Few questions / OME Dakars / D6XL AAL / etc...
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, Jul 4, 2012.
  1. Jul 4, 2012 at 3:44 PM
    License2Ill
    License2Ill [OP] Ain't one for poetry & prose
    Ian
    AZ Über Alles
    04 DC TRD 4x4
    SC'd Double cab 5 spd
    About to replace my questionable rear Dakars with new ones. And installing the D6XL. Along with 65 Nitrochargers.
    Few questions.
    CS046R: A=Driver's side / B= Passenger's? Correct?
    The D6XL is the 3rd leaf when installed? The original 3rd leaf will now be the fourth leaf. Looking at the pack from the top...
    My DSM has the axle as the ideal support position. Is it ok to position the jack stands under the frame rail directly under the rear-most frame to body supports, like the 2nd gen DSM states?
    TIA
  2. Jul 4, 2012 at 5:49 PM
    GLD01
    GLD01 Well-Known Member
    Jamie
    Denver, CO
    Tacoma SR5 TRD
    Toytec lift coils w/Bilstein 5100's; OME Dakars w/Bilstein 5100's; Camburg UCA's; Gray wire mod; Deck plate mod; Cooper Zeon LTZ 265/75 R16 tires
    Correct.
    Yes.
    Yes.
    Good luck. This is the exact same leaf setup I recently installed and I'm really liking mine.
  3. Jul 5, 2012 at 4:41 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    Was a PreRunner, now it isn't
    post up a few pics of the leaf pack before and after install of the D6xl along with pics of the stance before and after thanks
  4. Jul 5, 2012 at 10:42 PM
    License2Ill
    Ian
    AZ Über Alles
    04 DC TRD 4x4
    Thanks Jaime!
    Sorry. Before pics are a little to late to happen now. Up on jacks...
    My situation is a little different than just an upgrade..
    Doing this because I was taco-leaning about 1" to 1-1/4" in the front and about 1/2 to 3/4 in the rear.
    Keeping my old 882's, but replacing everything ome with new.
    PO did the original ome, and it sat too long w/o being used. I don't believe lifted suspension components should sit around for 4 years with 10k miles on them w/o seeing a trail, so I'm replacing them.
    Also doing 1.5" shackles, 10mm tp spacers and trying either a 5mm or 10mm trim packer for the taco lean. So I'm not just doing the AAL.
    Cheers.
  5. Jul 6, 2012 at 4:06 PM
    hossmaster
    League City, Tx
    believe me i know about gangsta lean, i have the same problem. i just want to see the pack after you put the aal in. also if you dont mind telling us the ride height change.
  6. Jul 6, 2012 at 9:35 PM
    License2Ill
    Ian
    AZ Über Alles
    04 DC TRD 4x4
    Sure! I'll post a pick next week.
