Few Q's for the tacoma owners(new here)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCtaco914, Oct 23, 2012.
  1. Oct 23, 2012 at 5:03 PM
    NCtaco914
    NCtaco914 [OP] MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Hey everybody, bought my first Tacoma. Traded my Titan in for one...lol Well
    I have several questions about them since I come from a previous Nissan owner. Now I looked around and if anyone can point me to a good thread that would be great. And im sure some of my questions belong in other sections but, here it goes..also my truck is a 08' TRD sport double cab 4wd 6spd
    1st my truck has 94k miles. Is there anything I need to look for? or replace? Truck runs and drives amazing for that kinda mileage.
    2nd does anyone have any recommendations on fluids? Coming from owning a few Nissans they also had specific fluids for t case and tranny. My Toyota manual just calls for generic fluids. I prefer Amsoil being a mechanic so I would runs Amsoil in everything. Tranny, tcase, and diffs.
    That is really about it for now. Planning on doing a lift once I get all the fluids done and any maintenance that needs to be done. And thank you for anyone that helps. I feel lost owning a Toyota now
  2. Oct 23, 2012 at 5:12 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    i came from owning a ford..also had nissan...i say use what you are comfortable with amsoil is really good ..just keep up w/ regular maintenence and it will run forever
  3. Oct 23, 2012 at 5:14 PM
    timmy2112
    timmy2112 Well-Known Member
    Welcome to the forum from Northeast Arkansas and congrats on your "new to you " Taco. IMHO, I would go to this website http://www.toyota.com/owners/web/pages/home and register with your VIN and you can access all dealer and if the previous owner did his or hers own service and posted them, you can find out what kind of services in the past this vehicle had done to it, then I would probably change the drive belt, service the rear and front diffs, make sure the driveline has been greased, I bought my 09 DC 4x4 V6 with 92,000 on it and it is pretty tight for being driven on gravel roads and still runs pretty peppy for its mileage. Enjoy parking with ease, I traded in on 08 Tundra, and love how easy it is to park in these small parking areas.
  4. Oct 23, 2012 at 6:18 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    yea as long as you stick with called viscosities and grades it will be fine. the toyota coolant is the only thing i would be picky about. and looks like your about due
  5. Oct 23, 2012 at 7:58 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Awesome! Thanks for the responses. Yeah I just wasnt sure mainly about running certain fluids in the tranny and tcase. But, I should alright using Amsoil in everything then. Serpentine belt is new and I also asked the dealer for any service records and they had very little. And the coolant appears decent looking..it is red which I believe is Toyota's line of fluid??
  6. Oct 23, 2012 at 7:59 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Welcome to TW :wave:
  7. Oct 23, 2012 at 8:07 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Check your brake and power steer fluid and plugs. Some things a lot of regular people forget about.
  8. Oct 23, 2012 at 8:17 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard from the High Desert of Central Oregon :cheers:
  9. Oct 23, 2012 at 8:33 PM
    badger
    badger Well-Known Member
    07 SR5
    Redline Mt-90 for the transmission and Tcase. Nothing beats it for improving the shifting. I also run Redline gear oil in the diffs. Lowest temperature under load that I have found. It's not as critical if you aren't towing or hauling. Amsoil manual transmission oil would be my second choice for the trans and tcase. I'd stick with the Toyota coolant. It is pink. Coolant is due for change at 100K. Don't neglect that just because it looks good. It needs to be replaced. If your throttle body and MAF have not been cleaned, I would add that to the to-do list. There are tutorials that help at the top of the page. Since you are a mechanic you won't have any trouble with any of it. For oil many of us are using Mobil-1. The Toyota factory oil filters are the ones to use.
  10. Oct 24, 2012 at 9:24 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Never heard of redline? Will look into it..I just get discounted prices on Amsoil and always happy with the quality. Hmmh will deff look into the coolant and plugs..ps and brake fluid look great. Thanks badger!
