I know it's on the 1st gen? Do all TRDs come with a rear diff locker?
    What are the things to look out for when buying a 1st gen?
    Thanks in advance!
  2. Jan 25, 2010 at 7:39 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    I believe the TRD Sport didn't come around until '05. Meaning, yes any 1st gen TRD will have the rear locker. Other recommendation, get the double cab. Good luck, good choice!
  3. Jan 25, 2010 at 7:39 PM
    ColdZeroBSP
    ColdZeroBSP Yo homie, that my briefcase?
    Geoff
    Tewksbury MA
    2012 TRD Sport DC
    console vault, viper remote start, weathertech front and rears
    Not sure about 1st gens, but on the 2nd gens only the TRD Off Road edition comes with the locker. I'm not even sure if 1st gens came with lockers from the factory :confused:
  4. Jan 25, 2010 at 7:41 PM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    theres a rr lock switch to the left of the steering wheel. Just because it has the sticker on the bedside doesn't mean it's a TRD, anybody can slap a sticker on and ask for more money.
    Check the frame, many of the first gens have rusting frames. not to mention your buying a used car, don't get giddy when you find one, go over it with a fine tooth comb, to make sure your getting what you actually want.
  5. Jan 25, 2010 at 7:43 PM
    buster2209
    Yeah, I saw the button on some pics.
    From wikipedia;
    Just wanted to double check.....
  6. Jan 25, 2010 at 8:06 PM
    ywen
    ywen Well-Known Member
    You don't need anything as hardcore as a Rubicon to go off road. Any stock Wrangler will have better departure/approach angle than a stock Tacoma.
    The reason I went with a Tacoma over a Wrangler was because 1) I only like the JK.. which means I would need to shell out more $$$. 2) As much fun as I had with a 4door JK (Sports trim), I knew that I really wanted the versatility of the truck bed.
    I anticipate I would get pretty much the same level of off-road ability whether be the JK Sport or 03 Tacoma TRD... Yeah e locker will be nice in certain situations but I didn't get stuck at all with the JK. The 4door JK rode MUCH better on-road than my Tacoma TRD.
  7. Jan 25, 2010 at 8:11 PM
    buster2209
    I hear ya. It's the whole locking diff thing. I used to drive a Land Rover Defender and the locking diffs come into there own when off roading. Not too mention the weak dana 35 axle the Wrangler has too.....
    The versatility of having a bed too also is a plus.
  8. Jan 25, 2010 at 8:15 PM
    ywen
    What's the rear axel on the 1st Gen TRDs? Stronger than Dana 35?
  9. Jan 25, 2010 at 8:24 PM
    buster2209
    Good point. I have no idea. I assumed it was as I haven't seen anything bad about the Tacoma axles plus, if you lock axles, they are under way more strain that limited slips so, again, I would assume the Tacoma axles were competent.
  10. Jan 25, 2010 at 8:50 PM
    Jay W.
    Jay W. Whaaat?
    Jay
    Central, SC
    06 Tacoma DCSB 4x4
    Not too sure about the axle question..
    However, I was a Jeep guy before I bought my Tacoma. A stock TJ (97-05 Wrangler) is a very versatile 4x4 even without the Rubicon package. Just find one with a Dana 44 rear (the D35 is garbage). Back on Jeepsunlimited.com the guys told new guys to start 'wheeling stock or mild to know the capabilities of you and your vehicle, then start building from there.
    I'm not trying to turn you away from a Tacoma, they're the best truck on the market, period. However, don't limit yourself just because you can't find a locking differential..heck, you can always add one of those on down the road anyway!
  11. Jan 25, 2010 at 10:29 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    not all TRD branded tacos came with a locker...
    the lockers were only tacos that were TRD, but vice versa does not apply...
    dont worry so much about the locker... worry more about the motor and tranny... like Jay said, you can always add the locker later...
  12. Jan 25, 2010 at 11:48 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I have 4x4 but don't have a locker. It's my daily driver and it's capable enough off-road (but not hard core rock climbing).
  13. Jan 26, 2010 at 2:04 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I think it's already been said, but 4 cyl TRD Tacos didn't come with a locker.
    Don't worry too much about the frame rust either, Toyota will replace it free to you if it's bad enough.
