Few questions regarding 3" suspension lift and components
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98Tacoma13, Apr 21, 2013.
  1. Apr 21, 2013 at 10:06 PM
    98Tacoma13
    98Tacoma13 [OP] Active Member
    i have a 98 tacoma 4x4. currently has all stock stuff height wise except for a readylift level kit (2" lift) and diff drop kit.
    i'm getting a bilstein 5100 set, toytec springs, 3" add a leaf and rear 5100s.
    my questions are; these are going to sit with a 2" rake? i have no experience with add a leaf stuff, and i assume the 3" front lift is off standard height. i want my truck to sit level. anyone else running similar setup?
    run the fronts at the "leveled" setting (+1.25" if i read correctly), so the truck would be closer to level. this would be 4.25" of front lift, it said not recommended to avoid damage/harsh driveline angles i imagine.
    so for someone who doesn't wheel a truck hard, is 4.25 front lift safe? i have the diff drop from my readylift kit. any feedback here is appreciated. my leafs are in great shape. they aren't sagging as a foundation reference.
  2. Apr 22, 2013 at 5:34 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Remove the ready lift. Add the Eibach springs and 5100's at 0" and get a 2" AAL should sit level.
  3. Apr 22, 2013 at 9:38 AM
    98Tacoma13
    OK, Thanks for the input.
  4. Apr 22, 2013 at 10:19 AM
    whathefk
    whathefk Member
    Normaly factory rake is an inch higher in the back. Set front at 3" and put 2"aal in rear. I have a lot of weight in the back, so I have 2" aal's and 1" shackle lift rear and front is at 2.75" and I'm level.
